Question about Panasonic KX-TG5673 Trio Cordless Phone
Ring tone changed tonight--it is too loud and awful.
How do I change it back to a normal ring tone? I can't find the manual.
Thanks so much.
    President:
  • 1,952 Answers
The Ringer ID, Light Up ID, Picture ID and Custom Ringer settings cannot be assigned via the software, nor backed up, restored or transferred to another handset.
3. The USB connection cannot be plugged in while the phone is being charged - it is also physically impossible to do so. Kind of dumb given the USB connection sucks a lot of battery power.
4. In fact the USB should plug in to the base/charger so the phone is instantly connected (like a PDA) once docked, with two-way synchronisation. This is not as important though, as #2 above.
5. It is possible (as I learnt the hard way) to inadvertently wipe out the existing phone book and all its hard fed Ringer ID, Light Up ID, Picture ID and Custom Ringer settings merely by attempting to add new entries thru the software without first retrieving the existing entries from the phone. On the positive side, re-sending the same entries does not overwrite the already set up Ringer ID, Light Up ID, Picture ID and Custom Ringer settings.
Posted on Jan 20, 2009
Hi just got a alcatel 2036x cheap phone but cant change ring tones can i do it on this cheap phone thanks
go into settings, ring tones , and change it there , can only change to those listed,
Oct 03, 2016 | Alcatel Cell Phones
How do I change the ring tone to a normal ring tone
Since you neglected to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Oct 29, 2012 | Uniden DECT 6.0 Cordless Phone ID
How do i change ringer tone and adjustment of Euroset 2005 Corded Phone
How to Change the ring tone of the Phone - "Siemens Euroset 2005"
1st - Lift the Telephone receiver
2nd - Press Set/Mute
3rd - Press # and any number 1 to 9 and then Press #
4th - Place the Telephone receiver in its normal Position.
That's it now you should have changed your ring tone of "Siemens Euroset 2005"
Thanks Enjoy
Jun 23, 2011 | Siemens Euroset 2005 Corded Phone
Ringer is marked as off on my blackberry bold 9700 and i have no sound
Hi,Sound profiles define how your BlackBerry device alerts you of phone calls, messages, reminders, and browser content.
Your device has a Normal sound profile and six other preloaded sound profiles: Loud, Medium, Vibrate Only, Silent, Phone Calls Only, and All Alerts Off.
By default, some of the settings in the preloaded sound profiles are based on the settings in the Normal sound profile. For example, when you change the ring tone in the Normal sound profile, the ring tone in the Loud, Medium, and Phone Calls Only sound profiles is automatically updated. If you do not want specific settings for a preloaded sound profile to update automatically when you change the corresponding setting in the Normal profile, you can manually change the settings in that preloaded sound profile.
You can create custom sound profiles. When you assign a custom ring tone to a contact, the ring tone is always active and does not change when you switch sound profiles unless you switch to the All Alerts Off sound profile. Call and message notifications for your contacts might be audible even if you switch your sound profile to Silent or Vibrate Only.
You can change, rename, and delete most preloaded sound profiles. You cannot delete the Vibrate Only sound profile and you cannot change, rename or delete the All Alerts Off sound profiles. You can change the Normal sound profile, but you cannot rename or delete it because some of the settings in the other preloaded sound profiles are based on the settings in the Normal sound profile.
Sound profiles define how your BlackBerry® device alerts you of phone calls, messages, reminders, and browser content.
Change a sound profile
If you change a setting in a preloaded sound profile that is based on the Normal sound profile, that change will override the corresponding Normal sound profile setting in the preloaded sound profile.
1. On the Home screen, click the Sounds icon.
2. Perform one of the following actions:
* To change the active sound profile, click Set Ring Tones/Alerts.
* To change a custom or preloaded sound profile, click Edit Profiles. Click a profile.
3. Click the application or item that you want to change.
4. Change the notification information.
5. Press the Menu key.
6. Click Save.
7. Press the Menu key.
8. Click Save.
Hope that helped...
Feb 08, 2011 | RIM BlackBerry Bold 9700 Smartphone
A am not getting any sound when faxing or when faxes are coming through and my volume is on loud why is that.. I disconnected plugged it back in changed some settings and i still get nothing
Your HP all-in-one provides three levels for adjusting the ring and speaker volume. The ring volume is the volume of the phone rings. The speaker volume is the level of everything else, such as the dial tones, fax tones, and button press beeps. The default setting is Soft.
1 Press Setup.
2 Press 4, and then press 8.
This displays the Basic Fax Setup menu and then selects Ring and Beep Volume.
3 Press to select one of the options: Soft, Loud, or Off.
Note If you select Off, you will not hear a dial tone, fax tones, or incoming ring
tones.
4 Press OK.
Sep 15, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Volume on the phone/speaker/ring is very low
You can change ring tones by pressing the flash button until you get the ring you want. When you get the ring you want press the set button.
May 24, 2009 | Innovage Speaker/Caller ID* LCD Touch...
LG KC910 Renoir RIngtone Volume
it might be the ring tone you have, i had the same problem but when changed the ring tone to a music tune i had downloading or bluetoothed it was very loud
Jan 14, 2009 | LG KC910 Renoir Cell Phone
Won't Ring
check the settings in your phone book. this happened to my phone and all of the personal ring tones were set to vibrate. I don't know how this happened. I went into each contact and changed the ring tone to none and I am back in business
Sep 15, 2008 | Motorola Mobility W385 Cellular Phone
Text tone motorola V3i
go to options ring styles... then for example your ring style is loud, then go to loud detail and there select the type of alert for messages. similarly it applies for all the other ring styles.
Apr 26, 2008 | Motorola Mobility RAZR V3i Cellular Phone
MOTO PEBL MESSAGE AND RING TONE
i think this is what you're going for...Go to SETTINGS, then RING STYLES. Whatever ring style (ie, vibrate, silent, vibe & ring, vibe then ring, loud, soft), underneath is the detail for it, which you can then change (bottom right of screen).
So right now my phone is:
"Style: Vibe & Ring" and underneath that is "Vibe & Ring Detail"
Under the details, you can change your ring tone by scrolling down to the "Calls" option and choose change (bottom right of screen). And to change your message tone, just go to "Messages" and then change (bottom right of screen).
Hope that helps!
Apr 08, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Panasonic KX-TG5673 Trio Cordless Phone Logo
132 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
