Question about Electrolux EIED55H Dryer
How to repair an open heater circuit on electrolux dryer
  • Official Brand Answer
  • 4,342 Answers
Hello Gary Melton - Usually this type of information is not release to someone who is not a technician and it is very rare to find enough information to do it yourself. In most cases this information can be found on the internet; however it is not provided directly from the manufacturer. Typically this is something that you want a certified professional to install/remove for you due to safety and liability reasons. They also usually warranty their labor just in case something else may turn out to be the root cause of your initial problem and it does work out better to your advantage. Consider contacting your manufacturer for more details on who in your area can properly repair/install this part (part usually have a 30 day warranty with tech). I would suggest contacting your manufacturer to provide you a listing of authorized technicians in your area whom may guide you through this process.
Posted on Jan 11, 2013
2 Suggested Answers
  • 3074 Answers
SOURCE: Electrolux EDC5340 dryer: drum is hard to turn,
you can take off the front panel, there are screws inside the dryer door,may have two on the bottom corners and then gently pry up on the top corners with a flat tip screwdriver. disconnect the door switch and the panel is off. check to make sure the the belt is centered and you can turn the drum. hope this helped tim
Posted on Sep 03, 2010
I have Electrolux dryer model number EIED55HIWO and it says E64code...what do I need to do?
It indicates that there is an open it the heating circuit. It most likely means the heating element has gone out in it.
Feb 12, 2018 | Electrolux Dryers
WHAT DOES E61 ELECTROLUX DRYER
Hello Friend, this is Z. Thank you for allowing me to assist you!
If you are receiving an error code E61 on your Electrolux dryer, it usually means that your dryer is experiencing an issue with the heater relay. A qualified technician would pinpoint the problem by checking the wiring for both open and short circuit across heater relay(s). If the wiring isn't the issue, he/she would need to determine whether the problem rest with the main control board. It really could be a hit or miss calculation in parts so I would personally reach out to an experienced tech that will be able to identify the precise reason. Best regards!
Jul 25, 2014 | Electrolux EW1200i Front Load Washer /...
E64 code eletrolux dryer
Hello cordiapartin - Typically error code E64 indicates that the dryer has detected that the heater circuit is open. Contact a professional to move forward accurately to check the heater coils and connections for an open circuit. Depending on the diagnosis's, the heater might need replacing and/or wiring
Feb 22, 2013 | Electrolux EIED55H Dryer
I own a 1Q-Touch Front-Load Electrolux washing machine. The door won't open. What can I do?
Hello Elizabeth P Cochran - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
Jan 15, 2013 | Electrolux EIED55HIW Electric Front Load...
E64 error code
Hi gordsxbstn34 - Typically error code E64 indicates that the unit has detected that the heater circuit is open. Contact a professional to move forward accurately to check the heater coils and connections for open circuits. Depending on the diagnoses heater might need replacing and/or wiring
Jan 11, 2013 | Electrolux EIED55H Dryer
Error code e64
Hello Gary Melton - Typically error code E64 indicates that the unit has detected that the heater circuit is open. Contact a professional to move forward accurately to check the heater coils and connections for open circuits. Depending on the diagnoses heater might need replacing and/or wiring
Jan 06, 2013 | Electrolux EIED55H Dryer
What is an Electrolux dryer E64 code?
You are experiencing an open heater circuit error. Check heater coils and connections for open circuits. Replace heater and/or wiring and retest.
Aug 30, 2012 | Electrolux Dryers
I was drying and the dryer shut off and gave an error message of E64
Hi
Error code E64 means Heater Open Circuit. This error appears when the Heating element or wiring to the heating element is defective. To clear the error code (s): Press and hold the far left key under the display and “cancel” buttons simultaneously for 3 seconds. If the error appears again then you’ll need to check heater coils and connections for open circuits. Use a multimeter to check the heater element, use Rx100 setting on the multimeter. It should display 30-33 K ohms as the resistance. If it is less than this or exceeds this limit then the element has gone bad and you would need to replace the element. Hope this helps...
Daniel
Sep 13, 2010 | Electrolux EIED55H Dryer
Error message e64
Hi
Sep 07, 2010 | Electrolux EIED55H Dryer
Electrolux dryer error code e63
I have ann E63 code on my Electrolux dryer. THe vent pipe was somewhat clogged but now is cleaned.What do I do?
Jan 02, 2010 | Electrolux Dryers
Electrolux EIED55H Dryer Logo
103 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
vince
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
