Question about Dell Computers & Internet
Desktop hangs up after I hit ALT & space bar by mistake.
  • Dell Master
  • 27,725 Answers
Most "freezes" are just software lockups, often limited to just one program, although they can cause the entire system seemingly to hang. The remainder are caused by hardware. Failing power supplies can cause all sorts of trouble, for example, including freezes. Memory is also a frequent culprit. Reseating the memory module fixes memory-related problems one-third of the time on desktop systems and one-quarter of the time on laptop systems, according to studies done by Microsoft.
Press "Alt" and "F4." This may close the program without any further problems. Press the "Alt" and "Tab" keys together to switch to another program. If you are unable to see any change when you press "Alt" and "Tab," then try to bring up the Task Manager by pressing the left "Control" key, the left "Shift" key and "Escape." If that key combination doesn't open the Task Manager, press "Ctrl," "Alt" and "Del," then press the down arrow on the keyboard four times to highlight "Start Task Manager." Press "Enter." Determine the problem area. If your mouse cursor moves freely, then you have a locked up program and you need to find the process that's hogging the CPU. If the whole system seems jerky, and you can hear or see your hard drive being continuously active, then you are facing memory exhaustion. Go to the "Processes" tab. Sort by CPU or Memory as determined. If your mouse is functional, click the headers to sort the appropriate column. Otherwise press "Tab" to move forward or "Shift" and "Tab" to move back through the controls until you get to the header. Then use the arrow keys to select the header you want to sort by and press "Enter." Select the item at the top of the list, which should be the problem program. If your mouse doesn't work, use "Tab" or "Shift" and "Tab" to navigate to the list. Click the "End Process" button, or press "Alt" and "E." Then click "End Process" in the confirmation box or press "Spacebar" on the keyboard. If none of this worked, your computer may be totally frozen due to a component problem. b> Component Problems b> Power down the computer and unplug it from the power source. For a desktop computer, open up the computer case, consulting your owner's manual as necessary, to locate and reseat the memory modules. Pull the retaining clip back from the memory module and pull the module upward out of its socket. Push the memory into the slot while pulling the retaining clips gently toward the memory until it is fully seated. To reseat it, make sure the notch is aligned with the memory slot. For laptops, locate your memory, which is usually found behind a labeled door on the underside. Unscrew the door. Pull the retaining clips back from the memory module and pull the module toward you to a 45-degree angle. Then pull the module straight out of its socket. Push the memory into the slot at a 45-degree angle. Rotate the module gently until the retaining clips are securely fastened, and the module is fully seated. To reseat it, make sure the notch is aligned with the memory slot. Unscrew the retaining screw on the faceplate of the video memory card, if present in your desktop computer, and push the latch at the rear of the card toward the slot. Pull the card straight out, then push the card straight into the slot until the latch reingages. Screw the faceplate into the case. This does not apply to laptops. Reseat any other add-in cards present in the desktop computer. Overheating Problems b> Check the temperature. If your computer supports temperature monitoring, use the vendor-supplied utility to check temperatures. Anything above 140 degrees Fahrenheit should be considered suspect. Identify faulty fans. Any fans not moving under load with high heat showing should be immediately replaced in desktops. If your laptop has a faulty fan, you need to have it professionally serviced. Add more cooling fans to your desktop computer. Fan width is measured in millimeters. Common s are 80, 92 and 120 millimeters. You need to purchase fans that fit into your computer case's fan mounts. If your computer came with a jumper diagram for the motherboard, locate the fan connectors, usually labeled "FAN1" to "FAN4." Determine if the fan connectors have three pins or four pins. Buy additional fans with the same number of pins as those already in your case have. If you can't determine the number of pins, get fans that include "Molex" adapters to connect to your power supply. Start by mounting fans into the front of the case, blowing toward the back. If the problem persists, add more fans to the rear of the case, blowing outward. Laptop users can purchase a cooling pad that comes with extra cooling fans and typically connects via USB. Add a heat spreader to the memory modules in your desktop. This does not apply to laptop users. Open up the computer case, consulting your owner's manual as necessary, to locate the memory modules. Pull the retaining clip back from the memory module and pull the module upward out of its socket. If the heat spreader's manufacturer provided directions, follow them. Otherwise, remove the adhesive backing from one-half of the heat spreader. Apply the heat spreader to the memory module. Apply the other half of the heat spreader, ensuring that the screw holes or the clip slots are aligned. Screw or clip it together. Power Problems b> Ensure your computer is plugged into a high-quality surge suppressor, not just a power strip. Try the computer in different outlets around the house, especially those on another electrical circuit. Plug the computer into an uninterruptible power supply, or UPS. Connect your desktop's internal components to different power supply cables. The internal power supply has several power converters in it, so connecting your computer's internal components to different cables or cable bundles can spread the power load to help avoid under-voltage problems. Hope this helps.
b>
Posted on Jan 06, 2013
Tip
How to remove the text from the Desktop icon or from any directory or file
You can remove the text from any icon, directory or file, you just need to rename the file, directory or icon, just go to rename option and set blank name or single space-bar entry but the problem is that, windows will not allow you to set blank name or name with single space-bar entry. Here interesting thing is this, window will allow you to use the ASCII code for a space, which is 0160.
First of all you can clear all the text from that icon
Now type the ASCII code, simply hold the Alt key, type the number 0160 from the number pad and release the Alt key then press Enter button to finish the process. (Note. you can also put some special character in place of text by pressing some different ASCII codes like - 6560, 2456, 4251 etc......)
on Mar 02, 2010 | Computers & Internet
How do i get my laptop screen thr right way up i pressed somthing and its gone upside down
You probably flipped the screen orientation (rotated it).
For some versions of Windows (XP and Vista), try pressing Control (Crtl)+Alt+Up arrow (press the three keys together). You can also try the other arrow keys with the Crtl+Alt keys. The Crtl and alt keys are both usually in the row with the space bar. On a full-size keyboard, there are two Ctrl keys on the ends of the row and the alt keys are closest to the space bar.
Otherwise, right click on the Desktop (where there are no programs or icons) and choose Graphics Options > Rotation. Another place to check is right click on the desktop and choose Screen Resolution > Orientation. This is a shortcut to accessing the display properties in the Control Panel. Click Start > Control Panel > Appearance and Personalization > Display > Screen Resolution. For a widescreen monitor, choose Landscape.
I hope this helps.
(The ctrl+alt+arrow key doesn't work on my Win7 desktop but does work on the laptop. The Orientation change from the control panel works on both.)
May 04, 2012 | Acer Computers & Internet
How do I re-set the margins?
using the space bar or backspace keys, move the carrier to where youwant the margin set, you may have to hold down the "ALT" button (2nd key from left on the bottom of the keyboard) and hit the "3" button (the one under wher it says "MAR REL") , to move past the margin. When the carrier is where you want the margin set, hold down the ALT key and then hit he key under where it says L MAR (for left margin) or R MAR (for right margin). the ALT key accesses all the function listed above the keyboard, the CODE key accesses all the functions listed on the keys themselves.
Feb 28, 2011 | Brother ML-300 Typewriter
No menu bar
Left click near the bottom of the desktop and try to drag the menu bar up towards the top of your screen, if the problem lies on the desktop menu bar.
Feb 28, 2011 | Dell Dimension E520 PC Desktop
@ will not activate
Look to the right of the SPACE BAR on your computer.
If the first key is labelled ALT(ernate) GRA(phic), then hold that key down, press the '2' key, release the '2' key, and release the ALT GRA key.
Apr 17, 2010 | Acer Aspire One PC Notebook
Letters on the keyboard don't always get on the
I think ya need a new keyboard, that is NOT normal.. & KB's either work right or replace
Jan 26, 2010 | Computers & Internet
When I hit the space bar it eitherdoes
is a stuked key bar, normaly bellow key is a metalic part, is out of place, and stuck key when pressed.
Jan 09, 2010 | Logitech Cordless Desktop MX3200 Laser...
How to creat new folder on desktop using keyboard winthout any supporting software installed in widows xp
assuming your desktop is selected the little button on the right of you space bar between the Alt and Ctrl keys will bring up the right click menu (Context Sensitive Menu)
Scroll down the menu using your arrow keys to "new"
Press the right arrow key
Select Folder
Well the rest you can work out for yourself - its the easy part :P
You can select your desktop by pressing Alt-Tab and selecting your desktop
If this helped you at all please vote
Oct 06, 2009 | Computers & Internet
My icons and tool bars are so big nothing I bring up fits on the screen.....I can make the internet smaller with the mouse wheel, but it shows in a very small space because of the very large tool bars....
Here are some tips to help you move around when you can't see other parts of the screen
Alt + Tab (hold down Alt and press tab) will move you between open windows
Tab will move you from button to button and to the file menu at the top
Shift + tab will move you back, for example if you hit the tab key one too many times
Alt + F4 will close the open window, if no window is selected it will bring up the shutdown computer screen
F5 will refresh a page on the Internet
F11 will switch between Full Screen mode and not full screen mode
So try getting to the "approved" window and then using tab to select it.
Mar 11, 2009 | Gateway GT5056 PC Desktop
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
