Question about Motorola Mobility MOTO W755 Cellular Phone
Speakerphone volume and earpiece volume very low. Can barely hear phone ring. All settings are maxed & I tried several ring tones. Phone worked great when I shut it off. Recently had Verizon r
See above in problem area.
  • Official Brand Answer
  • 1,623 Answers
Casecraig.
Take it to Verizon to have it looked at.
Mark
Motorola Support
Posted on Jan 23, 2015
SOURCE: can't hear caller
I expierenced the same problem with my V265 phone. First, note that performing this repair as I did will most likely void any warranties on the phone, and also is an electrical shock hazard. This repair should only be performed if the person/s performing the repair understand these risks and have at least basic technical knowledge in circuits, electricity, and audio. I take NO RESPONSIBILITY for damage or injury in any way, shape, or form. Please to prevent errors or any more damage, read directions fully before starting this repair. - Remove the Battery and make sure no chargers, headsets, etc., are currently plugged into phone. - Remove the housing on the phone which is on the same side of the camera and the external display by gently and carefully prying, making sure not to break the latches or any of the external parts. - Using a Torx bit (I believe it was either a T15 or T20 I used but not sure) or a small flat head screwdriver, remove the 4 screws holding down the board. - Now examine the speaker located at the earpiece of the phone and the two contacts which are on the board you just removed. Look to see if they were properly alligned and if contact is being made between the speaker and the board. (a PINK pencil eraser works great as a cleaner for circuit board contact points) - If contact is being mad and no obvious obstruction is found to prevent contact with the two, the easiest way for me was to take a speaker from another phone, and using it in place of the old one. (If you are willing to use extra time, you could also try finding an actual replacement from a manufacturer.) - I used a speaker from a motorola phone which was actually a few years older than my V265. - After finding a replacement speaker, you'll need to use some trial and error to properly allign it with the contacts on the board and to make it stay in position during everyday use. - For my V265, I had to use a razor and shave away the plastic molding which held the old speaker in place. Then use a VERY small amount of super glue to hold the speaker in position. Then I used a little bit of hot glue to give it some flexible strength. All together, it took me about 1 hour to complete this task and start using my phone again normally. - If any additional assistance is needed, feel free to e-mail at spike8551@comcast.net leaving your name and prefirably a phone number and best time to call, as a return contact. This will make it easier for me to help the best I can. Thank you and good luck.
Posted on Dec 21, 2006
joshy999
  • 241 Answers
SOURCE: CAN'T HEAR RING TONES ON MY RAZR V3I CELL PHONE
Your outter speaker is damaged - you got to love ebay!
Contact your seller and request a replacement or refund because it will cost you upto $50 to fix it
Posted on Jan 23, 2008
deepakonly
  • 87 Answers
SOURCE: volume low
there is problem with ur speaker which make sound. it need to be replaced take it to technician so it can be replaced
Posted on Feb 25, 2008
Bajanguru
  • 7752 Answers
SOURCE: cannot hear incoming calls unless on speakerphone
take the phone to a mobile service center and have them replaced the mobiles' ear piece.
Posted on Mar 21, 2008
nasirahmed
  • 282 Answers
SOURCE: incoming call
Seems your ear speaker has a problem. It need to be changed.
Posted on May 27, 2008
Elderly friend can't hear his phone ring even though the volume is set at Max Volume
Putting the phone on Outdoor may help or when someone rings before you answer, use the Up Key. Cheers..
Mar 28, 2013 | Samsung Rugby SGH-a837 Cell Phone
Volume at phone speaker very weak
Casecraig
Speakerphone volume and earpiece volume very low Can barely hear phone...
Mark
Motorola Support
Jan 04, 2013 | Motorola Mobility MOTO W755 Cellular Phone
How do I make the phone ring/ Also how do I delete number's/
Activating Personal Ring
You can assign special ringer tones to anyone in your phonebook. When your phone gets a call, it looks up the Caller ID information in your phonebook. If you've assigned a personal ringer to that number, the phone uses it so you know who is calling. To turn the personal ringing on or off, follow these steps:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the PERSONAL RING submenu.
  2. Move the cursor to select ON or OFF.
  3. Press [Menu/Select]. You will hear a confirmation tone.
Selecting a Ring Tone (Handset only)
You may choose from four melodies or three tones for your phone's primary ring tone. Each handset can use a different ring tone or melody. The available ring tones are as listed:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the RINGER TONES submenu.
  2. Move the cursor to select a ring tone. As each ring tone is highlighted, you will hear a sample.
  3. When you hear the tone you want to use, press [Menu/Select]. You will hear a confirmation tone.
Adjusting the Speaker Volume
Handset Speakerphone: You can choose from six volume levels for the handset speakerphone. To adjust the speaker volume while on a speakerphone call, press the UP Arrow button (to make it louder) or the Down Arrow button (to make it softer).
Base Speaker: You can choose from ten volume levels for the base speaker. To adjust the speaker volume while call screening or playing messages, press [volume +] (to make it louder) or [volume -] (to make it softer).
Adjusting the Audio Tone
If you aren't satisfied with the audio quality of your phone, you can adjust the Audio Tone of the earpiece while on a call. Your phone gives you three audio tone options: low, natural and high; the default setting, Natural Tone, is recommended for hearing aid users. Audio tone adjustments only apply to the earpiece, not the speakerphone.
To adjust the audio tone:
  1. While on a call, press [Menu/Select].
  2. Move the cursor to select AUDIO TONE, and then press [Menu/Select].
  3. Move the cursor to select desired option (HIGH TONE, NATURAL TONE, or LOW TONE), and then press [Menu/Select]. Selected option appears in the display for two seconds, and then the display returns to normal.
Deleting Phonebook Entries
You can delete a single phonebook entry at a time or all phonebook entries at once:
To delete a single phonebook entry:
  1. When the phone is in standby, press the phonebook key.
  2. Find the entry that you want to delete and press [Menu/Select].
  3. Select DELETE. DELETE ENTRY? appears in the display.
  4. Move the cursor to select YES.
  5. Press [Menu/Select]. You will hear a confirmation tone, and DELETED! appears in the display.
Deleting Caller ID Numbers
  1. To delete only one Caller ID number, press the Caller ID button when the phone is in standby, and then find the number you want to delete.
  2. Press [Menu/Select] and select DELETE ENTRY.
  3. When the phone asks you to confirm, select YES.
  1. To delete all the Caller ID numbers, press the Caller ID button when the phone is in standby, and then press [Menu/Select].
  2. When the phone asks you to confirm, select YES.
Note: When you delete a Caller ID number, you delete it permanently.
Deleting a Redial Record
If you want to delete a phone number from the handset's redial list, follow the steps below:
  1. When the phone is in standby, press [Redial/Pause].
  2. Use the UP Arrow button and the Down Arrow button to scroll through the redial list.
  3. When you find the redial number you want to delete, press [Menu/Select] and select DELETE ENTRY.
  4. When the phone asks you to confirm, select YES. The redial number is deleted.
Resetting the Voice Message Waiting Indicator
  1. When you receive a new voice mail message, the new message LED on the top of the handset flashes and VM appears in the handset display.
  2. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state.
  3. To reset, press and hold [find hs] on the base for five seconds.
  4. A beep sounds and the message alert tone is reset.
Mar 22, 2011 | Uniden DECT 2080-5 Quint Phone
Ringer is set at max but is hard to hear
If the ringout volume is very low, then try not to select a soft, silent or low ringing tone. Try to choose a ringing tone that is loud so that you can hear your phone ringout.
Hope that was helpful?
Mar 18, 2011 | One Touch Jitterbug One-Touch Cellular...
When I call people, they can't hear me. What is wrong with my phone?
Your mouthpiece or receiver's earpiece might be not functional. To make sure, please record something and try playing it. If you can hear what you recorded, your mouthpiece is fully functional. Tell the receiver to increase the earpiece volume.Now test whether the receiver earpiece is not working. Tell the receiver to set his phone is speakerphone mode. If he can hear what you say in speakerphone mode, then the receiver's earpiece is not fully functional.
Hope this helps.
Mar 04, 2011 | HTC Wildfire Cell Phone
To increases volume
first of all u can increase volume during call by pressing right button (middle one). but i think ur phone is set to max and u dont hear much - in this case probably some "metal dust" sticks on your speakers membrane - open case clean speaker gently or replace with new one...
Feb 07, 2011 | Nokia 1600 Cellular Phone
Cant hear people when they call
Yes you are very correct. Its a earpiece problem. I use to have a Sony Ericsson K750i and the earpiece is not loud at all, so when I changed the earpiece, it began to work perfectly again. So I'll support or advice that you change the earpiece.
Take care.
Nov 19, 2009 | Sony Ericsson Walkman® W995 Cell Phone
Can barely hear sound even though volume is max
thebuzzer of your phone is defected, replace itand replace also the earpiece
Apr 09, 2009 | Samsung Eternity Cell Phone
Motorola Mobility MOTO W755 Cellular Phone Logo
90 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
