Question about Jl Audio 500/1 Car Audio Amplifier
Kickers dont beat like they should
Ive had my 2 10" kicker comp vr c10d subs now for about 6 months, since then i also got a 10" blau, and a 10" mtx thunder series, i had all but one kicker hooked up in my car, then i got a ported box for 2 10" subs, i put the box in, and i put both kickers in. so now i have all of my subs in my car. an i have 1000 watts powering it all. it worked great for a few hours. then one of the kickers started to crackle, so i unplugged it, from the amp. then the amp on the oor speakers starte to cut in and out. i went back to the trunk to look at it, and it stopped. so i looked at the wires on the amp an saw that a couple of wires were crossing so i cut some of the wire off and plugged it back in, then both of the amps started cutting in and out, but after they stopped the bass doesnt hit like it should, it doesnt thump, it doesnt punch, ive spent a lot of money on this system, and i want it to work. please help ASAP
thanks
  • 32 Answers
Try to check and clean the wiring as clean as possible to avoid messing up on your connection. Check the polarity of you subs to yuor amp if you have it connected on the outher way around it would not give you a good result. check the polarity this will solve your problem. Over powering your sub will fry it easily try to tune it a 10" sub wont give you a 15" performance..
Posted on Jan 21, 2009
I have 2 different subs in one box, a 12" MTX thunder and a 12" Kicker CVR. the kicker is a dual voice coil while the MTX I dont believe is. Can I use one amp for this set up? And how would it be wired?
im guessing both speakers are 4 ohms ..mtx 4ohms and kicker dual 4ohms..now if your amp can go down to 1 ohm wiring the kicker dual coils in parallel (2ohms) and the mtx connected together (4ohms) should leave you with a final impedance between 1 and 2 ohms ...i suggest you use one or get another
Oct 08, 2013 | MTX Car Audio & Video
Kicker comp 12'' subwoofer swingarms snapped
when you say swing arms i assume you are talking about the wires connecting the terminal (where you connect the wires to the sub) to the voice coil (the center of the sub).
If these are broken it is tricky to solder new wires back on. If your sub is still under warranty i would suggest sending it back to them. below is there number and business hours.
Kicker Customer service Email: Warranty@kicker.com Phone: $05-624-8510
Aug 23, 2012 | Kicker Car Audio & Video
What is a good price for two kicker comp vr dual voice coils?? How many watt does each one have??
2 10" Kicker Comp VR's will run you about $150.00 each new from most dealers a good price for 1 10" should be anywhere from $130 - 160 no more and never less.
$160 -$190 for 1 12 " CompVr
Jun 17, 2010 | Kicker Comp VR Car Subwoofer
Dont know how should the wires be wired on the sub
You have polarity problems there. Try swapping the wires and see if the cones goes up or down... You got the right polarity if the speaker produces sounds when you connect it to your subs.
^_^
Jun 07, 2010 | Kicker 01C8VR4 Car Subwoofer
How do i wire a 8 ohm kicker comp 10" sub inside the box? and what is the best way to get more bump with a 600 w mtx amp and kicker comp 10" sub?
Ok, for an 8 Ohm sub, it is advisable to get another 8 Ohm sub. wire them in parallel down to a 4 Ohm load. You would wire both + wires together, and both - wires together to yield a 4 Ohm load at the amp. Majority of the amplifiers on the market are designed to give more power at a lower impedence, or Ohm load. You just have to make sure that your amp will take a 4 Ohm load. Without knowing the model of the MTX amp, I can't give more advise. However, this should be able to give you and idea of where to start. The main problem is that you have a single 8 Ohm sub in the Kicker Comp.
Apr 30, 2010 | Kicker CompVX CVX104 Subwoofer - 10" Dual...
Subs dont beat like they should
you've spent alot of money on **** by the sounds of it!!. you should only ever run multiple subs the same brand, power and resistance you can just connect any old subs to a system you need to wire them depending on the load that the amp needs to see. first thing is to try the amp/s on a individual sub to check your amps still work once done check the subs 1 by 1.
Jan 20, 2009 | Jl Audio 500/1 Car Audio Amplifier
Price check
that is 2 12 hitting 150 db you got to know what you are doing
Sep 14, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Jl Audio 500/1 Car Audio Amplifier Logo
139 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
