Question about HP MP3130 Multimedia Projector
All lights and projection working but keeps on searching for input as if it doesnt see input. tried a different laptop with same issue
  • HP Master
  • 3,904 Answers
Did you first set your computer to display on an outside source? You can do this by pressing function 4(the FN key and the number 4) This will let you toggle display types to be used.
Posted on Jan 07, 2013
When I try to play a DVD through the player the on screen picture has a scrambled look sort of like when your DIrectv signal begins to go due to a storm. I changed players and tried a different
A few questions for you that might narrow down the issue.
Where is DVD connected at?
Have you tried it on all rear inputs?
Where is Direct Tv connected to at the set and does it work normally?
If input it (the player) works with something else connected (rules out the input used) then I would suspect some setting in the players (identical model brand?) is set wrong.
May 20, 2012 | Toshiba 53HX71 53" Rear Projection...
No s-video connection
the set is not capable of this type of connection
Apr 15, 2012 | Toshiba 61HX70 61" Rear Projection...
Philips projection dvi problem
The set is old enough (based on model number indicated here) the DVI input (supprised it has one) it will not work with newer equipment.
Apr 15, 2012 | Philips 55PW9363 55" Rear Projection...
I have a 55 in mits WS55511 that is 9 years old. I turned the tv on and the green light comes on and stays on, but I have sound on every channel but no picture.
I'm sorry that the TV is not displaying picture on the screen. Please follow the troubleshooting steps and check the operation:
Please make sure that the connections are secure and proper.
Try connecting a different video source like DVD player or VCR and check the operation. If it works with another device, the issue might be with the input device currently.
Also try connecting the device to a different port in the TV if no other devices are available. If the issue persists, try with a different cable.
Perform a power resetting and check the operation. To perform the power resetting, unplug the TV from wall outlet for more than 2 minutes and then reconnect it.
Thanks for understanding. Please let me know if you require any clarifications/additional help.
Sep 01, 2011 | Mitsubishi WS-55511 55" Rear Projection...
The tv was re conneceted after 2 wks. It played
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 18, 2010 | Sony Grand WEGA KDF55E2000 55" Projection...
My projection tv makes everything look green
Your set is totally different and it couldn't be a convergence issue. It appears to be an HDMI connection issue. Cleaning the HDMI terminals thoroughly will resolve the problem.To verify, use a different connection or hook a different device to a different input connection on your TV.
In case the problem exists in all of the inputs please let me know.
Dec 10, 2009 | Televison & Video
I am trying to fix my daughters Toshiba laptop Satilite A135-S7404. When I turn it on it says enter password in A ble box with A black screen. Help Please
It is a prompt for BIOS password, Someone must have set it up in the BIOS menu. there are ways to reset it. Different models have different ways for resetting. Contact customer care if in warranty. If not try opening it up and take out the CMOS battery and press the power button for about 5 seconds.then switch it on.If this doesnt work try keeping the laptop without battery for sometime.This should solve the issue..
Sep 15, 2009 | Toshiba Computers & Internet
Replaced bulb stil issues
In most projection televisions if a solid light comes on there isn't anything wrong the bulb there is a problem with one of several cards in the back of the television. I'd check for over heating damage on your imput cards, the Controller card that is connected to said input card, or the relay card that controls the tube output. Keep in mind you did order a part off of Ebay which is untrustworthy in and unto its self.
Sep 01, 2008 | Optoma RD65 65" Rear Projection HDTV
PC videocard-HDMI input not working any more.
There is acompany that makes such a converter BUT it is getting hard to get because HDCP (hd copy protection) can be bypassed with it. I will get the company name for you but search ebay for a hdmi to component converter. It works pretty well. You may need to get the HDMI to DVI converter cable for $8 as well.
Jan 28, 2008 | Akai PT5598HD 55" Rear Projection...
Nintendo 64 problems
First try to be absolutely sure that the TV input jack is not the problem. Try hooking up the N64 to a different TV, or you could try to wiggle (gently) the connector to the input jack.
I have two of these N64's that the kids play with, and had the exact same problem. The input jack is loose on our TV, and we had to tape the wires at a certain angle to keep the connection!
Dec 31, 2007 | Nintendo 64 Console
HP MP3130 Multimedia Projector Logo
51 people viewed this question
Seeker5211
Seeker5211
