Question about Asrock K8Upgrade-VM800 Motherboard
Keeps beeping even with memory
Hi guyz... after fixing the previous problem, my computer doesnt open, now it keeps beeping... (T_T)
    Problem Solver:
  • 19 Answers
Is the memory ok? is the grapihic's card ok? take out the memory and graphics card clean the contacts with a cottonete and instal it again
Posted on Jul 02, 2007
6ya staff
SOURCE:
IBM Thinkpad R31 1.13GHz Keeps beeping a steady beep when i first turn it on
Step 1:
The memory of your computer was cannot support the system that you load. Just upgrade the memory or else replace of higher memory.
Step 2:
Just load operating system that your used previously. Because that was the compatible system that they used.
Apr 05, 2013 | IBM ThinkPad R31 2657 Notebook
What does two beeps on a dell Inspiron 530S mean and how do you get it out of power saving mode?
Power off. Wait a full minute. Discharge static from your hands by touching exposed metal part of chassis (case). Open your case and re seat memory chips.
Jul 07, 2012 | Dell Inspiron 530 Desktop Computer
I have a dell 580 inspiron thats does not turn on..before it turned on but now it just beeps and doesnt follow through with start up.......i had a blue screeen before this ....thanxx
Blue screen could be the windows files getting corrupted due to a virus, file fragmentation or a failing hard drive, overheating cpu or failing memory.
The beeping usually indicates a hardware failure, first open the computer and see it the CPU heatsink is in place properly seated and fan is connected and spinning.
Second with the PC off, remove and reinsert the memory.
These are just a few things to check , most likely the hard drive has failed and needs replacing.
pressing certain keys during bootup can sometimes isolate the issue, but only if the monitor still shows a picture
I hope this helps
Thanks
Roety
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 23, 2011 | Dell Inspiron 580 Desktop Computer (Intel...
My Computer Beeping when star-up. The Beeping sound is continue such as Beep...Bee...Beep...Beep..until I force it by pressing the start up button to stop it total. I think due to the new mouse and...
Beeps always indicate error excluding a one single beep only which indicate process.Every manufacturer has its own beep setting. it comprises on short and long beeps. If previously it working good, then your idea may be correct. replace both the keyboard and mouse with existing. start computer if now it not giving beeps it meant that one of them is causing problem. connect one by one and start computer you will reach. AND if even after replacing keyboard and mouse it gave beeps then shut down your system. Open casing remove processor and memory chip out and connect them again it will work now INSHALLAH.
Sep 24, 2010 | Computers & Internet
Long beep problem when I turned on my computer
Not the right category for computer but a beeping computer on switch on usually means the memory module is not present or not working.
A continuing beep beep beep memory missing.
One long continues beep that stops and the computer then works could be anything normally the PC is looking for something can’t fined it and moves on.
If you are concerned restore the system to a previous time i.e., prior to the beep starting to happen.
Sep 13, 2010 | Home
Beep..beep..beep..(Three times)
check the new memory in all memory slot that u have. use thinner with a art paint brush just past it in the memory slots, just like cleaning them up. then place the memory about some seconds. switch it on. if doesnt work see your graphic card. or try a kingston memory. kingston memory works on almost all motherboard. some others even new, they dont work on some motherboard.
Aug 10, 2009 | Computers & Internet
Two loud beeps when turning on the laptop
No, you probably don't have the memory seated correctly. Carefully open the memory bay, remove the memory being sure that when you reseat it you make sure good contact is made before locking it in the slot.
Jul 15, 2009 | HP Pavilion ze2315 (EC201UAR) PC Notebook
Gateway 838gm
Does the computer beep when you turn it on? If so, count the beeps and google it. Something like "computer beep 3 times at post" or similar.
If it does not beep, remove all buy one of your memory chips. (mind your static charge, keep in touch with your computer case so you don't fry your mobo or memory) Will the system post with only one chip? If not, try all of your memory chips one at a time. Post now? If so, you can narrow down the issue.
If this doesn't work, remove all of the cards. (video, sound, network, etc) Turn the computer back on. If it still does not beep, it is very likely that the CPU is the culprit, with a slight left field chance of it being the power supply.
Jan 17, 2009 | Gateway 838GM (RB838GM) PC Desktop
IBM xseries 205, Model 8480-43X Memory upgrade an POST BEEP
Those beeps mean that your RAM is not functioning. Are you sure you got the right upgrade type. Sometimes it'll fit into socket but won't work because of speed. Or just try reseating the modules.
Jan 14, 2009 | IBM eserver xSeries 205 8480
Jetway p4mdpt with an error beep
Hello!
Probably one or more RAM modules has gone bad.
I suggest you leave just one memory module in your motherboard and see if it boots,
if it does not try changing the memory modules and try putting it in different socets too.
If you have only 1 memory module I suggest you leand one from a friend, just make sure its a correct type of memory, your motherboard uses DDR type memory don't try to put DDR II memory in there
Hope this helps!
Oct 02, 2008 | Computers & Internet
Open Questions:
See all Asrock K8Upgrade-VM800 Motherboard Questions
Asrock K8Upgrade-VM800 Motherboard Logo
60 people viewed this question
Top Asrock Computers & Internet Experts
Ekse
Thomas F. Schneider
Joe Negus
Joe Negus
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
