Question about Audiovox Richmond 6EM30-2 30-Gallon 6-Year 4,500-Watt Medium Residential Electric Wa
I have a 40 gal Richmond water heater not sure on the model, it's was installed about 10 yrs ago. Lately the hot water is REALLY hot and the water has a brown tint to it. Does that have anything t
3 Suggested Answers
  • 154 Answers
SOURCE: I GET NO HOT WATER
needs drop tube or full replacement
Posted on Aug 01, 2009
dennymulford
  • 1055 Answers
SOURCE: I have a Richmond 40 gal gas hot water heater
your damper is stuck open and caulsing a down draft blowing the pilot out, make sure its working properly!!
Posted on Mar 31, 2010
Richmond 40 gal water heater from 2003 gurgles loudly when refilling, is that normal
I'm not sure what you mean by "gurgles when refilling." If you mean that it is making noise when heating the water, that is usually a sign that sediment has built up in the bottom of the tank. This results in the surface of the tank bottom to overheat and the sound you hear is the water flashing to steam. This usually results in tank failure as the glass lining will crack an the tank will rust out. If it's not too late you could drain and flush the tank to try to remove the sediment but if has hardened to a solid mass it won't come out.
Sep 14, 2016 | Rheem Richmond 40 Gal Nat Gas 6 Year Power...
My hot water just stopped running from hot side but cold still runs all sinks so what happen
the is a tube inside the heater that sometimes fails . and all you get is cold water call a local plumber and have them check the DIP tube
Jun 17, 2015 | Rheem Richmond 40 Gal Nat Gas 6 Year Power...
Brand new Atwood 6 gal hot water heater, stainless, has leaked at one corner since I installed about one + yrs. ago. Can it be fixed without removal?
If you can find yourself a GOOD welder in your area that has a tig welder, or a mig welder with stainless steel wire option all you would have to do is empty the tank of water. Or better yet, if possible take it out and return it, if it's really only a year old these things should be under warranty still.
Aug 13, 2010 | RTO Atwood Water Heater - 6 Gal LP
I own a 31' trailer which has an ATWOOD G6A-8E RV Water Heater, 6 Gal electronic ignition, 2 yrs ago the pressure relief valve would open up and empty the hot water tank completely, it did this several...
Most electronic ignition models only show the red light if there is a problem, (did not ignite) for one reason or another. To start with, make sure your propane is on, and you have a good flame at stove top burner, just to be sure the water heater is getting propane, and all air is bled from the line, which may cause water heater to go into check. (red light) If it does, shut switch off, and retry. Let me know what happens. As far as pressure relief opening and emptying the water heater, and your sure it's not a faulty pressure relief valve, then there's 2 things to start with checking. 1st, does the water seem extremely hot, thus a possible faulty thermostat &/or ECO . Secondly, if the incoming water pressure is too high, that will also cause it to leak bad. Try installing a pressure regulator (usually 40 psi.) at your hose connection. Let me know what you find.
May 25, 2010 | RTO Atwood Water Heater - 6 Gal LP
Richmond power vent water heater won't stay lit. I've reset the unit several times and the unit will run for about 10-15 minuets then shuts down (into lock down). Then I have to shut it off unplug it and...
I have a 40 gal richmond water heater with power vent and had a similar roblem. I call to talk to a tech and he suggested the vacuum switch. I ordered on line. It was $43 plus shipping and I installed it and it did the job. I happy.
Mar 29, 2010 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
I GET NO HOT WATER
Jul 27, 2009 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Audiovox Richmond 6EM30-2 30-Gallon 6-Year 4,500-Watt Medium Residential Electric Wa Logo
15 people viewed this question
Top Audiovox Water Heaters Experts
Paul Carew
jdthefixer
Richard Lindsey ...
Are you an Audiovox Water Heater Expert? Answer questions, earn points and help others
