DSP A 1092 keeps tripping when switched
When switched on there is a click sound while switching from pre amp to power amp. sometimes it switches on but then trips and shuts down.
    New Friend:
    Problem Solver:
  • 5 Answers
Try unplugging each set of leads 1 set at a time,and after each set of leads are unplugged switch it on as it may be a set of faulty leads,it sounds like the safety cut out is coming on and switching off the power to save your system blowing due to bad or broken phono leads or speaker cables.it could also be that you could have blown your output transisters or something else thats causing the saftey cut out to cut off the power,also make sure there are no loose connections inside your mains plug as this would cause the same thing.
Posted on Jan 08, 2013
petraman7
  • 1175 Answers
SOURCE: gem sound exa 3950 amp
Hi...
If it's a straight-up power switch then it will need to be replaced if it works off a relay then the relay is gone.
website
http://www.gemsound.com/contact.html#
Posted on Mar 24, 2009
paulm10
  • 73 Answers
SOURCE: Behringer EP2500 trips immediately when turned on
Power supply section is overloading probably because of audio power amp problem.
Paul
Posted on Jun 13, 2009
SOURCE: Yamaha DSP-A2070 intermittently fail to output audio to speakers
Probably selector switch when you turn to CD mode. The ball bearings inside the switch make poor connection resulting in intermitant problems to either speaker. Yamaha knows the selector switch is defective but has stayed silent. I've had mine replaced for $144.00 Can and it works AOK now. Different switch of course. I've had my problems with that switch for a long time and it was after a few years that a knowledgeable technician knew of the problem. Poor support by Yamaha! I'll never buy a Yamaha product again nor will my relatives and friends. Do the calculations and assess whether the cost of the switch is worth the value of the receiver. I think it is worth it as the receiver when it works is excellent. It is at a stage now when other problems could creep in though including corrosion on the boards and solder joints so have the technicians do a entire quality check at the same time...
Posted on Jul 02, 2009
  • 4234 Answers
SOURCE: I have a phonic powerpod 7. the speaker
In bridge mode, the left and right amplifiers are in essence connected together. Typically, the speaker connections are to the positive connectors for each channel for this mode. WIth the speakers still connected, you essentially shorted the outputs to ground and smoked the output section. The unit will detect this now and not turn on the output section. Your unit is in what is usually called "protect" mode. This unit will require repair. Expect to have the output transistors replaced at the very least. I would estimate around $16-$40 for parts.
Dan
Posted on Jul 03, 2009
tbreeze47
  • 3083 Answers
SOURCE: yamaha dsp-a492 amp keeps switching
Amplifiers have protection circuits that sense current overloads, and especially internal faults, and theyt shut themselves down to prevent further damage to the unit, until it can be troubleshot and fixed. They're designed to allow minimum damage to the unit, and the cause of the overload must be found and fixed by troubleshooting the unit systematically. Sometimes you can get lucky and ohm out a suspected power transistor or IC regulator and replace it successfully, but most of the time a scope is required.
Take it to an audio repair shop and get an estimate first, but know that they do charge by the hour, and it can get a bit expensive.
I noticed this same problem was posted in a couple of forums on the net, but they never got a solution or followed up, so service is in order.
Good luck, and hope this helps.
Posted on Oct 30, 2010
NAD C320. Only one channel sounds. Problem with the volume control?
Did you try to switch the loudspeakers? Before changing anything always lover the volume and switch off the amplifier.
Assuming you tested already different inputs, you can be sure no cable from signal source is out or defect. (or did you nit check that first?).
When the amp is switched off, disconnect the speakers and switch left to right and right to the left output.. If the other speaker is quiet now, you are sure it is in the amp. Still his can be anything.
You can check the connections between the pre and main amplifier on the back side. When you have an extra set of interlink cables, perhaps you can cross the in and output there too. Take care every time you change something, lower the voltage and switch off the amplifier. Sudden clicks when switching on or changing anything can damage the amp and or the speakers.
Perhaps when you checked this you can locate where the problem is? Speaker, speaker cable, power amp, pre amp, (only a part of the pre amp.
Nov 12, 2013 | NAD C320 2-Channel Amplifier
YAMAHA DSP A1 WONT SWITCH ON
Popped power supply hi sorry if you can't get it on trying to do a diagnostic won't matter if you can open the back check where the power is going into you will c a power supply board a cap has carrots on it check if any of them is popped up
May 20, 2012 | Yamaha DSP-A1 Receiver
My machine flicks the mains switch as soon as i turn it on, both washing and drying. it first flicked the safety switch about halfway through a dry load...what could it be?
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
This sounds like a heater issue since it's tripping the power on both the wash & dryer, in events of overheating the machine will trip your power for safty & to prevent the risk of fire however since you mention that it trips the power as soon as you switch it on you could have a blocked pump or burnt out motor too if your finding that the machine is tripping the power earlyer & earlyer each time you retry i would focas on the motor or the pump 1st
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys..
remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Apr 22, 2010 | Hotpoint Ultima WD72 Front Load...
No sound output
Known problem w/Onkyo. Resolder Q710 transistor on DSP board.
Onkyo is aware of this problem.
Apr 11, 2009 | Onkyo TX-DS575 Receiver
Dsp-a1000 dead
output stage problem, systems trips due to protection. have the power amp transistors checked. the rotating of function switch is normal, its like a routine system check
Jun 22, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha DSP-A2070
Check the 'front mix' switch on the back, set it in off; main level on max.
Feb 29, 2008 | Yamaha Audio Players & Recorders
Amp powers off after switching on
The DSP-A1 has an internal self diagnostic program which you can access from the front panel. The service manual shows how to do it and what the readout codes mean as far as the fault that caused the trip. Service manuals are cheap and readily available on the web.
Mar 15, 2007 | Yamaha DSP-A1 Receiver
Yamaha dsp a2
Check the A or B switches it could be they are turned off!
Sep 28, 2006 | Yamaha DSP-A2 Receiver
55 people viewed this question
 Grubhead
Grubhead
