Question about Dell Computers & Internet
How to unlock desktop after hitting ALT & space bar
Computer locks up after hitting ALT & space bar by mistake, have to turn off power to restart.
  • Dell Master
  • 27,725 Answers
Might be a ram problem or a loose connection of some type
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible.
There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Jan 06, 2013
4 Suggested Answers
philmik
  • 107 Answers
SOURCE: when i hit ctrl alt delete it says my computer is locked. the blue screen keeps coming and going. I cannot use any part of my start or desktop.
Here you'll find some of the solutions.
Posted on Apr 18, 2009
efs_perpends
  • 1996 Answers
SOURCE: cant get my desktop icons back or the toolbar
This sounds like a malware problem. There should be nothing on your system telling you to buy something!
Are you on xp? If not, let us know your os,
If so, follow these instructions:
Reboot the system, press F8 steadily, and when you get the os options screen choose last known good configuration and see if windows boots 'normally'. If you get in with a desktop, please go to this link and follow the malware removal protocols up through step 4, at least, before restarting your system. You'll need to scan with MBAM to remove the malware.
If that doesn't work, try rebooting into safe mode with networking, then go to this link, scroll down to line 195, right column, and download and install the registry repair for your computer.( or click here to download). Then follow the malware removal instructions to scan for problems. Allow MBAM to remove any problems it finds.
If you need more instructions or run into any difficulties with this, post back with more details and we'll be happy to walk you through it.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 22, 2009
sherbazmoham
  • 62 Answers
SOURCE: When I turn the computer on, it says "disc read
Its likely because of hard disk failure. Try replacing the hard drive.
Regards
Sherbaz
Posted on Aug 06, 2010
My new straight Talk phone won't unlock
hit the dash that is ABOVE and to the left of the OK then hit the space bar on the bottom. Space bar is the widest key on the bottom and actually looks like a typical keyboard space bar.
Jun 01, 2012 | straighttalk.com
How do i restore EI 305 to factory settings
Turn Off the computer, now as soon as you hit the power button, keep on holding
Alt key & keep on tapping F10 key Alt+F10 it will open the recovery console ,select full factory restore and follow on screen instruction.
Nov 19, 2011 | Computers & Internet
I want to reset my compaq desktop to its original settings from theday I bought it
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) Hope this helps
Mar 11, 2011 | Computers & Internet
How do i get back to factory setings keep geting
Here are a few things you can do or try
Restart the computer. If you are already in Windows, you can do this from the Windows Start menu, go to Turn off computer and click Restart. As the computer restarts, watch for a progress bar at the bottom of the screen. press F8 about once every second. Immediately press F8 before the progress bar reaches the right side of the screen. From the Windows Start-up menu, highlight Safe Mode and press Enter. Wait for your desktop to appear, and then make the necessary repairs (for example, uninstall programs or devices). When the repairs are done, restart the computer, and allow it to boot normally.
Alternate:
From the Windows Start menu, click Run. In the Open field, type MSCONFIG and click Ok. On the BOOT.INI tab, check /SAFEBOOT.
Click Restart when prompted.
or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
Hope this helps don't forget to vote
Feb 21, 2011 | Gateway Computers & Internet
I need directions on how to restore my dell optiplex 170l to factory settings os is xp
Hope this helps
Jan 06, 2011 | Dell OptiPlex 170L PC Desktop
Host Procees as stopped working
It appears that the Windows is corrupted on your computer, you can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction.
NOTE: This will erase all the datas on the computer.
Thanks and regards,
Jitha
Dec 27, 2010 | Acer Aspire M1201 Athlon X2 320 Gb PC...
Computer wont boot past the acer empowering people screen
Thanks and regards,
Jitha
Dec 24, 2010 | Acer Aspire X3400 PC Desktop
Trying to perform recvery and getting cannot find preload.tag for set boot ini error
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction.
Thanks and regards,
Jitha
Dec 24, 2010 | Acer Aspire E360 PC Desktop
MY COMPUTER HAS BEEN LOCKED
Hit the power button till it shuts down. Let me know what happens when you turn it back on.
Jan 02, 2008 | Computers & Internet
Computers & Internet Logo
18 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
