Question about Xerox DocuColor 1632 Laser Printer
Xerox Docucolor 2240 - how to change fusers & xfer belt cleaner?
I have a spare fuser assembly but no docs on how to swap...any ideas?
Also, how hard is it to replace the "transfer belt cleaner"? Should I call for a service call, or try it myself (limited experience)? Thanks...
    Problem Solver:
  • 19 Answers
I am not familiar with that particular model Xerox but generally speaking Xerox maintenance is more difficult that say your average HP, Lexmark, etc. I would call a service professional if I were you
Posted on Jan 20, 2009
Model 7665. What do fusher system errors 10.311.00 and 10.322.00 indicate?
Both of those indicate a defective fuser, replace fuser, part number 008R12988.
http://www.iteminconline.com/008r12988_008r12988-8r12988-622s00044-622s44-xerox-docucolor-250-fuser-assembly-110v-compatible-with-docucolor-240-250-workcentre-7655-7665-7675-7755-7765-7775-new.htm
Jan 10, 2016 | Xerox Office Equipment & Supplies
What is open heat errot
One of two things, both will require a fuser replacement.
Either the over hear thermostat has open, or and most likely the heating element built into the heat roller has failed. Normally the heating element burns out and displays that message, I have not found that roller assembly spared, and even if you try and swap one from a used fuser to new, they are really dificult to change because of the spring end contacts.
In simple terms, replace the fuser and you will fix the problem.
Mar 28, 2009 | Xerox CopyCentre C20 Black and White...
Xerox Docucolor 2240 - says the fuser needs replacing, and I have a spare used one, but no docs on how to do it. Any ideas? Also it says I need a new "transfer belt cleaner" - can this be done easily,...
After normal start up press and hold 9 and the # key together after a few seconds it will ask if you have installed a new fuser just hit yes and you r done.
The tranfer cleaning belt is easy to replace just two screws but you have to clear the consubable life couner this is where i ame haveing problems it can be done but i dont know how if you find out post back here and let me know.
Jan 20, 2009 | Xerox DocuColor 1632 Laser Printer
Xerox Phaser 780
This problem occurs do to a defect in the fuser drawer. In the fuser drawer, there are two black plastic parts that can go up or down. Their function is to push the belt cleaner on and off the accumulator belt after every pass. A defect in this system causes these parts to stay up, pushing the belt cleaner on to the belt every step except the last one, causing only the black toner to remain on the belt.
It's hard to track what the exact cause is but I would recommend checking gearing and gear teeth in your fuser drawer.
Nov 02, 2008 | Tektronix Phaser 780P Laser Printer
Error 10186 docucolor 12
10-186 is a fuser problem.Check for jammed paper in fuser or low fuser oil.Might have bad fuser lamp or fuser thermal fuse.
Apr 23, 2008 | Xerox DocuColor 12 Color Copier
Doc 12 fuser oil leaking
It needs to have the fuser taken apart and rebuilt.
There are wicks and wiper blades that wear out.
Then they do you get excessive oil on the paper and
pretty much everywhere.
If your doing it yourself I can provide you a good and reliable vendor.
Apr 07, 2008 | Xerox DocuColor 12 Printer
Xerox DocuColor 1632 Laser Printer Logo
691 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
