Question about Dell Inspiron Computers & Internet
Dell inspiron m5030 wont boot, 7 post beeps continuously
Dell inspiron m5030 wont boot, 8 post beeps continuously
  • Dell Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove new hardware If any new HARDWARE has been recently added to the computer, remove that hardware to make sure it is not the cause of your issue. If after removing the new hardware your computer works it's likely the computer is either not compatible with the new hardware or a system setting needs to be changed to work with the new hardware device. Remove any disks or USB devices Remove any disks, CD's, DVD's that are in the computer and if any USB devices (Ipods, drives, phones, etc) are connected disconnect all of them as well. Reboot the computer and see if anything changes. Disconnect external devices. Remove everything from the back of the computer except the power cable. Turn on the computer and see if it beeps normally. If the computer has never beeped keep the monitor or display connected to see if any change occurs. Check all fans Make sure all fans are running in the computer. If a fan has failed (especially the heat sink fan for theCPU) your computer could be overheating or detecting the fan failure causing the computer not to boot. Check all cables Verify that all the cables are properly connected at that there are no loose cables by firmly pressing in each cable. All disk drives should have a data cable and power cable connected to them. Your power supply should have at least one cable going to the motherboard. Many motherboards may also have additional cables connected to them to supply power to the fans. Disconnect all expansion cards If the above recommendations still have not resolved the irregular POST, disconnect the riser board (if applicable) and each of theexpansion cards. If this resolves the issue or allows the computer to POST connect one card at a time until you determine what card is causing the issue. Disconnect all drives If you were unable to determine by the beep code what is failing or do not have a beep code disconnect theIDE, SATA ,SCSI or other data cables from the CD-ROM ,Hard Drive and Floppy Drive from the Motherboard. If this resolves your irregular POST or generates error messages re-connect each device until you determine what device or cable is causing the issue. In some situations it can also be a loose cable connection that causes the issue. Remove the RAM If you continue to to receive the same problem with all the above hardware removed, disconnect the RAM from the Motherboard and turn on the computer. If the computer has a different beep code or if your computer was not beeping and is now beeping turn off your computer and try the below suggestions. Making sure to turn off the computer each time you're adding and removing the memory and then turning the computer back on to see if the suggestion resolves the issue. Re-insert the memory into the same slot. If you have more than one stick of memory remove all but one stick of memory, try rotating through each stick. Try one stick of memory in each slot. If you're able to get the computer to boot with one or more of the sticks of memory it's likely you're dealing with some bad memory. Try to identify what stick of memory is bad and replace it. If you're able to get memory to work in one slot but not another slot. You're motherboard is defective you can either workaround the issue by running the memory in a different slot or replace the motherboard. Power cycle the computer In some situations a computer may have power related issues often caused by either the power supply or the motherboard. To help determine if this is the cause of your issue try turning the computer on, off, and back on as fast as possible, making sure the computer power light goes on and off each time. In some situations you may be able to temporarily get the computer to boot. This should only be used as a temporary workaround if you're able to get this to work. Often this is good for users who may have not done a backup and need to get the computer up one more time to copy files before starting to replace hardware. Disconnect and reconnect the CPU For users who are more comfortable working with the inside of their computer or who have built their computer one last recommendation before assuming hardware is bad is to reseat the CPU by removing it and putting it back into the computer. Bad motherboard, CPU, RAM, or power supply If after doing all of the above recommendations you continue to have the same issue unfortunately it is likely that you have badMotherboard, PSU, CPU, orRAM. The next step would be either to replace these components or have the computer serviced. If you plan on doing the repairs yourself or you are a repair shop it is suggested that you replace the Motherboard first, RAM, CPU, and then power supply in that order or try swappable parts from other computers. Hope this helps.
Posted on Jan 06, 2013
SOURCE: mouse pointer is frozen on dell inspiron m5030
Thank you the Fn and button to the right of F12 enabled my laptop mouse. Appreciate the tip.
Posted on Jan 19, 2011
  • 83 Answers
SOURCE: how do i replace the hard drive in my dell
You must remove the keyboard and palm rest to remove the hard drive also there is a hard limitation of 500gb,,,,
Posted on Feb 07, 2011
  • 72 Answers
SOURCE: 7 beep error message for
For the Dell Inspiron Mini 1012 Netbook, 7 beeps indicates bad memory (system RAM). The memory will need to be replaced.
The RAM can be replaced using a small Phillips screwdriver and removing the back-plate on the bottom of the laptop. When you see the memory (sticks around 3 inches long), pull those out and put new ones in. Make sure it's the correct DDR2 memory.
Posted on May 06, 2011
SOURCE: Hello, My function key on Dell
http://support.dell.com/support/edocs/systems/insm5030/en/sg/sg_en.pdf PAGE 30
You have to go to (winkey)- xto get to the Windows Mobility Center and in the function key row, select Function Key instead of Multimedia key. This should reverse the Fn problem.
Posted on May 18, 2011
  • 63 Answers
SOURCE: How to disable my touchpad
You can find some instructions on disabling the touchpad herehttp://www.labnol.org/software/disable-touchpad-on-laptop/14052/
and this link has a piece of freeware called TouchPad Pal which allows you to disable the touchpad while you're typing (which should be the only time it gets in the way really) http://download.cnet.com/TouchpadPal/3000-2084_4-11143760.html
Hope this helps!
Posted on May 19, 2011
What processor for dell inspiron m5030,and how to replace,the 7 beep code heard says cpu failure?
I would confirm it is faulty first. I have been in the electronics industry working with processors for years and have never come across a faulty processor!. Is the oscillator running? Has it got 3v3 supply?
If you feel the need to replace it, take the old one out and order the exact part number that is printed on the processor.
Seven beeps is usually a RAM failure.
Sep 20, 2014 | Dell Computers & Internet
M5030 won't start,just beeps 7 times.
This is a motherboard and power supply issue - you most likely cannot fix it yourself. I have attached a link where someone got their system back up temporarily, but it won't last. You need to replace the motherboard ASAP.
http://randythetechprofessor.com/how-i-fixed-the-dell-inspiron-m5030-seven-beeps-at-startup
Jun 16, 2014 | Dell Inspiron M5030 Laptop
Dell Inspiron M5030 screen won't turn on, beeps 7 times. I've replaced the device, but I desperately need files off of it (a school project, most importantly). Stupidly, I didn't back up the files. Is...
hi, Chelsea, you have to disassemble the laptop take out the hard disk drive, then use sata to usb converter to read the drive like a thumb drive,
any other question ?
Feb 12, 2014 | Dell Inspiron M5030 Laptop
Will not boot from hdd
Your PC is broken and needs repaired.
Jan 09, 2014 | Dell Inspiron M5030 Laptop
Why does my dell inspiron m5030 laptop give me a series of 5 beeps and wont boot when I try to turn it on?
Please read this:
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Jan 12, 2013 | Dell Inspiron M5030 Laptop
Dell inspiron beep codes
These are the Dell beep codes.
DELL BEEP CODES
Oct 11, 2012 | Dell Inspiron M5030 Laptop
Computers & Internet Logo
115 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
