Question about Ovens
Open door handle is loose on a true temp GE stove how do I tighten the handle
    Genius:
  • Ovens Master
  • 1,669 Answers
You will need to unscrew and unfasten the inside door panel to access the screws that need to be tightened.
Posted on Jan 24, 2013
SOURCE: loose oven door handle
I had the same problem. We took the door off completely & turned it upside down. There are screws on the bottom of the door, take them out, take off bottom trim piece that holds the outside glass panel in place, remove glass panel and you can access the door handle screws and clean the inside of the glass while you are at it.
Posted on Feb 17, 2009
MNTECH
  • 1543 Answers
SOURCE: GE True Temp oven won't turn off.
The sensor is a part number WB23T10002 and goes for about $60. The paper inside the control area of the oven will state the normal resistance values of it. (probably about 1080 ohms at room temp, about 2650 at clean temp.) If you cut a lead to it, you would just get a F3 code, and if you cut the other and wire them together, just get a F4 code, so that wouldn't help diagnose the problem, but if you could use an ohm meter on the probe it would. BUT the oven should not come on without it being set to bake, SO I conclude that the ERC is indeed the problem (with the welded electrical contacts), which is a part number WB50T10043 which might go for about $125 or so. If you are careful when you replace it, you can probably peal the faceplate (part # WB27T10125) off and reuse it, so you should just need the ERC.
Posted on May 07, 2009
SOURCE: Loose Oven door handle
can get spares from
Tel. 01628 620081 Fax 01628 776345 - Spares Email is spares@a1tech.co.uk
Posted on Apr 14, 2008
localwonder
  • 6784 Answers
SOURCE: oven will not get out of the self-cleaning mode
Ok, unplug the unit for 5 minutes to reset the main circuit board. if the error continues to plague the unit, replace the control board.
Posted on Jun 01, 2009
SOURCE: GE True Temp Oven not heating. Broiler works
we bought a new oven
Posted on Dec 15, 2009
Oven door handle one side not attached to door other side loose
look around the outer edge of the door a few screws hold the 2 halves together caution do it on a flat surface as the glass can fall out .
Sep 01, 2016 | Neff Ovens
Where is the serial number on the GE True Temp Oven?
open the oven door and look for a label or a tag with numbers on it .
Apr 06, 2015 | GE Ovens
How to tighten loose handle
Remove the door gasket, that should give you access to removing door plate. Door handle may need to be replaced.
Oct 26, 2013 | Combi Steamer electric built in steam...
The door handle of my oven whirlpool gold model no GGP84803 is loose I try to get it off by prying it from the top with no luck seem to be jam or locked I am not sure how to proceed.
I had same problem, fixed by removing screws under door and removing side panels . Then remove front glass ( 4 screws under glass ) and remove other screws behind glass to remove handle and then tighten 4 screws on handle. Works great.
Dec 29, 2009 | GE Ovens
Oven will not get out of the self-cleaning mode
May 31, 2009 | GE Ovens
May 05, 2009 | GE Ovens
You may have to get some loctite brand paste in a tube for applying to the threads of the bolts that hold it on.
This will prevent the screws from loosening.
Another way would be to get some spring washers or star washers at your local hardware store such as menards.
Jul 02, 2008 | Smeg SE399X/5 Stainless Steel Electric...
I would try putting some locktite on the threads so It wont come losse anymore.
Nov 07, 2007 | Ovens
Ovens Logo
318 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
