Question about HP Compaq Presario Cq58 250Sa 15.6-Inch Laptop Intel Celeron B830 1.8GProcessor, 4Gb Ddr3 Ram, 750Gb Sata 5400Rpm Hdd, Intel Graphics, Dvd-Ram, Integrated Webcam, Windows 8
Compaq celeron B830 WINDOWS 8 BATTERY NOT CHARGING
COMPAQ CQ58-261SA PICKS UP Charger beingconnected but does not charge battery. charger is ok -replacement also not charging battery - laptop brand new
It seems a few guys on here are missing the point, if you wish to check to see if you dc socket is faulty you need a good working charger and a multimeter set to DC volts.. Remove your battery and inside the battery compartment there are a series of brass looking contacts some are longer than others, the longer ones 90% of the time represent the Negative ( -V ) or Ground, Connect your black meter lead to one of the longer terminals and continue to probe your red lead on the other smaller terminals and see what reading you get.. if you see a small voltage thats dropping this normally means you are on the pins that connect to the output of the battery and as such capacitors on your main board are discharging (hence the voltage drop). if you see 3.3v on some pins this indicates the charging voltage and shows your dc socket is in fact working fine and that the problem is with your charging circuitry on the main board which is where i am at the moment, trying to find the relavant information to allow me to repair it, LOL hope this helps..
Posted on Sep 11, 2013
  • 2567 Answers
SOURCE: my hp compaq laptop charger is not working in the
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
DC Jack diagnosis:
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Posted on Sep 23, 2010
PABLOCSA
  • 1124 Answers
SOURCE: COmpaq Presario V5000 Battery will not hold charge
Problem with the motherboard connector that charge the battery.
Posted on Oct 03, 2008
farhangM
  • 64 Answers
SOURCE: Compaq nx 9020 battery charging problem
Damaged battery or internal circuit problem it is hard to to say. Bring your laptop to a repair shop. They can check the battery and tell you what the problem is.
Posted on Dec 04, 2008
FoxSysPCTech
  • 107 Answers
SOURCE: compaq HP 6715s Laptop not charging!
If you can determine that it is not the battery just going bad, then most likely it is a problem with the motherboard. I actually have this same problem, and have not been able to find a quick fix.
HP has a battery tester tool. If you are able to use this, then you are one step ahead of where my HP laptop is. I tried running this and it insisted that I did not have a battery installed, or that it was dead. If you have this same problem, then it looks like it might be time for a new motherboard.
In anycase, it might also be worth the time to try draining the battery completely and attempting to charge it back up. According to a few other sources, the laptop can sometimes get confused and think that a full battery is calibrated to be a low battery.
Posted on Jul 05, 2009
ted1430
  • 339 Answers
SOURCE: HP Pavilion dv1000 doesn't charge
You need a new system board unfortunately.
Posted on Oct 01, 2009
Testimonial: "it seems he's right "
Not working
It sounds as though your battery is dead. If you place it on charge, does it start then? If so, charge overnight and try with the charger unplugged. If it does not start, I think you have a bad battery. The yellow light indicates it is charging, but some notebooks do not start if the battery is bad, even if plugged in. You might try taking the battery out, and see if it works when plugged in. I hope this helps you find your problem.
Mar 31, 2014 | Gateway Ne56r31u Intel Celeron B830 X2...
Compaq 510
I think you should check the charger. If your charger is ok and battery is ok, then you should go to Compaq showroom and also must be checked that what problem in your Laptop. Why your PC don't charge?
Aug 16, 2013 | Computers & Internet
Battery charge light flashing amber
Ok, lets start slowly, do you have both a new battery and a new battery charger? If both attempt to use your old battery with the new charger. Also could be a bad charger or a shorted out battery...
Good Luck
Feb 13, 2013 | HP Compaq nx9600 Notebook
I have bought a new charger for my laptop, compaq presario cq56, and it is still not charging
Other expert is right--if not charger may be a loose socket where it plugs in or even a bad battery is possible.
Jun 12, 2012 | Compaq Presario CQ56-115DX Laptop
I Have A Compaq Computer But Got Some Reason It Cannot Be Charged.
Ok, your problem is not very well explained, I dont know if you are techy or nooby, also do not mention how old is the equipment. options:
1- Defective battery pack, HP has recalled a few battery pack models for them being defective, check with HP's website to see if yours has been recalled.
2- Defective or not working charger, HP and compaq chargers do not have indicator light unfortunately, so the only way to make sure is by testing the lead with a multimeter.
3- Broken cables within insulation, either power outlet to charger, or charger lead itself broken internally from being stepped on or run over by furniture. test them both.
4- Worse case scenario, if your charging light goes off and on every few minutes, then your power board may be going out or defective, battery not taking charge (dead), possible issue with mother board going bad.
Hope this helps a bit...
Aug 19, 2011 | Compaq Presario CQ35 Laptop Charger...
My hp compaq turned off by itself and won't turn on now, it won't even show the charging light when the charger is plugged in
Remove the PC labtop battery then re insert it again.
If still not charging check the charger connector if its connected as well.
If there was no problem in the charger connector,Check the charger itself.
These all what you need to check only,no problem in your labtop.
If still not charging means one of these :
1- The BATTERY may needs to be changed .
or
2- The charger may needs to be changed.
Jun 13, 2011 | HP Compaq 6720s Notebook
Hi i have some problem to my laptop battery it wont charging, but laptop charger is working fine, my laptop brand is compaq presario C700. i tried to charge my laptop in 2 hours after that i tried to turn...
Did ur laptop works or turn on when u plug the adaptor charger?
If ur laptop turns on when the charger is pluged in, u got problem with ur DYiNG BATTERY!
Better buy a brand new battery!
Nov 08, 2010 | Compaq Presario 700 470024-192 Notebook
Laptop battery wont charge?
It could be the battery needs replacing ... it shows that the battery is charging but it doesn't keep the charge .....
May 23, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq R3000
r u mention for battery light?if is it true,then the light is blinking because of your laptop want to make sure the power supply charge that battery.if it is in charging condition,the light on.but if the light goes off,that mean, the battery is already full.
But when u use adaptor without battery, the light will goes off because no charging session is in progress which has same behaviour with battery full(during battery full,no charging session occur)
May 12, 2009 | Compaq Presario R3000 Notebook
Battery not charging
Was it charging ok before the damage occured?
Oct 22, 2007 | HP Pavilion zd8000 Notebook
HP Compaq Presario Cq58 250Sa 15.6-Inch Laptop Intel Celeron B830 1.8GProcessor, 4Gb Ddr3 Ram, 750Gb Sata 5400Rpm Hdd, Intel Graphics, Dvd-Ram, Integrated Webcam, Windows 8 Logo
181 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
