Question about Microsoft Point-of-Sale Point of Sale Software POS Single Store Only (MIC-POS2.0)
How to replace miltiple whitespaces with single space in java?
Input: "nikunj gohel"
output:"nikunj gohel"
    Brigadier General:
  • 10,406 Answers
Nice try! Find an upper-class student to give you one-on-one tutoring with your homework.
Posted on Dec 02, 2009
Tm u220 java
Are you printing from inside a java program (output) or from a java program editor.
Use the command to Open an output file, have all your output sent to the output file, close the output file properly before you exit the java program. After you finish send the output file to the matrix printer as you would with ASCII file. If the printer is installed properly, your OS should know where to send the output.
Dec 23, 2013 | Epson TM-U220 Matrix Printer
HOW TO WIRE GEMINI GRAPHIC EQ 3000 TO behringer djx750 proffessional MIXER
Line level output of the mixer would go into the line level inputs of the EQ, and the EQ line level outpputs to the line level inputs of the amplifier. If you are faced with a mix of unbalanced inputs or outputs, to balanced inputs or outputs it gets a little complicated because you need to matrix the balanced signal to unbalanced load and vice versa. There is no single answer to doing this either.
RCA jacks are unbalanced, 2 conductor 1/4 inch connections are unbalanced most of the time. XLR and 3 conductor 1/4 inch jacks and plugs can be either balanced or unbalanced.If either are wired so left and right are a single ring or tip on the 3 conductor 1/4 inch jack, it is unbalanced and they would share a common ground lead. XLR wired with one pin common with shield and right and left have a single conductor on the plug or jack, that is unbalanced.
Apr 26, 2012 | Behringer Pro Mixer Djx750 Professional 5...
How do i connect subwoofer (canton movie 125 mx) to amplifier(onkyo txnr609)? there is one subwoofer output on the amplifier with either L & R(mono) high level input or L & R(mono) low level input...
Connect front the sub out (single) on the amp to one of the rca inputs on the sub, This will work reasonably well but to make the most from the sub buy a 2 rca to 1 rca cable and use it to connect both rca inputs on the sub to the single output on the amp
Mar 10, 2012 | Canton Movie 125 MX Speaker
No ethernet disk available
Hello, This is not my turf. Would guess that green means go and that channel is okay and orange means problem for the other channel. Would suspect that you had something running on the orange channel while the Download was going on, as most Downloads want you to exit running Programs.
You could try to Download the info again and I hope you use a Restore point, for that matter, a Restore point should have been created before the first Download. Sometimes Firewalls and Antivirus software will block parts of a Download to make the Download usueless. Some Antivirus Programs can be put to sleep while important Downloads are conducted. If you trust the site, turn off your Firewall and Antivirus.
Dec 01, 2011 | LaCie 2TB Network Space 2 A)
Hi there, I am building a java application which will call to praat for some execution of sound. I managed to call and sendpraat to praat from java application by java runtime.exec() But the praat seem to...
I was able to solve this problem..........
My java code is following........
String[] sendpraatCom = new String[3];
sendpraatCom[0] = "./sendpraat";
sendpraatCom[1] = "praat";
sendpraatCom[2] = "execute " + "<filename.praat>";
Runtime run = Runtime.getRuntime();
run.exec(sendpraatCom);
Now it is working properly.......
Dileepa sisila chandrasekera.
Department of Computer Science and Engineering
University of Moratuwa
Sri Lanka......
Apr 02, 2011 | Praat
AV receiver single line output to two line input on sub woofer
You are trying to connect the powered sub output of the receiver to a standard (unpowered) subwoofer. Can't be done.
May 05, 2017 | JVC Audio Players & Recorders
Java programming: file access
(R.id.note) this is the error in java, How can I rectify it;
Aug 29, 2008 | Computers & Internet
Java programming
There are 2000 jpeg libraries in Java out there, easily searchable on search engines, sourceforge, maybe versiontracker, and secondly, you're asking for (what should be application-specific -output-; why would you hobble input) crop/resize without hinting at your algorithm? First, get a real programmer....
Java project for college applications? Gee, how about one to take a personality inventory (the INTJ type; only padded out) including areas of interest and make people little public/private spot codes (2D barcodes, like the ones in Japanese magazines) to indicate their type. The camera in a cellphone with J2ME can read the codes, maybe.... The cool part is that they're coupled with either P3P in wikis or java applets that help communicate with that person if you're an type that would otherwise take bothersome human care and preface to communicate.
There are all kinds of little systems you can build to thwart the draggy bits of Alzheimers' etc. with various little expert systems, that come up when you read a science journal (Nature, Science, Dr. Dobb's Journal, JAMA, JVNA....
You could invent something other than big-headed anime characters to add a personal visual reference to GUIs; emobots were cool, but maybe you can have a **** Cheney's Hands IM environment if it doesn't already exist (see also: Galludet University (for deaf students) stuff.)
Mar 20, 2008 | Computers & Internet
Sentence
send me your code -- and I can fix it
Feb 27, 2008 | Computers & Internet
Microsoft Point-of-Sale Point of Sale Software POS Single Store Only (MIC-POS2.0) Logo
73 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
