Alarm #191 Battery test failed (open cell voltage)
After reset "Alarm #191 Battery test failed (open cell voltage)" Alarm appear again two days later. Please give us any information what could be reason. Same situation we found on another UPS. When I disconnected main power supply they work correctly.
Benimur
  • 6966 Answers
SOURCE: UPS problem
Based on your post/description, two (2) possibilities:
1. electronic fault - main power/AC mains sensor which could be really just a relay; or
2. corroded fuse terminals or fuse holder.
The first is a bit of a challenge since different brands/models have different sensing circuitry design. Some can be as earlier stated, a simple AC relay while others could be a TRIAC switch with a DIAC trigger. Still, some could be an elaborate AD converter and a myriad of logic circuitry. Often, a service manual or at least a schematic diagram would be needed, however these are not that readily available and most often the tech or DIYer must resort to winging it. This of course would require familiarity with electronic circuitry and components, use of a DVM and a soldering iron. Extreme caution must be exercised since even with 12VDC supply most of the electronics are at least at 60VAC+ level.
The 2nd possibility would be of course be the easiest to determine and repair. Replace/clean.
Should the downtime & repair cost makes the project no longer economically reasonable, perhaps your best bet would be to simply replace the UPS since their prices are relatively low.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 16, 2008
ghoff1
  • 167 Answers
SOURCE: Nexxtech UPS Battery shows full charge but won't stay on
had same problem! i discovered that the unit was defective,sorry if this is the case. good luck!
Posted on Feb 13, 2009
  • 12 Answers
SOURCE: Apc ups legwerkin
You can also adjust the sensitivity of your UPS so that it will accept the Generator's supply. I had to set ours to low sensitivity to get them to work. Depending on your UPS model, you can either connect to it with the supplied USB cable and run powerchute software to set the sensitivity to low, or some models allow you to adjust sensitivity on the front panel. Good Luck!
Posted on Jul 01, 2009
micromatikal
  • 2777 Answers
SOURCE: I recently purchased a used Belkin F6C800-UNV UPS,
This is normal in some lower end UPS's, the voltage can swing quite a bit, a drop of 40 seems like quite a bit but it's out of the question. It will also adapt to what is plugged in yes. Ultimately to test you would want to try it with something like an actual PC plugged in and make sure it stays running. I'd say otherwise it sounds normal to me.
Posted on Jul 10, 2009
pravinbhavsa
  • 348 Answers
SOURCE: damage to equipment from power surge
yes a spike may destroyed the mov (metal oxide variastor) inside projector replace it problem will be solved spike comes in the case of storm and lightning strike apc ups are well protected from spike and surge
Posted on Mar 05, 2010
Testimonial: "Will give it a try. Thanks!"
+#191 BATTERY OPEN CELL VOLTAGE
If it is fully charged a 12volt battery and if it's rarely new should show 13.8volts to 14V.But if the battery is fully charged the open outage will be around11.5 to 12volts again depends on how long itvwas charged previously and usage and under what load that is on connected.
Aug 12, 2014 | Computers & Internet
Pawerware 9130 alarm 191
need to change batteries.
cannot hold charge
Nov 09, 2013 | Eaton Powerware 9130 UPS Battery
Alarm #191 open cell voltage powerware 9130
Remove the front panel plastic cover where the batteries are located, then plug the two connectors together, restart the UPS, and it should be fine.
Aug 13, 2013 | Powerware Series 9 9170 UPS System
Alarm error #191 comes from a battery test, where batteries are put under load for 25 seconds. (If the alarm is unexpected, you might have enabled the periodic 30-day battery test.)
#191 is test failure for battery internal resistance. So, need to locate and replace the bad battery, then run the battery test manually. If batteries are good, make sure no battery connector is corroded or loose.
Feb 04, 2013 | Powerware Series 9 9170 UPS System
Shut down the UPS and replace the batteries.
Jan 15, 2013 | Eaton Powerware 9135 UPS (700465495) UPS...
Why won't new alternator charge battery when car is running
Many cars have a voltage regulator that is integral to the alternator. Check to be sure it is properly connected. One year later afternoon the day before the Turkey was to be cooked I replaced the Alternator. I drove 200 hundred miles and had the car die at the gate to my destination. I failed to properly connect the Voltage Regulator on the Alternator. Look in that direction for a bad wire, fuse, connector.
May 15, 2012 | 1986 Pontiac 6000
2005 Honda CR 85 R getting no spark
Hi, Brandon and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting/leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty pulse coil.
8. Faulty CKP, CMP, or BAS sensor.
9. Faulty ignition switch.
10. Faulty run/off switch
11. Tilt sensor needs a reset.
12. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2005 CR85 No fire to th espark plug
cr 85 no spark
1995 2007 CR80 CR85 2 Stroke Motorcycle Repair Manual Download Download... $15
https://www.partsfish.com/page/oem-parts-for-honda
Honda CR85 Expert Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 02, 2012 | 2005 Honda CR 85 R
What causes battery to overcharge and burn out lights
Hi Gary, you need a new voltage regulator and probably an alarm reset, for more information about your question please visit the websites below. Good luck and have nice day.
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Jan 10, 2012 | Harley Davidson Motorcycles
Tomos Revival no spark
Hi, Petersfam271 and the usual suspects are:
10. Tilt sensor needs a reset.
11. Security alarm failing to disarm needs reset
2005 Tomos revival spark issue SCOOTER PROFESSOR
GY6 Electrical Troubleshooting Tutorial No Spark Eliminator
New Tomos Service Myrons Mopeds
https www treatland tv
Tomos REVIVAL User Manual
Sep 04, 2017 | Tomos VRSCX Motorcycles
Alarm system malfunction?
Is your battery getting weak by any chance? May be time to have it load tested.Good place to start.
Dec 11, 2008 | 1997 Buick LeSabre
Computers & Internet Logo
3,197 people viewed this question
David Payne
David Payne
