Brother ax110 does not type
Hammer does not strike
Geno111
  • 183 Answers
SOURCE: cant find margin release
Generally, the way the margins work is, wherever the printhead is positioned, when you hit the right or left margin set, is where the margin is set. To reset the margin you must move the printhead to where you want the margin set, and hit the appropriate mar. set button. to move the printhead past where the margin is set, you must hit the "mar rel" button, and then backspace or space to where you want he printhead positioned. On machines without a "mar rel" button, you just use the "backspace" or "spacebar" to move past the margin. You can't release the margins permenantly, you can only move them, or move past them using the above mentioned processes.
Posted on Oct 24, 2008
  • 3594 Answers
SOURCE: the hammer does not strike
If this is an IBM wheelwriter you need the plastic solenoid cap.
We sell them for 20.00 includes S&H and inst.
216-241-0027
DickyO
Posted on Apr 09, 2009
  • 3594 Answers
SOURCE: "Hammer" won't strike; printwheel won't turn; code key not workin
It sounds like the print solenoid cap is broken except for the printwheel not spinning. the caps are available for 20.00 including shipping and instructoins. The code not working may be a keyboard for a keyboard rebuild contact Geo. Beyers Co. @800-392-8085.
DickyO
Cleveland Business Machines
216-241-0027
Posted on Jan 27, 2010
RadarRon
  • 398 Answers
SOURCE: The hammer that strikes the daisy wheel is stuck
Sometimes it a minor jam and you can just put your finger in the hammer and pull it away from the printwheel. Don't force it there are a lot of plastic gears that can be damaged. If that doesn't work, try releasing the print wheel (like if you were changing it) sometimes that will release the hammer. Last "easy fix" is to cycle the power, Turn the power off and when you turn back on the carriage should reset its self.
Posted on Dec 10, 2010
  • 9 Answers
SOURCE: The hammer on our typewriter won't strike, it just
Hi - there a many reasons why this happens. Try these first. Replace the ribbon. This might have become tight (faulty) and make this happen. Next clean the main rod that the carriage goes back and forth on, it sometimes get very sticky. Then place a couple of drips of oil on. This should work wonders? Best John ex OEM trained mechanic
Posted on Jan 07, 2011
Bought new Brother ML300 will not type anything on the paper, please help!
I would check all the basic stuff first. Is the print wheel locked into position? Is the platen all the way forward? (lever right side) Is the ribbon installed correctly and not cocked up on one side? Do you hear the hammer striking the paper? If you hear the hammer striking the paper, it is a ribbon problem. If you don't hear it, it is a hammer / print wheel problem.
Jun 24, 2014 | Brother ML-300 Typewriter
My typewriter won't type. The cartridge moves, but nothing prints
The ribbon may be broken or binding so that it cannot advance.
Apr 19, 2014 | Brother EM-430 Typewriter
Hammer doesd not strike
There is a clutch system under the ribbon carrier that has to rotate to move the hammer, see if you can see if this part is rotating, also there is a spring that puts pressure on the hammer. If this clutch is not moving it may need replacement,, or cleaned with alcohol.
Apr 14, 2014 | Brother ML-500 Typewriter
My AX -430 typewriter was functioning well as i was using it. However as i was typing a new word, the letters are no longer visible on the paper. The part that hits or is it the hammer or arm, can no...
It sound like you have a broken part. If the hammer is not hitting hard enough, the armature theat make the hammer strike the keys is broken. This is a common problem with the ax's
Mar 03, 2011 | Brother EM-430 Typewriter
Hi
Many brother type writers have two cam assemblies under ribbon holder. One operates the print hammer and the other operates the correction ribbon lift. sometimes they gets stuck or lock themselves up. turning on and off a few times will take care of it, but sometimes it needs to be worked on by a tech. If you look when you type a character, most likely the print hammer is not firing or it is striking the correction ribbon instead of the black ribbon.
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting Fixya.com
Apr 08, 2010 | Brother EM-530 Typewriter
My typewriter doesn't type..won't display letters, but keys work.
alot of the brother t/w's have 2 cam assemblies under ribbon holder. 1 operates the print hammer and 1 operates the correction ribbon lift. sometimes these will hang or lockup. sometimes turning on and off a few times will take care of it, but sometimes it needs to be worked on by a t/w tech. if you look when you type a character, most likely the print hammer is not firing or it is striking the correction ribbon instead of the black ribbon.
hth,
razors
Feb 27, 2009 | Brother Office Equipment & Supplies
Brother Correctronic 40 Not striking
You’re right Brother authorized service centers are hard to come by and now that the one that I was working for went bankrupt I can’t buy parts any longer.
Let me see if I understand the problem. When you start typing it’s ok and as you continue typing it get’s lighter then it finally stops printing? If you let the machine sit like overnight it starts all over? If so what you need is a .20¢ rubber bumper used to lessen the hammer noise.
What happens is the rubber get’s sticky with the heat generated from use. I have tried to find a substitute (for the Brother part) and nothing I have found lasts very long. If you just remove the bumper the hammer makes a terrible racket (too noisy for more people), and I suspect if it were used without the bumper the hammer mechanism would rattle apart after a short time.
I know this can be repaired easily but not cheaply. The machine is old, it’s time to consider a replacement. Sorry!
Mar 14, 2008 | Office Equipment & Supplies
Cannot get daisy wheel to type correct letters
Turn oFF the typewriter, take the ribbon out.....use the lever on top to release and remove the print wheel cartridge. Lightly rotate it to see if it will move and reinsert the cartridge. snap it back into place.
Turn on the machine, the typewriter should move the carrier to the left and reset the printwheel....if it is snapped back properly.
Jan 14, 2008 | Brother GX-6750 Typewriter
Brother ML300 Typewriter
Is the hammer striking the paper? What letters print when you press a key? Can you determine if the printwheel is turning?
Dec 28, 2007 | Brother ML-300 Typewriter
29 people viewed this question
k24674
