Sony vaio vgn cs 12gh b at start up there is a beep beep sound, pretty loud, and when the password box comes it's automatically filling wwwwwwwwww endlessly. when it's finally open there is this sound. if i open ms word this wwwwww repeats until i press another key. i keep my lap extremely clean. checked under w key taking it off. help
  • 27,725 Answers
Clear the saved passwords
Sony VAIO Care, an application pre-installed on most Sony laptops, is designed to automatically check for computer updates and to assist you with troubleshooting and maintenance. The application is configured to start as soon as the computer powers on. Although Sony VAIO Care is helpful, it is not necessary for it to launch automatically, as having too many programs launch at startup can cause your computer to run slowly. You can disable VAIO Care so it does not run at startup.
Click on "Start," then click "All Programs." Click on the "Accessories" folder. Click on the "System Tools" folder and click "Task Scheduler." Type your Administrator password, if asked for one, and click "Continue." The Task Scheduler window appears. Click on "Task Scheduler Library" in the left pane. Click on "VAIO Care." Click "Disable" under the "Actions" heading on the right side of the window. Close the window. When you next start the computer, VAIO Care will not automatically run
Hope this helps.
Posted on Jan 06, 2013
4 Suggested Answers
SOURCE: FN keys don't work on Sony VAIO VGN-SZ18GP
The solution is as follows, which worked for me:
- Install Windows 7
- let it update all the drivers that it needs to
- Install additional Sony drivers that you need (XP drivers work just fine, but make sure to install them in Administrator mode, so, Run as Administrator), such as camera, fingerprint scanner, etc
- Install the Notebook Control Device Driver (without this the other software does nothing)
- Sony Utilities DLL
- Sony Shared Library
* restart computer *
- Sony Video Shared Library
- SUS (Setting Utility Series)
- VES (VAIO Event Service)
After this one the Fn keys will start to work. The S1 and S2 keys don't work due to something to do with UAC (but I don't need them anyway)
- VAIO Control Centre (will allow you to change what the S1 and S2 keys do, even though you can't use them :) )
That's it and it worked for me.
Posted on Apr 27, 2009
  • 1149 Answers
SOURCE: Sony Vaio fan making noise
Hi:
Not sure of a user cause for the fan to run full speed, unless you are using the laptop in a high heat environment, or setting it on a bed or other area where it is not getting adequet cooling air. If it does it right away, when you turn it on , cold, then there might be a laptop hardware problem. If you leave your laptop on all the time, then you might be inducing the problem. I had a HP high performance laptop, that the fans would not turn on at all till it ran an hour or so, then they would stay on loud for 10 or 15 minutes, then shut off, then cycle.
Posted on Nov 10, 2009
cirocpatel
  • 524 Answers
SOURCE: DIP SWITCH BIOS RESET POSITIONS SONY VAIO VGN-fs660
There are 2 ways you can reset your bios2_bing.gif.
1. On the motherboard there is a small watch battery. Remove this battery along with the power cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery and plug in2_bing.gif your system. Your reset is now complete
2. Some motherboards have a 3 pin jumper by the battery. Lets say that the jumper is on pins 2 and 3. Remove the jumper while the machine is OFF and place onto pins 1 and 2. Power on your machine for a minute. (Note: Your system will not POST). Shutdown your machine and put the jumper back to pins 2 and 3. Your reset is now complete
This is a great troubleshooting2_bing.gif step for those of you having POST issues or no POSTing at all. Like other troubleshooting steps, this will not always work but usually will depending on the problem.
Please let me know if you have any further questions or concerns.
Thanks.
Posted on May 05, 2010
Sony VAIO VGN-CS110E won't boot
yes it is the problem you need remplace the mothersboard because lucks like your motherboard is damage
Nov 25, 2011 | Sony VAIO VGN-CS110E/Q PC Notebook
How can I reset my vaio vgn-cs220j to factory settings?
Most of Sony VAIO models, holding alt + F10 at boot will start the factory restore process.
Rate how this helped you. =)
May 27, 2011 | Sony VAIO CS VGN-CS220J/T Notebook
My Vaio VGN CR120E laptop has been beeping quite obnoxiously every time I start it up for awhile now, and has also started doing it every now and then while I'm using it. The beeps last about 1-2 seconds...
in 99% of cases its detected bad ram connection take out all the ram cards clean the copper pins with a hot damp rung out rag and re insert ram should fix it
Nov 27, 2010 | Sony VAIO® VGN-CR120E PC Notebook
Hello i have an sony vaio VGN CS14G/B series laptop and i locked my bios .afterall i fogot my bios password .now i am un able to get into bios .so pls help me ......pls
To reset the BIOS password read the information from this link.
In case of your Sony VAIO laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
Oct 16, 2010 | Sony VAIO CS VGN-CS220J/T Notebook
Fan of VAIO CS-118E makes loud sounds
That is definitely a problem from the fan. What you can do is to call sony and check if they still cover Fan replacement for this specific mode.
Oct 15, 2009 | Sony VAIO VGN-CS118E/P NoteBook
Turns off automatically
check your cooling fan sounds like its getting too hot
Oct 03, 2009 | Sony VAIO VGN-CS220J/W Notebook
Vaio care stop working
Problem for Sony VAIO CS Series VGN-CS118E/P NoteBook Intel Core 2 Duo... Vaio care stop working
May 01, 2009 | Sony VAIO VGN-CS118E/P NoteBook
Hp computer will start, all the lights come on but the screen is black.. also.. it makes this loud beeping noise 4 times?? whats wrong?
The beep is more than likely a beep code (sounds stupid and obvious, but they're there for a reason).
What make/model is your machine? We can look up the code by make/model. That will diagnose your problem.
May 16, 2008 | Sony VAIO VGN-N250E/B Notebook
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
