Question about Radio Communications
Midland 38 uk cb radio
Im looking to tune my midland 38 radio up i would like to adjust the recive and also the sql also ,but im not sure wot pot to turn ,can anyone pls help kind redgards tom
5 Suggested Answers
ginko
  • 19396 Answers
SOURCE: radio frequecies
I will have a look around and post back what I find in the next 24 hours, if you can send any link you may have, that will help.
Try also posting a request on The CB Radio Talk Forum , it is the biggest forum on cb radio.
Posted on Apr 22, 2008
Communicomm
  • 90 Answers
SOURCE: wiring a midland 78/999 cb radio microphone
Pin 1 = white
Pin 2 = shield
Pin 3 = black
Pin 4 = red
Posted on Sep 29, 2008
One Wire
  • 126 Answers
SOURCE: converting a different brand of mic for a midland CB
This should be a typical Midland pinout. If you are using a generic 4 pin mic that is wired to cobra/Uniden, all you have to do is switch pin 1 & 2, then 3 & 4.
Not all mics are color coded the same with their wires.
Posted on Oct 06, 2008
  • 67 Answers
SOURCE: Midland alan 42 multi CB Radio
The user manual can be found in PDF form here: http://www.alan-uk.com/cb/manuals/42%20multi%20manual.pdf
Posted on Feb 27, 2010
How th adjust peek modulation on a midland 1001lwx cb radio
VR 2 is the pot you are looking for an now you need a modulation meter. Speak into the mic at the volume you will be talking on the radio. One one one one while adjusting for 100 percent anymore an you will begin distorting.
Jun 03, 2014 | Midland 1001LWX CB Radio
Adjust modulation pot midland 5001
because of lack of information on this radio I will have to say its stamped the same way as the 9001z which is top secret because even midland doesn't have a manual on it . If you look at the board with a magnifying glass you will see the variables are marked with like vr-1 might say mod, if that's the one then turn it all the way to the left for max mod. You have to look at each variable and next to it it will have what function it does .
Aug 05, 2013 | Midland 5001 40-Channels Base CB Radio
Midland 77-099 Modulation/AMC pot?
the one closest to the power transformer.RV 4 . Have some at a distancetell you which way is best.If you have a scope it would be better.you can also look at your meter on the front and write down the number the needle hits.the turn it the other way.you may wind up turning it back all the way .
May 26, 2012 | Midland 77-099 CB Radio
Modulation on 1001Lwx midland cb low need to know which pot to adjust
hello,
The limiter is what limits the modulation. Often times there is a pot that you can turn to adjust it. To get more power and swing out of your radio do this DM1 is the mod limiter RVM1 is the mod pot. Adjust this for maximum modulation. Spread the coils marked Lt5/LT12 just a little Spread LT7/LT11 a lot.
Regards, Tony
Apr 13, 2011 | Midland 1001Z 40-Channels Base CB Radio
Midland1000cb very littel audio w/stock or powermic,what is the limiter?
DM1 is the mod limiter RVM1 is the mod pot. Adjust this for maximum modulation Spread the coils marked Lt5/LT12 just a little Spread LT7/LT11 a lot
Hope this helps.
Mar 08, 2011 | Midland 1001Z 40-Channels Base CB Radio
Midland 38 pr27/97 cb
red to (+) , black wire goes to (-) on the battery, 50 Ohm Coax cable to an aerial mounted onto a flat horizontal metal ,so that the aerial is at 90 degrees to the flat metal its monted on. Adjust the aerial size to see a SWR less that 2
Jul 18, 2008 | Midland Radio Communications
Radio Communications Logo
142 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
