Will not go to main startup even when safe start selected
  • 7,627 Answers
You didn't select safe mode using the up arrow key. Shut down, unplug, remove battery, plug in, reboot.
Posted on Jan 06, 2013
Hi. how can i enter in safe mode on an asus k50ij with windows 10 ?
Here you go:
Start your PC in safe mode in Windows 10
  • ?Email
  • Hide all
    From Settings
    1. Press Windows logo key Windows logo key + I on your keyboard to open Settings. If that doesn't work, select the Start button in the lower-left corner of your screen, then select Settings.
    2. Select Update & security > Recovery.
    3. Under Advanced startup, select Restart now.
    4. After your PC restarts to the Choose an option screen, select Troubleshoot > Advanced options > Startup Settings > Restart.
    5. After your PC restarts, you'll see a list of options. Select 4 or F4 to start your PC in Safe Mode. Or if you'll need to use the Internet, select 5 or F5 for Safe Mode with Networking.
    From the sign-in screen
    1. Restart your PC. When you get to the sign-in screen, hold the Shift key down while you select Power > Restart.
    2. After your PC restarts to the Choose an option screen, select Troubleshoot > Advanced options > Startup Settings > Restart.
    3. After your PC restarts, you'll see a list of options. Select 4 or F4 to start your PC in Safe Mode. Or if you'll need to use the Internet, select 5 or F5 for Safe Mode with Networking.
Jan 03, 2017 | ASUS Computers & Internet
Tip
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy...
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy Tips
If you fail to boot the operating system, you can:
#1. Use Windows startup Disk to fix Windows 7 startup problem
If the failure of booting is result from the errors or the damaged files of starting system, a start up disk will help to solve this problem with ease.
#2. Use last know Good Configuration to fix Windows 7 startup problem
It is also a common method to enter the operating system. To use last know Good Configuration you can press F8 when you reboot the system. Then select "Last know Good Configuration" on the Advanced Boot Options screen to enter this mode.
#3. Use System Restore option in safe mode to fix Windows 7 startup problem
Enter the safe mode as the step in to last know Good Configuration in method #2. Choose System Restore option in System Tool in start menu.
If you find the startup process of Windows 7 very slow, we suggest that you should:
#1. Remove redundant programs in your booting items as many as possible. After finishing this action, the speed of startup can be improved by no less than 40%.
#2. Delete short cuts on desktop. The more icons on the desktop, the longer it takes to restart Windows 7. To fix Windows 7 startup problem, you should clear up the unnecessary short cuts on your computer desktop.
#3. Optimize registry regularly with proper registry maintenance tool. Registry error is the main reason that slows down the rebooting speed. You had better do registry cleanup timely to speed up Windows 7 start up process.
on Jan 12, 2010 | Computers & Internet
Dell dimension 3100 wont load to main screen
You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose Safe Mode). Win 7 - Start > Search type System Restore. XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates. Uninstall last program(s) that was installed, again in safe mode.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Nov 29, 2012 | Computers & Internet
My comp says i need to turn off safe mode its preventing certain things from loading
Hi, open your computer in safe mode and uninstall some newly install software. Otherwise--
  • Turn on CPU.
  • CPU will be start booting. Red/yellow light will be blinking. If yes then check your monitor light will be fixing and Show *********** Board.
  • If shows and your OS will be Booting and fail to start.
  • If yes you can repair it.
  • Insert OS disk into the DVD driver.
  • Turn off PC.
  • Turn on
  • "Press any key........" when comes this message you press any key.
  • After that you can see two option
?? Fresh copy Installation OR
?? Repair Option
  • For Repair Press "R"
  • It will be start repairing
Thanks.
May 17, 2011 | Computers & Internet
My dell studio startup repair cant fix the problem,every time i start my pc it goes off after the startup repair
Try booting it up in safe mode. At the startup continuosuly press the F8 key repeatedly
Once you get to the Bootup option, select Safe Mode
After booting into safe mode, click on Start, All Programs, Accessories, System Tools, System Restore.
Restore to the date around when your laptop was working ok
Feb 25, 2011 | Dell Studio 17 Laptop
Hi, I have a toshiba equium A110-233, a little elderly I know ! All was working fine until I turned it on a couple of days ago and now only get the initial toshiba screen then nothing, not even the cursor...
Hi shirley_ann1,
This problem that you have with your PC is a NO BOOT issue. After getting the startup Toshiba logo it's not booting up to your Windows. This could be a hardware or software problem depending on the result of the diagnostics that I'll be walking you through below, but definitely this issue can still be fixed.
Here's how:
1. If this is a software issue you can determine it by booting up on safe mode. To go to safe mode:
  • Shutdown the computer then turn it back on
  • The moment you turn on you PC keep on tapping F8 button until Safe Mode menu shows.
  • Then select Safe Mode, press enter.
If you'll be able to boot up on Windows using Safe Mode then you just have to reload your operating system. You will use the recovery disc that goes with your machine when you purchase it.
2. If it's a hardware issue you will not be able to boot up even on Safe Mode or even go to BIOS when you keep on tapping F2 during startup. This means your harddrive is corrupted or defetive. It needs to be reimaged or replaced.
Hope this will help you resolve your concern.
Thank you for using Fixya.
Feb 21, 2011 | Toshiba Satellite A135-S4527 Notebook
My dell inspiron mini 10 bootes up to the main sceen but no icons nor start button appear.. please help
ok try starting in safe mode, keep pressing f8 on startup till menu appears, then run system restore if safe mode works
Aug 30, 2010 | Dell Inspiron Mini 10 Notebook
My son set a password on a Dell computer and does not remember what it is. Is there a way I can bypass this and reset the password. It asks for a password on start up and has windows xp.
You can definitely reset the password for your computer just do the ff steps:
  • when the computer is starting up press F8 simultaneously
  • select safeboot when prompted for boot options
  • login as administrator
  • when you are on the main screen click start
  • select control panel
  • select USERS
  • select the username that you are using
  • click on remove password
  • then restart your computer
Hope this will help
Thanks
Byron
Sep 24, 2009 | Dell Computers & Internet
Same problem!
I would boot the computer in safe mode and here is the instructions.
Learn how to start up in Safe Mode.
Products Affected Mac OS X 10.4, Mac OS X 10.3, Mac OS X 10.2, Mac OS X 10.5
To start up into Safe Mode (to Safe Boot), do this:
  1. Be sure the computer is shut down.
  2. Press the power button.
  3. Immediately after you hear the startup tone, hold the Shift key. The Shift key should be held as soon as possible after the startup tone but not before.
  4. Release the Shift key when you see the gray Apple icon and the progress indicator (looks like a spinning gear).
During startup in Mac OS X 10.4 or later, you will see "Safe Boot" on the login window, which appears even if you normally log in automatically.
During startup in Mac OS X 10.2 through 10.3.9, you will see "Safe Boot" on the Mac OS X startup screen.
To leave Safe Mode in any version of Mac OS X, restart the computer normally, without holding any keys during startup.
while your in safe mode see if you can uninstall the drive software and reinstall it
Jul 21, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Will not open,then can't turn off
Try starting the PC in "safe mode (with network support) " by tapping the F8 key whilst it boots up and selecting safe mode from the menu. (Which bypasses your start-up items) If this boots up ok then the problem is a program that is starting up with windows, Check the start menu / programs / startup for any programs and remove them.
You can then downlaod a free program called "Spybot search and destroy" - run it, select "mode / advanced" - Tools - Startup and remove the offending item!
Apr 28, 2009 | Computers & Internet
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
