Question about Jerdon Deluxe Lighted Makeup Mirror JGL9W
Lights flicker but don't come on
The screen flickers and darkens while watching the TV. It is a 3 month old Bush DLED32165HD. Adjusting contrast/brightness/sharpness makes no difference. Turning off the TV and turning it on again, th
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jan 14, 2015 | Bush Televison & Video
I have a 2004 5 speed Saturn ion redline with a 2.0 L engine. I've had a new starter & a tune up. At first my car wouldn't start sometimes so I thought maybe it was the passlock system because...
Disconnecting the battery cable while the vehicle is running is a no no ! The electronic's on your vehicle , you can cause some serious problem's doing that . That was ok on 1960 era vehicles , from 1970 on with all the transistors in the electronic control modules ,you don't want to do that . You may have caused your problem yourself ! http://www.troubleshooters.com/dont_disconnect_battery.htm .Take your vehicle to a qualified repair shop .
Mar 13, 2017 | Cars & Trucks
Abs and traction control dash lites come on and off at various time..sometimes never come on
Your abs and traction control lights should only come on when you start to slide while breaking(ABS), and when your wheels spin in place when excelerating(TC). If those 2 things don't happen, which with some people they never do, you should never see the lights come on. Only when those mechanisms are in use do the lights come on. And they will always flicker as that is what abs and tc are, intermitant surges to break up the constant. ABS does this for obvious reasons...anti lock break, so when you slide, the abs "taps" the breaks in short bursts so they don't lock up. TC "taps" the exclelrator when it slips. Those "taps" are what trigger the lights on your dash, which is why they flicker and don't stay on.
Sep 26, 2012 | Cars & Trucks
Lights flicker on 2005 Cobalt
http://www.autozone.com/autozone/repairinfo/repairguide/repairGuideContent.jsp?pageId=0996b43f80cb1732You have fusible links tied into positive battery cable,they could be burnt or meled and not giving enough current so it is flickering,check all wiring leaving positive battery cable and all fuses in fuse box in side Cobalt.Here's a electrical diagram of a 2006 colbalt,for some reason,the 2005 is not listed,but you will see the fusible link.Click on link.
Sep 06, 2012 | 2005 Chevrolet Cobalt
Lights flickering ON 1994 CHEVY K1500. Just hooked an amplifier up and headlights are flickering @ night. The amp is not powerful @ all so I didnt think i needed a capacitor
If you're running it to the battery post directly its creating a strain-you'll need a power distribution block. Also consider a bigger body ground wire/cable. If this doesn't help, you will need a capacitor.
Aug 26, 2011 | Chevrolet 1500 Cars & Trucks
Battery replaced and now A/C vents front blowers don't work, only floor blowers work. Lights dim, battery gauge flickers down when truck is idle. Check engine light comes on steady, then goes off...
The exact same thing happened to me... my lights don't flicker but my A/C is having the same exact issues.... if you find out what happened please let me know as well.
Jul 18, 2011 | 2006 GMC Envoy
I recieved a brand new Canon Rebel XSi in the mail. I throughly read the manual & assembled it carefully by the book. Kept it in all the correct settings. Also kept it in a warm, dry area. I grabbed...
Hi
You can try doing the steps below
1. Remove the battery from the camera
2. Remove the Memory chip
3. leave the camera for an Hour
4. After which you can install the battery only first
5. Recharge the camera first
6. Later when the camera is charged the battery
7. Install the chip if available
HOPE THIS WILL SOLVE THE PROBLEM
RATE MY SOLUTION
Jul 02, 2011 | Canon EOS Rebel XSi Digital Camera
Jerdon Deluxe Lighted Makeup Mirror JGL9W Logo
63 people viewed this question
Top Jerdon Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Jerdon Health and Beauty Expert? Answer questions, earn points and help others
