Question about Lionel 6-24137 Mr. Spiff and Puddles Accessory O 027
Where can I find a replacement motor for Lionel 6-24137 Mr. Spiff and Puddles accessory
  • 161 Answers
Here is a link to contact Lionel Parts & Services:http://www.lionel.com/ContactUs/
They'll be able to supply you with a motor.
Posted on Jan 31, 2013
Coupler will not stay closed on tender this was new out of the box
Contact Lionel Customer Service for a repair/replacement or take the tender to a Lionel Service station.
Jan 27, 2016 | Crafts & Hobbies
How do I connect the Lionel #76 warning bell & shack?
Lionel#76 accessory is a pre-war item, so instructions for it are scarce. I suggest you read pages 12 - 26 of the attached pdf and hook up the #76 following the directions for one of the automatic signals.
http://www.slsprr.net/history/1954LionelTrainsAccess.pdf
Oct 15, 2014 | Crafts & Hobbies
Where can I find an owners manual for the Lionel 145 gate man
See page 12 of attachment, How to Operate Lionel Train & Accessories, 1954 - 1955.
Sep 30, 2014 | Crafts & Hobbies
How to replace the front light on a lione santa fe train engine
From the Lionel User Guide for this engine.
it forward to release the two rear clips from the frame slots.
2. To remove the lamp, gently push the lamp down and turn counter clockwise to disengage
the lamp from the socket. Refer to Figure 6.
3. Replace the expired lamp with Lionel part no. 600-0363-300, available from your local
Lionel Authorized Service Center or Lionel Service. (For more information, see Lionel
Service on page 12.)
4. To reinstall the shell, first insert the rear tabs on the body into the slots on the frame. Line
up the screw holes on the frame and body shell, and reinsert the screw. Make sure all of the wires are inside the body before you tighten the screw.
This is a 14V bulb
This
Mar 14, 2014 | Lionel Santa Fe Diesel Locomotive Engine...
New polar express motor wont engage
It sounds like the gears have worn out or come adrift somehow. You will be able to get replacement gears from any of the Lionel authorised dealers Lionel Authorized Dealers or their replacement parts service Replacement Parts
Dec 28, 2013 | Lionel The Polar Express Train Set
My 1941 Lionel train stops getting enough power to run all the way around the track. Voltmeter says 15 volts around all track and transformer says 15 volts. How do I test engine?
If your sure the loco contacts/wheels are clean and the track is ok then remove the loco bodywork and check the motor. You can apply a 12v supply directly to the motor contacts to test if it's running ok. If it does run ok then suspect and clean the brushes and associated connections. If it does not run try moving the motor armature manually. If it is stuck it is probably time to replace it. If it moves apply a light machine oil and test again.
Dec 16, 2013 | Lionel Trains Classic Freight Train Set
Parts to fix train with failed component
You've done the right thing by talking with Lionel. Their techs should be able to guide you trough trouble shooting as it seems that you have some knowledge of electronics.
Mar 06, 2017 | Lionel The Polar Express Train Set
Holiday Tradition Express, engine tender not working. Contacted Lionel Trains, they have no replacement parts or service available.
Best bet is to search the internet for Lionel replacement parts. Try to include as much information in your search.
Dec 03, 2012 | Lionel 11000 Holiday Tradition Express...
Can I use the cw-80 transformer on any Lionel train set from year 1948 to the preasant , thanks George
You should be able to. The Lionel transformers all put out AC power, not DC and many Marx and American Flyer transformers will work too. The real question is total amount of power being drawn and whether or not you have the wattage to match your engine and accessories. With the CW-80 though, it should put out plenty. I run my pre-war 1666E engine pulling a full compliment of metal cars with no problems using a CW-80.
Feb 05, 2011 | Lionel Cw 80 Transformer
Lionel Polar Express Berkshire Locomotive will only go in reverse
No doubt the transistor in the motor controller inside the engine is shorted TIP31C Q6 If you have the skills you can repair the unit. Parts are cheap, like 50 cents. Expense is shipping. Have repaired at least one that had the probblem you describe
good luck
Dec 08, 2009 | Lionel The Polar Express Train Set
Lionel 6-24137 Mr. Spiff and Puddles Accessory O 027 Logo
101 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
