Question about Dell STUDIO 1735 Motherboard - H274K
My dell 1735 turns on but does not go past the log in. Jumps back to the start up screen.
Went through diagnostics, reboot, everything I can think of and it checks good but wont go past the login.
  • Dell Master
  • 3,606 Answers
Hello here is the homepage:
http://www.dell.com/support/drivers/us/en/04/Product/studio-1735
If the F2 and F12 keys don't work, there's something wrong with the hardware. It could be as simple as a faulty keyboard or bad keyboard connection but my guess with the other problems occurring there is something more. You will need to contact Dell for in depth hardware
diagnostic
This could also be the harddrive failing.
Try visit a computer repair shop or a DELL autorized dealer/repair for detailed fault finding.
Good luck
Posted on Jan 08, 2013
2 Suggested Answers
  • 14 Answers
SOURCE: Hi, My Dell Studio 1735 Laptop
Try plugging that external monitor back in one more time. This time, with the external display attached and turned on, try pressing Function + F8. The Function key usually has blue lettering, and is located in the lower right corner of the keyboard. This toggle the active screen between the laptop's monitor and the external display. If the external monitor comes up, then the issue is most likely with the laptops monitor. If neither monitor comes up, then the issue could be with your video card. On most laptops, this will be part of the system board, and it may not be cost effective to replace.
Posted on Feb 28, 2011
Server Randomly Reboots
First, go to Dell's website and update all the firmware and install the latest version of Dell Server Administrator. DSA has logs information not logged by Windows. Next, take it outside and blast the fans with compressed air, make sure all components and cables are properly seated in their slots/sockets, turn it on with the cover off and make sure all the fans are spinning. Many servers will increase the fan speed if they detect the cover is off so this is another possible cause to the problem.
Finally, Dell servers have lifetime support, this number should work: (800) 945-3355
BTW: A temporary workaround might be to use a network controlled outlet that you can remotely turn off and on. Your UPS might be able to turn outlets on and off or you could get a stand alone network controlled outlet. Some can actually ping the device and turn power off and on again if it stops replying to pings. (E.g. IP Power EV-9255 IP http://www.newegg.com/Product/Product.aspx?Item=9SIA1470N64280)
Mar 04, 2013 | Dell PowerEdge T300 Server
I have a dell 1735 studio laptop. When I turn it on I have only a black screen. I'am able to do a diagnostic and I am getting an error code 2000-0146, but I can't get past the black screen.
Hello here is some info about your dell:
http://en.community.dell.com/support-forums/desktop/f/3514/p/19342733/19736103.aspx#19736103
Error 0146 indicates a failed/failing hard drive or bad drive sector.
Basically, this means your hard drive will need to be replaced.
Even more here:
http://search.dell.com/results.aspx?c=us&l=en&s=gen&cat=cmu&k=error+code+2000-0146&rpp=12&p=1&rf=all&nk=f&ira=False&~srd=False&ipsys=False&advsrch=False
Here is the home page:
http://www.dell.com/support/drivers/us/en/19/Product/studio-1735
A computer repair shop can help you with recover your data if is not damaged by the bad sectors.
I recomend to change the system to windows 7 (32bit) because the support for vista is out by this year.
Good luck
Nov 12, 2012 | Dell Studio 17 Laptop
Alienware aurora r3 diagnostic lock
Sounds like a complete new install of windows is in order. Sounds like you may have had a very bad virus that has messed everything up. But very well could have been something else things like this are not always the result of a virus
Aug 30, 2012 | Dell Alienware Aurora-R3 Gaming Desktop...
I dropped my dell studio 1735. The battery monitor now displays a red cross even though it does still charge. The machine boots up and runs until I start to do something. As soon as I run any application,...
Hi there! You can try to access Dell's special partition to for diagnostics so you can make sure if there is a hardware problem.
You can access it by Pressing F12 while the computer is booting up, then select boot to utility partition or diagnostics. It will give you an error after that it it founds one.
Hope this helps!
Jun 30, 2011 | Dell Studio 1735 Laptop (NU330)...
Hi, My Dell Studio 1735 Laptop doesnot display anything, i hear sounds of it getting rebooted and startedup but, wont display anything. I tried conencting to external monitor NO...
The video card most likely has failed. The computer will need to be serviced by a trained technician. The entire motherboard will need to be replaced.
Feb 28, 2011 | Dell STUDIO 1735 Motherboard - H274K
Dell 1735 won't recognize new battery
try this:
remove battery
unplug power adapter from the laptop
hold power button down for ten seconds
this will drain the laptop power completely.
place battery back in and plug power adapter back in.
Now turn your laptop back on.
let it start normally
if you using Windows XP go to start button then control panel then power options and in the power meter tab see the computer sees your battery. check to see if battery light is on.
if not then buy your battery from.
May 29, 2010 | Dell Inspiron 1300 Notebook
Vostro 200 PC freezes on Dell Start up page & won't turn on
If you have windows 7 installed, then see if you can boot to the DVD and run a repair on the OS. You also may want to run a diagnostics on the system if you can get to the F12 menu
Feb 27, 2010 | Dell Vostro 200 PC Desktop
Dell E310 Dimension that won't go on!
Boot the computer into safe mode. Run full-system anti-virus scans to ensure that the system is virus free and to remove any infections that may be present. Reboot system.
Instructions for booting into safe mode:
1) Start system
2) As system is starting, press F8 key
3) Boot menu will come up asking how you want to boot - choose Safe Mode and press ENTER
4) Your computer will start with limited services, no internet connection, etc. This will allow you to check the system and scan for viruses without interference from non-essential services.
Let us know how it turns out.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 16, 2009 | Dell Dimension E310 PC Desktop
Dell Inspiron 600M laptop screen issue
The system may not be able to refresh after the defrag. Press ctrl-alt-del and try to turn the computer off from the task manager. If task manager wont popup. You can turn the computer off by holding the power button for 10 seconds or until it turns off.
To prevent file corruption which could be caused by the improper shutdown which you will have to do. Don't forget to tap F8 repeatedly when you restart the computer. Start tapping after you push the power button to turn it on. Choose 'last known good configuration' using the arrow keys on the keyboard. Press enter. And wait until the computer reboots. It should come back to normal.
If it still locks up. Run diagnostics and check if your hard drive is still ok. Turn the computer off. Tap F12 when you turn it back on. Choose diagnostics. If you get an error for 'DSt short test' call dell, so they can give you options for replacement. If all the tests passed, your software is corrupted. Post back what happens.
Jan 02, 2009 | Dell Inspiron 600M Notebook
Dell STUDIO 1735 Motherboard - H274K Logo
56 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
