Question about Sony KP-61HS10 61" Rear Projection Television
Sony tv kp-61hs10 wont turn on light flashes constantly
Standy by light flashes constantly with no pauses
ctf1800
  • 4402 Answers
SOURCE: KP-61HS10
yes. go here
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Posted on Dec 20, 2007
SOURCE: Sony KP-51Ws520
9 blinks means, "Zero Crossing Detector" and the probable cause locations listed are "D6166 or D6114 is open (G board)". I had the exact same problem so I just ordered a new G board and swapped it with the old one and now everything works fine! You could order a new one at this site: http://www.partstore.com/PartSearch.aspx?PartNumber=A1054157A&x=31&y=19. The Sony board number is A1054157A. Replacing the G board is rather simple; all you got to do is pull out the back cover of the TV and the G board is the first board on your very left. After that unplug the four connectors and replace it with the new one. Here is a picture of the G board inside your TV: http://img47.imageshack.us/img47/8396/backev6.jpg. Hope this helped!
Posted on Jul 16, 2008
SOURCE: Sony KP-61HS10 61 in. Rear Projection Television
my tv has the same problem but it blinks five time with no picture but good sound
Posted on Aug 01, 2008
SOURCE: I have a Sony KP-61HS10 that will not turn on.....
hello read my comment on shadie333 i just posted the problem i had, my tv is a kdp65ws550 which is also the same as the kdp57ws550 and kdp51ws550 mine was doing the same thing... ours is fixed... please read it
Posted on Dec 17, 2008
  • 3 Answers
SOURCE: sony kp-61hs10 tv, has sound but picture goes black after 3 min.
I just had the same problem. If your lucky it might be a free 5 minute fix. The five light flashes mean impropper current. I took the front grill off, then behind that is another black cover, I took that off and noticed the circuit boards COVERED in dust. I then took an air can duster and blew off all the dust... works like new. No more flashes and in an out picture. The collection of dust was interfereing with the electrical current.
Ben
Posted on Jun 22, 2009
Dryer/model number DRCS68W. Light constantly flashing on start-pause-cancel button also light on constantly dryer button but not flashing. How do I grt light to stop flashing so I can use dryer.
This could be the belt on the drum that has come off the pulley or the motor, it may have broken. It might also be a bad switch on the door or the pulley, it could also be a bad control board.
Jan 09, 2018 | Dryers
Pause light is constantly flashing
Pause is not a term ive seen on a dehumidifier , but one would assume that its waiting for something to occur in that mode , and with these the only logicial reason to wait is to "wait" for Moisture to return to room , maybe your room has been voided of %rh to the setting on unit and its waiting for more water to return ??
Dec 13, 2014 | Dehumidifiers
My television turned itself off and will not turn back on again, the blue light is constantly flashing.
Hi
How many times does the light flash... i.e. flash flash flash flash flash...pause, then repeats?
If you include the make and model of the TV in your reply this would be helpful.
Regards,
HillElectronix
Aug 04, 2011 | Televison & Video
Ruff idol, poor acceleration. EGR light on. Idol was ruff for several days. Replaced distributor,coil,spark plugs,spark plug wires,air filter and fuel filter. EGR light did not come on until after the...
Cycle your key on (not start) then off, on, off, then on and leave it on. Now count the flashes from the "check engine light" and get back to us with those codes. It will flash a 2 digit number, but pause briefly between numbers. For example: 3 flashes,pause, then 3 more flashes is code 33. 1 flash, pause , then 5 more would be code 15. When you get 5 flashes, pause, then 5 more, that's code 55 and it just means end of message or codes. You'll also get a short pause between codes as well, so have a pad and paper ready and keep your eyes on the check engine light.
Jun 29, 2011 | 1987 Dodge Dakota
I had water damage in my wall an my power strip got wet. Now my Tv shuts itself off after I turn it on before the unit ever comes on. Then the blue led power indicator light flashes.... U hope this is a...
Does it flash in a pattern or does it constantly flash - like 7 flashes then pause then 7 flashes? Or is it constant without pauses? Are you using a new power strip? It could be two things 1. Power supply or 2. Main board. is my initial thoughts. Have you opened it up to check the fuses, caps etc? If the power suply voltages look good its probably the main board.
Thanks,
michael
Feb 06, 2011 | JVC LT-52X579 52 in. LCD TV
My Sony Bravia will play for less than a minute and then reverts to standy. Any suggestions?
Please unplug tv from wall socket for minute or so,, replug back in and turn it On.
If tv still goes to standby itself than its standby light would blink to show an error in somewhere inside tv circuits.
Let me know how many times standby red light blinking? There would be 3 seconds long pause in blinking so count pause to pause to determine problem section.
Thanks.
Jun 13, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Engine service light is constantly on
That's basically your vehicle telling you that there is a problem. Not 100% sure whether in 96 you can cycle key to retrieve trouble codes or not, but you can try. Here's what to try.
Turn key to ON (not start) then off, then on,then off, then on, and leave it on. Have a piece of paper and pen ready and count the flashes of the "Check engine light". It will flash a 2 digit number, with a pause in between each number. For example: flash,flash,pause, flash,flash,flash, would be code 23. Flash,flash,flash,pause,flash,flash, would be code 32. There will be a slightly longer pause in between the codes. When you get code 55, which is 5 flashes, pause, then 5 more, that means "end of message. Get back to us with the results and it will help pinpoint where the problem is and will help cure it quicker, and usually cheaper by taking out some of the guess work. We'll be waiting to hear back.
Nov 26, 2009 | 1996 Dodge Caravan
Sony Projection Stand by indicator flashing red
Ur FBT,Fly Back Transformer high voltage is dead, the black block of plastic with a red wire with cap hook to a CRT(Tv Tube).
Sep 14, 2009 | Sony KP-46S25 TV
Sony KP-61HS10 61" Rear Projection Television Logo
230 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
