Question about Huffy So Sweet Girls 20-Inch Bike
Training wheels don't fit
Axel has single nut - no room for putting the trining wheel on axel
2 Suggested Answers
  • 6 Answers
SOURCE: install training wheels
when installing the training wheels, check to see if it is put together in this order ....flat washer, training wheel, flat washer, lock washer, nut. I hope this helps. If you are missing any of these you can find them at any auto parts store, Wal-mart, or hardware store such as Lowe's or Home Depot. (Be sure to take the traing wheel and nut to make sure you have the right size)
Posted on Dec 28, 2009
Huffy 12' bike front wheel doesn't fit
Mine had the same problem and there was no way bending the fork was going to work. It turns out they had installed an extral washer and nut on the axel. Take one off and retry fitting it. It may only go on one way. Make sure, before you tighten it, that the wheel turns freely.
Dec 25, 2012 | Huffy Disney Princess 16 in. Girls Bicycle
I've got all the wheel nuts incl locking nut off my Golf back wheel, but can't get the wheel off, what am I doing wrong?
At a guess, you've got alloy wheels, assuming so, this is a common problem.
1) Make sure its on an axle stand, not just a scissor jack, and give the inside of the wheel a good old whack with a mallet, if you don't have a rubber hammer/mallet. Hold a piece of wood against the wheel and hit that.
or
2) Put the wheel nuts back on, just finger tight, then roll the car backwards and forwards, with luck the weight of the car should do the work for you.
When you put you wheel back on, put some copper grease on the hub to stop it sticking again.
Jan 30, 2012 | Cars & Trucks
My chain has fallen off, and I can't put it back on. Every time that i think I have it on there again, it falls off shortly after. I don't know if the first time it happened something feel off too...
Hi emsfy...
When you put your chain back on this time, you will need a open end adjustable wrench or a wrench that will fit the nuts that are on the rear axle shaft and wheel assembly.
When you get your wrench, loosen the two nuts (1 on each side of the axle) and pull the axle wheel assembly back towards the back of the slot the axel is sitting in to tighten the chain, when the chain is tight you will tighten the two axel nuts and the job is finished.
The chain will stay on now.
Please take time to rate me thumbs up
Sep 12, 2011 | Schwinn Bikes 26 Womens Southport Cruiser...
Change a bearing in 1983 ford f150 4 wheel drive
need special socket from parts store remove allen bolts from front alex, loose first axle nut. with neddle nose pliers pull out tab ring .then loosen second ring bearing will be next might have to wiggle wheel to get bearing to slid out. replace bearing snug first lock-nut against bearing keep track of lock nut with *** on it that one is first then {DON'T OVER TIGHTEN} then put ring with holes on next nake sure *** is in a hole, then tighten last lock ring watch how you take hub off make sure hubs are not locked in. after you are done with vech.in air lock hubs ane rotate tire to make sure front axel {drive shaft} turns . I use super blue wheel bearing. grease I pack my bearings every two years
Jun 05, 2011 | Ford F-150 Cars & Trucks
Need to know how to remove front halfshaft on a 1998 chevy blazer
Google the exact steps...you'll be amazed what you find.
Apr 19, 2011 | Chevrolet Blazer Cars & Trucks
Hello, I bought my little girl the huffy 12in disney princess bike (blue) already assembled from walmart. she tried to ride it today, but when she pedals the back wheel spins, but the training wheels and...
ONE AT A TIME, loosen the nuts securing the training wheels to the rear axle and slide each one upward a little bit so it float a little bit off the ground when the bike is vertical, then retighten the nut.
As she develops her handling and balance skills she'll need less help from the training wheel. So you can gradually raise them a bit higher as she masters balance and then she'll develop the 'lean' for turning. Ultimately, you remove them entirely.
I hope she's wearing a properly-fitted helmet.
http://www.nhtsa.gov/people/injury/pedbimot/bike/easystepsweb/index.htm
Jan 27, 2011 | Huffy 12 in. Girls Disney Princess Single...
How do u put the front wheel on the Huffy Cars Lightning McQueen 16 Boys' Bicycle
back off the nuts and washers up on the wheel axel. Place the wheel between the forks positioning the axel in the slots. Replace the washers and nuts and tighten with a wrench
Dec 25, 2010 | Huffy Cars Lightning McQueen 16 Boys'...
Bell brand bicycle training wheels
hello there:
the training wheels are a simple procedure you will need to take the nuts off the back wheel and place the steel spacer and put over the axle then place the training wheel over the spacer and put the nut on making sure the the training wheels are not too low or too high.... best of luck to you hope the information is helpful
May 29, 2010 | Cycling
How do I lock up the axel on my bench grinder to retighten after replacing the wheels? Also what is the torque setting?
Just put a wrench on the nut on the opposite side to hold the spindle. They will both tighten at the same time. Tighten them "snug". The threads are made so the nuts will self tighten or should I say will not come loose due to the way the wheels turn and pressure from use is applied.
Dec 02, 2009 | Delta 23 - 725 8" Industrial Grinder
How do you install training wheels on the girls slumber party bike
Most training wheel kits come with directions in the kit. Do one side of the bike at a time. Start with the left side and when tightening the nut back up make sure the rear wheel is still centered in the fork . When you do the right side it is the same but you have to make sure the chain stays in adjustment as well as the wheel being centered. Usually you have to remove the nut on the side that you are working on. The kit should come with a little bar with a hole in it that fits over the bolt that you just removed the nut from. Make sure that the flat side faces out and the protrusions on the bar fit into the slots on the fork. Next mount the bar with the training wheels on the bike over the first bar. Put the washer supplied in the kit over that and then screw the nut back on. Pay attention to the wheel being centered and the chain being tight enough not to slip off the crank when pedalling. Make sure you get the proper size for the bicycle. There is a video here that explains it http://www.ehow.com/video_4974885_put-trining-wheels-bike.html
Jun 24, 2009 | Cycling
Huffy So Sweet Girls 20-Inch Bike Logo
89 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
