Went to do laundry has know power breaker is good outlet has power
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 30 Answers
If you find a fuse check to seee if its bad
Posted on Jan 06, 2013
3 Suggested Answers
SOURCE: My Kenmore Elite front loader has no power.
the power is on but the start button does not start the machine
Posted on Jun 30, 2009
blueextc3221
  • 15935 Answers
SOURCE: i started a load of laundry and went back in to
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
All the outlets and lights in the garage quit working. We know the fuse in the box is working and cannot find a GFI on the circuit. We tested the wires and they appear to be hot. Any ideas?
All newer construction will have a gfci on circuits run outside (including garages) find the gfci it may be under the house. If it's a breaker it needs to be switched off fully then switched on, sometimes breakers have popped but don't show visible signs
Good luck
Most saws have breakers some also have online fuses check it out
May 01, 2017 | Saws
Answer not provided. Please read my question.
is it 110 or 220? if it is a 110 first check your breaker/ fuse panel for tripped breaker or blown fuse if 220 it would be a double breaker. if you find tripped breaker remember some panels require you to turn the breaker fully off then back on to reset. if 110 and no blown breakers, check your laundry room for a GFI (ground fault interrupt) outlet. make sure that it is not tripped either. to reset that just push the reset button on the outlet. best of luck to you
Nov 19, 2015 | Dryers
Why does laundry center have no power?
Kenmore washer 40272 has no power. Unplug and wait a ...
www.shopyourway.com > Manage My Life > Questions
I have a Kenmore 40272 front load washer. ... I remove plug from outlet, wait, then plug back in. ... Do you have the washer plugged in to an outlet or is an extension cord being used?
Nov 06, 2015 | Kenmore Washing Machines
The gfci power cord is not lighting up
One of two things. First check the power to the outlet. If this is outside, their is probally a GFCI on this line ether on the breaker or in the house on one of the outlets in the laundry or bath room. Or the GFCI in the cord has gone bad. If you have good power to the outlet and it trips when plugged in their is something wrong in the spa and will need to be addresed. If your good with electric you can check this by going step by step with the power till you find what causes the GFCI to trip. If not it may be time for a repairman. Good luck.
Mar 06, 2010 | Pool & Spa
Maytag 3000 Series front load gas dryer (Whirlpool) - No lights, no digital display, not able to turn on or start. Yes, unit is plugged in to AC outlet. Yes, AC voltage is good at 120V. Yes, circuit...
OK everyone, my ears are red. Over the weekend, I gave this another shot, since my warranty repair appointment isn't until next week.
I opened the dryer door (the drum light is off, indicating no power at all) and went to the circuit breaker box, and flipped the washer/dryer breaker back to off and then re-set the breaker again.
When I got to the laundry room - the drum light was on!
So I powered up the unit, and ran the machine. It ran for about one minute, and then went off. So I went back and re-set the breaker again.
Visually, the breakers did NOT LOOK tripped - but flipping the thing off and then on to re-set the breaker worked.
This time, the dryer is working fine. The bad part is: I need to replace the breaker for the second time. So this is NOT a defective dryer, it is a bad electrical supply. I will call the electrician back to make him fix this right. . . . .
Thanks again for all who responded. This is a new unit, purchased on 7/7/2009.
Sep 12, 2009 | Maytag Dryers
Power went off now my washer will not work
First thing to check is for power at the outlet--plug a working lamp in. If no light, find the laundry room breaker in the house electrical panel--push off, then on. Recheck with the light. If ok, try the washer. Hope this helps!
Sep 07, 2009 | Washing Machines
Jun 29, 2009 | Kenmore Elite 45986 Front Load Washer
Dryer wont start
Hello. i can help you. begin by checking the power.
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
If that doesnt get it working again get back as there are other things that could have gone wrong.
Jun 04, 2009 | Dryers
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
