Taking apart a kenmore front load washer model# 417.43042200
  • Anonymous Mar 28, 2009
    how does one proceed to remove the outer panels to change the coupling?
  • 15,935 Answers
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
7. Remove the water pump. This is a small pump located in the front of the washer directly under the wash tub. It has two hoses leading to it. LEAVE THE DRAIN HOSES IN PLACE and remove the two retaining clips. The front of the clip pops off with a gentle pry of a screwdriver, while the back is in a keyed slot. Once released from the pump, turn the clip to remove from the slot. Pull the pump off the motor shaft and push it aside while leaving the hoses attached.
8. Remove the Drive Motor. Remove the electrical connection(s) first using care not to break any of the wires. Loosen the two 1/4" hex bolts that hold the Drive Motor retaining clips in place. Now, place one hand under the motor and lift gently while prying the top retaining clip with a screwdriver. This will release some of the tension on the clip and make it slightly easier to remove. (WARNING: the motor has some weight to it, so be prepared to support it when you release it). Once the top clip is released, the bottom one should come out fairly easy. The clips are similar to the ones that hold the water pump in place. They are inserted into a keyed slot and are slightly longer.
9. Once the Drive Motor has been removed, the Motor Coupling is directly behind it. There are two plastic three-pronged pieces with a rubber bushing connecting the two. One plastic piece is inserted on the Drive Motor shaft, while the other piece is inserted on the transmission shaft. You may have to use a screwdriver to remove the old pieces. Inspect both halves of the coupling for signs of wear. Replace if necessary (part #285753A).
10. Uninstall the motor mounting plate from the gearcase by removing the two bolts.
11. Remove the agitator by removing the center cap. Locate the center nut under the cap and loosen with a socket and ratchet. Lift both portions of the agitator straight up, exposing the gearcase center shaft. Remove the agitator clip and agitator washer from the shaft. NOTE: If there is a recessed square slot under the agitator cap, use a 3/8 inch to ½ inch socket adapter with extender to remove.
12. Now take the washer and lean it backwards so that you have full access to underside of the washer. Loosen the three bolts holding the gearcase in place. When you get the last bolt, loosen slowly as the gearcase will begin to drop from under the washer. Slide the entire gearcase and shaft out of the washer.
13. Remove the clutch and brake assembly from the top of the gearcase by removing the retaining clip. Do not forget to retain the washer that is under the clutch.
14. Inspect new gearcase assembly. Open the breather hole (covered by a dab of paint) using an awl or similar tool. Install washer on gearcase shaft and install clutch and brake assembly. Slide gearcase shaft up through the agitator shaft from under the washer. Hold in place and get one bolt started. Insert remaining bolts and tighten them all evenly.
15. Insert new coupling by tapping one piece onto the transmission shaft with a hammer. Use a dowel or something solid to tap the center portion of the coupling until the opening of the coupling is flush with the shaft. DO NOT hit the prongs or they will break. Do the same for the Drive Motor. Make sure you place the coupling on the correct side of the motor. If you forget, remember that the electrical connections are on the RIGHT HAND SIDE of the motor and that the coupling goes on the REAR shaft of the motor.
16. Place the rubber bushing over the side of the coupler that is connected to the transmission. Rotate the bushing so one empty hole is facing up and the other two are facing down. Now, rotate the coupler on the motor so the prongs will line up with these holes. It's a little tricky trying to get them to line of sometimes. I usually place the lower retaining clip in its keyed slot so that it is resting on the floor. That way, when you get the motor in place, you can reach down while holding the motor up and snap the lower bracket in. You will still need to support the weight of the motor until you get the top bracket keyed into its slot and snapped back into place.
17. Reinstall electrical connector to the Drive Motor.
18. Reinstall Water pump. You may have to rotate the motor shaft slightly to get the slot on the water pump to line up correctly. Make sure you re-install retaining clips.
19. Re-install agitator washer and retaining clip on the gearcase drive shaft and then re-install agitator. NOTE: DO NOT over-tighten center nut. You can crack or break the agitator.
20. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
21. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
22. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
23. Reinstall console.
It seems like a rather lengthy process, but it is a simple repair if you follow the instructions step-by-step. Read through everything thoroughly before beginning any repairs. I hope this information helpful.
NOTE: Under Line Item 10. - after you remove the motor mounting plate, make sure you disconnect the wiring harness from the the gearcase housing if it is mounted to it. Otherwise, you may damage the harness when you remove the gearcase assembly. Make sure you re-install the wiring harness in the fashion when repairs are completed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 16, 2010
Over loaded my front load lg washer and now it is not able to spin. Makes awful grinding noise. Is this something I can fix myself?
this hapened to me years ago it was an easy fix I took apart my washer ther should be a belt that almost looks like a belt off a car it probably went off track once you get it apart try spinning the belt you should be able to fix yourself
Jul 06, 2012 | Kenmore HE2 Plus Front Load Washer
Tip
Good directions. Thanks. However I tried just unplugging the washer for a few...
This advice is for Kenmore Elite HE and Whirlpool Duet FRONT LOADER washing machines displaying the "F06" error code. The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 – is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
I hope this information is helpful.
on Dec 10, 2008 | Kenmore Elite 45986 Front Load Washer
Wash drum won't rotate, how do you take apart?
taking apart this machine is very time consuming, the entire tub assembly has to be removed from the washer cabinet.Does the drum turn by hand?
Jun 09, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore washer sounds like a plane taking off while spinning...
yes the rear bearing is gone,,you may have caused the issue by using the wrong soap,,in a front load you must use he soap only,,,the cost to fix 500.00-700.00
http://www.washerwizzards.com
Dec 24, 2009 | Kenmore Washing Machines
Sears Model 417 stackable washer and dryer
The model that you provide is incomplete. However, if the washer loads from the top, they cannot be separated. If it loads from the front, they can.
Apr 10, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore front loading washer leaks
under the front panel ther should be techshet/ trouble shooting guide. and withthe front panelremoved perhaps you can see ewhere the leak is coming from
Mar 01, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore front loading commercial washer door will not opne
You need to get access behind the front panel, taking the top panel off is probably best. Then you can see the the door release mechanism and release it.
Feb 09, 2009 | Kenmore 43042 Front Load Washer
Kenmore Model 417.44072300 Front Load Washer
Kenmore Model 417.44072300 Front Load Washer Kenmore Model 417.44072300 Front load washer.
The drum is loose. I pulled the back panel off and the nut is tight behind the drum? could it be the bearing? do I need to change the whole drum? is this a common problem or was this do to abuse.
Jul 28, 2008 | Kenmore 46462 Front Load Washer
HELP!
i have the same onebut fridgeair but mine would only wash and nothing else and it turned out to be the motor was weak
Apr 14, 2008 | Kenmore 44042 Front Load Washer
A kenmore HE3t front loader MO. 11042932200
Suggestion: Plug off the wall first. Check to see if all the connections are firmly pushed in; during the job some could hv come loose. Check the wall outlet, your washer plug....whatever. Then plug in.
Sep 21, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
1,113 people viewed this question
Top Washing Machines Experts
