Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi diamond hd1080
My television doesn't show a picture but the sound still works. The writing on the blank screen curves on a semicircle. The colors are also a little bit warped- like a rainbow. It happened once or twice but always fixed itself if we turned the TV off for a while. Now it is permanently stuck on the blue warped screen. Any thoughts on how I can fix this myself? Thanks Cat
    President:
  • 3,130 Answers
It sounds like you will have to replace the convergence IC's in this TV set. Not a really hard repair to do but you will need to know how to solder and work on solid state printed circuit boards. Good Luck
Posted on Jun 29, 2007
SOURCE:
Blank screen no sound,but all menu options show on
This was a common problem with this set there is a repair and a bypass posted on my website www.competition-tv.com simply click the link on the first page marked Mits bypass
Dec 17, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Picture on the mitsubishi HD1080 VS-50111
Nope, But your convergenjce chip is about to die. i would turn it off and leave it off and call a tech to rectify it before it takes out the whole board or all 3 as some capacitors are also overheating. Parts $100+Labour of about 1.5 hrs at this stage! later it will be $600
Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Mitsubishi VS-50111 50" Rear Projection...
The input function is not working and the t.v. is on but no picture. Blank screen. Was working last night just fine we tried to hook up Xbox and when the input button was pressed screen went blank. any...
Perform Reset From Front panel of Tv, wait until green light stops blinking, set is running self diagnostic. If that doesn't work, it could be something in the DMD Panel containing the Digital Micromirror Device
Oct 10, 2009 | Mitsubishi Diamond WD-65831 65" Projection...
TV turns on with sound but blank black screen
This solution from troylove solved my problem. troylove11
Rank:wizard_s.gif Wiz
Rating: 85%, 1164 votes
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Jan 07, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Blurryness
this sound to me is a convergence problem may cost to you 350$ if you want to do it by your self need to buy 2 stk 392 110 but if you dont know nothing about electronics i recomend you ta`ke the tv to a service center
Jul 27, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi HD1080 60in TV
First do a self test diagnosis. you can search Mits tv or read my solutions.
Mar 10, 2008 | Mitsubishi VS-60609 60" Rear Projection...
Looks like 3d picture
Sounds like the convergence amplifier ICs . What kind of TV and what model number and I will be better equiped to help you.
Jan 13, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Mitsubishi Diamond Series CS-27609 problem...image looks "fisheye"
2 years later and I may have a solution for you
I has a similar problem and I didn't quite fix it but made it less noticeable.
Press menu and then the code 2-3-5-7, this enters a service menu. Press Audio/Video to go between the options to get to options 40-50 to adjust geometry. Be sure to write what setting there on before you change it (even if they're wrong) just in case.
Its just trial and error from there, and hope I can still help.
Oct 27, 2007 | Mitsubishi CS-27609 27" TV
Tv picture
sounds like it could be a problem in the vertical sweep curcuit as if the vert sweep fails it blanks out the video and screen drive so the tubs dont get a line burnt into the face of the picture tube. Have this checked out by a pro as I doubt if you can do this repair unless your an electronic tech.. Good Luck
May 19, 2006 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
116 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
