Question about Claude Valentini Watches
Set up claude valetini activater cl700 after new battery
How do i change a battery in a quick silver watch (Viper YO15DV )
  • Remove back
  • Find battery mounting. Note mounting arrangement and polarity for future.
  • Identify battery type.
  • Obtain new battery
  • Remove old battery. Install new.
  • Check operation
  • Reinstall back
  • Set time, etc.
OR,
Take your watch to a jeweler who, for a reasonable sum, will replace the battery
Take your watch to
Nov 29, 2016 | Watches
Need help changing battery for my guess watch G85635L..tytyty
  • Remove back
  • Find battery. Identify type and note mounting arrangement for later installation
  • Remove old battery. Install new one correctly
  • Check operation
  • Reinstall back
  • Set time, etc.
OR,
Take your watch to a jeweler who, for a reasonable sum, will replace the battery for you.
Nov 28, 2016 | Guess Watches
Battery change
  • Open back
  • Note battery polarity and remove
  • Install new battery
  • Close back
  • Set correct time
Jul 12, 2016 | Watches
Battery replacement
  • Open case
  • Remove old battery. Check to be sure it is same type as new battery.
  • Install new battery. Be sure it is correctly seated and clamped in place.
  • Close case
  • Check operation and settings
Jun 26, 2016 | Tissot Mens T0484172705703 T-Race Quartz...
Armani Exchange Watches AX2072
Je cherche un notice d'utilisation de la montre Armani Exchange AX2077.
Merci pour votre aide
Claude
Nov 21, 2013 | Armani Exchange Watches
Battery replacement in wvq141 watch
Remove the back of the case. Remove the dead battery. Replace with a new battery. Close case back set time and your all set till it dies again.
Nov 10, 2013 | Casio Waveceptor Atomic Radio Controlled...
New battery needed and fitted to a Polar heart rate monitor
This is really easy to do yourself. Get a CR1632 battery, unscrew the four screws on the back (dont tip the watch as there is a small spring in the watch), unclip the metal band holding in the old battery noting the way 'round the battery is in (minus side up), pop in new battery and push clip back down, when re-fitting the back make sure the spring mentioned earlier lines up with the white sticker with a hole in it on the inside of the watch back, screw down the back. After you have re done all your settings you may need to re-aquaint the watch with the strap, to do this put on the watch and strap, set the heart monitoring going, bring the watch up close to the 'Polar' logo on the chest strap until the time is displayed, should now be all set up.
Andy
Oct 28, 2009 | Polar F4 Heart Rate Monitor Watch
Need instructions manual for my solsuno watch
you can go to solsunoworld.com and visit the order page, you will find the instruction next to any genuine solsuno, our movment is used by zeon for their zeon tech
You can contact me for info via solsunoworld.com
Claude
Mar 28, 2009 | Watches
Setting the time
Dear Sir,
It appears that the watch was malfunctioning which I thought was due to a change of battery being required.
(It was running slow and giving the wrong time - so my mother told me)
I subsequently found instructions for the watch on an internet site, changed the battery and the watch is still failing to set to the U.K. time zone therefore, I deduce that it is a failure in the watch rather than the need for a new battery or ranything I have or have not done.
Please delete my question from your system
Thank you.
Regards
Jan 17, 2009 | Bulova Watch
Watches Logo
Top Claude Valentini Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Claude Valentini Watch Expert? Answer questions, earn points and help others
