Question about Acer Veriton M670G Desktop
An alarm goes off when it is switched on
The pc is connected to a UPS, and the moment the PC poweswitch is switched on, a highpitched alarm stays on. the PC doesnt boot up, it just stays like that,.
  • Acer Master
  • 7,627 Answers
The UPS battery is ,most likely, dead or dying. Replace battery or remove the battery and use the surge protector side of the UPS. It's often less expensive to buy a new UPS, the batteries are almost as much as the new UPS.
Posted on Jan 06, 2013
Constant alarm but works fine otherwise
Jordan,
It probably burned up one of the capacitors on the board that signal the UPS to turn the alarm off. I've had this happen before and I unplugged everything, turned the UPS off, disconnected the batteries and then opened the UPS up to cut off the tiny, annoying, surprisingly loud speaker. I then put everything back together and that was the end of it :)
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
Feb 02, 2013 | Opti -UPS PowerES 1000 UPS System
GE LP33 UPS inverter failed to start
Dear Yared,
Did you try to give the UPS some time to recharge the batteries?
Seems like the batteries have reached their cut-off voltage and are not supplying enough voltage to the inverter.
Normally the dc boos circuit of the UPS will supply voltage to the DC BUS so maybe the problem can be found in the dc boost circuit or BUS if recharging the batteries is not helping.
Let me know.
Best Regards,
Ron
Jan 22, 2013 | MGE Computers & Internet
It worked yesterday perfectly well. But today, i just switched on the UPS, then switched on the monitor and the UPS went off but the PC is still on. I then disconnected the Monitor, Now the UPS is on but...
Seems that the UPS has failed and so cut off power to the monitor. So please check your connection once again. The PC and the monitor must be given to the UPS and if the PC stays ON then the monitor must get power. So connect them to direct power to confirm if there is a fault, if so the power supply section would have failed.
now check on the UPS , check the battery on the UPS, is low it can disconnect. If so replace. Other wise the driver MOSFETS could have failed or a possible fault in the mother board.
Jul 29, 2011 | Acer AL1717 17" LCD Monitor
HOW DO I MAKE THE ALARM SOUND STOP??? I HAVE THE ULTRA BATTERY BACKUP IN MY 911 CENTER AND THE COMPUTER ROOM DOES NOT HAVE ANOTHER AVAILABLE AT THE MOMENT, BUT THE ALARMS IT IS TRANSMITTING ARE INTERFERING...
From the User Manual:
When the UPS is in "Backup" mode, press the power switch for less than 1 second to silence the audible alarm.
(This function is disabled when the UPS is under condition of "LOW BATTERY" or "OVERLOAD".
Hope this helps.
Jul 19, 2010 | Ultra (ULT31502) UPS System
How to charge ups for pc's
Your PC connection must always come via UPS, and your UPS will always keep charging.
UPS Power cable should be connected to DC, and your PC power cable should be connected to UPS.
And this way your PC will always be safe.
Nov 06, 2009 | QVS NetStar (UPS650A) UPS System
My PC is connected to UPS.Whenever I switch on my UPSthe PC start
On the mother board at the front are 2 rows of pins to which wires are attached, going to switch(power) and the manual reset and the LED's. Usually the first 2 sets of wires--pairs of Green&White and red/black&white are for power and reset. Once u pull out the jumper-like attachments u will be able to see whats written on them. Isolate the power & reset wires. Remove them fron the pins on the motherboard. Switch on ur UPS and by simply shorting 2 pins, starts the PC. Now that u have identified the power pins, put them back after cleaning the dust,etc. If the PC behaves as before but works perfectly when the power switch connections are opened & PC works normally after just touching the 2 oins, then the switch need to be replaced......sodeep
Mar 31, 2009 | Intel D915GLVG Motherboard
Monitor flicks off
If you have switched monitors and the problem persists, I would first look at your cabling, if you did not use the same cable on both monitors then the drivers would be suspect. Go to your video cards site and update the drivers after checking all your cables and connections, also check that the video card is properly seated on the motherboard (if its not integrated onto the motherboard). An easy way to check the monitors, is to plug them into another computer (EG: laptop) and they should have the same problem there, i doubt they will from the symptoms you are having. also try bypassing the UPS and plug the monitor straight into an extension cord or wall.
Remeber, try this in steps, not all at once, so you can tell what works..
Hope this Helps!
Oct 07, 2008 | E-Machines eMachines Desktop PC
UPS constantly sounding an alarm tone
http://www.apcc.com/resource/include/techspec_index.cfm?base_sku=SUA1500&tab=documentation Above is the site for your operators manual and troubleshooting guide. Not knowing how load the sound is makes it hard to tell you what to do. You may have a damaged UPS.
Jan 15, 2007 | APC Smart-UPS UPS System
Acer Veriton M670G Desktop  Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
