Question about Fisher and Paykel DEGX2 Dryer
Where is the thermostat located on a fisher paykel dryer model # deix 2
SOURCE: help with a noisy Fisher & Paykel dryer
I have the same problem. Replacing the front glides (two glides cost under $20 plus labor and service call). The second time it seems to be more than the front glides. Service tech says that it is the blower moving back and forth on the motor shaft. (Because of a worn indentation on the shaft..). Therefore, he says that I must replace the motor and the blower--parts cost approx. $290, plus labor and service call. Ouch! Also says that the plastic front support piece is worn. More money! So, I am looking at a new dryer instead of trying to patch up the one I have (it's out of warranty.)
Posted on Dec 22, 2007
  • 10 Answers
SOURCE: Lint is not going into pull out lint trap. The lint screen is torn and lint is collecting behind trap.
Poor air flow would be my guess. How long is the vent hose? Does it have more than one angle/turn before venting outside? Is the lint gathering around the outer edges of the door? Keeping the length of air travel shorter will improve the operation.
Posted on May 12, 2009
  • 20 Answers
SOURCE: fisher paykel dryer DE04-US6 just get a buzz sound
Open up the door and push the door switch and hit the start button and try to turn the drum by the baffle in the dryer and it it starts to go then you need a new motor.
Posted on Aug 20, 2009
Testimonial: "Held the door button in...pressed the start button...spun the dryer drum...and it started spinning...i.e. bad motor. nice work thanks"
SOURCE: Fisher & Paykel Auto Sensor Dryer stops & beeps constantly
Hi emkboyce
my Fisher Paykel auto sensor dryer keeps stopping and beeping, i have to stop it and and re start.
I had the same problem. I took it off the wall and vacuumed up all the lint from everywhere including around the back and including taking off the back and vacuuming everything I could reach inside. I then used a damp cloth to get rid of the rest of the lint/dust.
I thought I was wasting my time but guess what, the problem has gone.
Posted on Nov 08, 2009
SOURCE: need a manual for fisher and paykel drier ED56
try here http://kitchen.manualsonline.com/ex/thread/view/idThread/2200997
cheers Sandy
Posted on Jul 02, 2010
Where is the reset switch located inside dryer housing?
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Oct 06, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Dryer not providing any heat during cycle
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ Check posts on "Heaters" in this forum will work you through your problem
Jun 26, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Fisher Paykel DEGX1 no heat, therm tripping - used multimeter
May 31, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Dryer taking 3 hours to dry jeans and towels
Here is a tip that I wrote that will give you some things to check out...
http://www.fixya.com/support/r4312805-dryer_maintenance
heatman101
Apr 05, 2010 | Fisher and Paykel DEGX1 Electric Dryer
My Fisher Paykel dryer DEGX2 WAS TAKING LONGER AND LONGER TO DRY CLOTHES AND THEN JUST STOP DRYING-DOESN'T GET WARM. THE HEATING ELEMENT WAS REPLACED ABOUT 7 MONTHS AGO. IS THERE A RESET BUTTON IN THE...
Hi.
There is no reset circuit.
Parts that must be tested are high limit thermostat and timer board.
The timer board is replaced if it is visibly faulty, or if there is no problem elsewhere.
The high limit located near to the element is tested reading impedance with a multimeter set at Rx1. If there is no continuity , the thermostat must be replaced.
Before testing parts check the lint filter, and ensure that air ducts are clean.
Regards.
Nov 13, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and paykel 460 dryer not producing any heat ? heating element ok
one of the 2 thermostats have failed, most have a reset button you can push pin into this will test if it is faulty, they are normally located near the heater element, you might also be able to tell with the reset one being slightly scorched45d764d.jpg
Aug 19, 2009 | Fisher and Paykel Dryers
Fisher Paykel degx1 electric clothes dryer
Thermostats, the dryer temperature control switches, are controlled by the temperature inside the dryer or by the heat of the motor. One or more thermostats on the panel can be adjusted to control the temperature in the dryer. Operating thermostats sometimes stick, causing control problems. These thermostats are usually positioned near the exhaust duct bulkhead or the fan housing of the dryer. Remove the back panel of the dryer to get at them.
Before you make any checks, try tapping the housing of the thermostats lightly with the handle of a screwdriver. This may jar the contacts loose. Temperature control switches are located behind the dryer control panel, and the panel must be removed for switch testing or replacement. Here's how to test and replace the thermostat:
Step 1: To check the control panel thermostat, make sure power is off to the dryer. Test the thermostat with a VOM set to the RX1 scale. Clip one probe of the VOM to each thermostat terminal. If the meter reads zero, the thermostat is working. If the needle jumps to a high reading, the thermostat is faulty and should be replaced.
Step 2:
 If necessary, replace the thermostat with a new one of the same type. Connect the new thermostat the same way the old one was connected.
Step 3: To check an operating thermostat, first make absolutely certain that the power to the dryer has been turned off and the dryer is cool. Then disconnect the leads to one side of the thermostat. Test an operating thermostat with a VOM set to the RX1 scale; clip one probe to each terminal of the thermostat. Disconnect the leads to one side of the thermostat so that the meter won't give a false reading. If the meter reads zero, the thermostat is working. If the needle jumps to a high reading, the thermostat is faulty and should be replaced.
Oct 10, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Won't heat
Not sure how old your dryer is but earlier models had the element around the door.
As a rookie you would have to remove the rear cover, the drum, the belt around the drum and then you would sse the element held in place by clips on the inside of the front panel. The thermostat would placed not too far away. I have just purchase a new dryer (very recent model) and was told the element is located away from the door. I guess I won't know until I have a problem with mine.
As usual, heed the warnings about electrical appliances and the risk of electrical shock.
Always unplug the appliance from the power point as you can still get a stock on the neutral connection even if the swith on the power point is turned off. (tunrs of the active connection only).
Feb 07, 2008 | Fisher and Paykel DE06 Electric Dryer
Dryer Fisher paykel
the biggist problem with dryers and drying is the outside vent being plugged. next thing is it gas or electric. electric i would think cycling thermostat. gas would be coils or thermostat. this is asuming you do have heat
Jan 18, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel DEGX2 Dryer Logo
32 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
