Question about Jl Audio 500/1 Car Audio Amplifier
Subs dont beat like they should
Ive had my 2 10" kicker comp vr c10d subs now for about 6 months, since then i also got a 10" blau, and a 10" mtx thunder series, i had all but one kicker hooked up in my car, then i got a ported box for 2 10" subs, i put the box in, and i put both kickers in. so now i have all of my subs in my car. an i have 1000 watts powering it all. it worked great for a few hours. then one of the kickers started to crackle, so i unplugged it, from the amp. then the amp on the oor speakers starte to cut in and out. i went back to the trunk to look at it, and it stopped. so i looked at the wires on the amp an saw that a couple of wires were crossing so i cut some of the wire off and plugged it back in, then both of the amps started cutting in and out, but after they stopped the bass doesnt hit like it should, it doesnt thump, it doesnt punch, ive spent a lot of money on this system, and i want it to work. please help ASAP
thanks
    Problem Solver:
  • 12 Answers
You've spent alot of money on **** by the sounds of it!!. you should only ever run multiple subs the same brand, power and resistance you can just connect any old subs to a system you need to wire them depending on the load that the amp needs to see. first thing is to try the amp/s on a individual sub to check your amps still work once done check the subs 1 by 1.
Posted on Jan 30, 2009
  • Seth Bourne Jan 30, 2009
    sorry the post b4 was supposed to say you cant just connect any old sub
I have 2 different subs in one box, a 12" MTX thunder and a 12" Kicker CVR. the kicker is a dual voice coil while the MTX I dont believe is. Can I use one amp for this set up? And how would it be wired?
im guessing both speakers are 4 ohms ..mtx 4ohms and kicker dual 4ohms..now if your amp can go down to 1 ohm wiring the kicker dual coils in parallel (2ohms) and the mtx connected together (4ohms) should leave you with a final impedance between 1 and 2 ohms ...i suggest you use one or get another
Oct 08, 2013 | MTX Car Audio & Video
What is a good price for two kicker comp vr dual voice coils?? How many watt does each one have??
2 10" Kicker Comp VR's will run you about $150.00 each new from most dealers a good price for 1 10" should be anywhere from $130 - 160 no more and never less.
$160 -$190 for 1 12 " CompVr
Jun 17, 2010 | Kicker Comp VR Car Subwoofer
How do i wire a 8 ohm kicker comp 10" sub inside the box? and what is the best way to get more bump with a 600 w mtx amp and kicker comp 10" sub?
Ok, for an 8 Ohm sub, it is advisable to get another 8 Ohm sub. wire them in parallel down to a 4 Ohm load. You would wire both + wires together, and both - wires together to yield a 4 Ohm load at the amp. Majority of the amplifiers on the market are designed to give more power at a lower impedence, or Ohm load. You just have to make sure that your amp will take a 4 Ohm load. Without knowing the model of the MTX amp, I can't give more advise. However, this should be able to give you and idea of where to start. The main problem is that you have a single 8 Ohm sub in the Kicker Comp.
Apr 30, 2010 | Kicker CompVX CVX104 Subwoofer - 10" Dual...
Kickers dont beat like they should
try to check and clean the wiring as clean as possible to avoid messing up on your connection. Check the polarity of you subs to yuor amp if you have it connected on the outher way around it would not give you a good result. check the polarity this will solve your problem. Over powering your sub will fry it easily try to tune it a 10" sub wont give you a 15" performance..
Jan 20, 2009 | Jl Audio 500/1 Car Audio Amplifier
Mtx 895 trouble
check your fuse up front first. some amps will turn the light on with only the remote wire (the 12 volt signal from the head unit). That may be your issue. If not you need to check your signal input. try hooking the rca's to a diffrent source, i.e. other radio your tv anything with Rca out put. If still you get nothing then pull your subs out and take a regular 9 volt battery and touch the leads to the positive and negative of the sub. Just for a moment though if the subs move when they come in contact with the charge from the battery then my last suggestion would be to take it to a store where you can have an authorized tech check out the equiptment. Good luck
Nov 19, 2007 | MTX Thunder 895 Car Audio Amplifier
Jl Audio 500/1 Car Audio Amplifier Logo
238 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
