Question about Air Tools & Compressors
Why does pressure in captive air tank keep getting higher?
I checked and set the pressure in my captive air tank by the proper procedure to 40 pounds( shut off pump, drain system of all pressure , check tank pressure, set to 2 pounds below cut-in pressure of pump). After a short ime noticed that my water pressure would drop to almost nothing before the pump kicked on; a classic symptom of the pressure in the captive air tank being too high. When I checked the pressure in the tank again, by the same method (pressure drained from system) it read 55 pounds. I thought I screwed up so I readjusted the pressure to 40 pounds. The next day the same thing occurred. I checked the pressure in the tank (again, after draining the system) and the pressure was back above 50 pounds. Yesterday I set the pressure at 10 pounds. The water pressure in the house seems good now. I checked the pressure in the tank (again after draining the system pressure) and it's now at 13 pounds. Can someone please explain how the air bag is gaining pressure???
Krazytech
  • 725 Answers
SOURCE: I have a whirlpool front load washing machine model WFW8300SW00
Hay Crab.
what I have found is that the washer thinks it is not pumping out .. if your drain pump is clearly removing the all the water in a good time... then the problem is your pressure switch...it is telling the computer that it still has water in the machine...
replace the pressure switch and it will solve your f21 error.
It is a round unit on the right hand side on top...with a tube and wires going to it...let me know if it helps
Posted on Apr 05, 2008
SOURCE: whirlpool duet sport wfw8300sw00 f-21 error
Unplug the machine. Unscrew the 3 screws under the front edge of the washer. The service technician manual is attached to the panel that slides down and off. Find F21 code. See suggested procedures. Note: My drain pump filter had a baby wash cloth in it along with some change that was disrupting the flow. It is exceptionally easy to remove, clean, and reinstall. Just line up installation notches when reinstalling. Whirlpool should have mentioned this filter in the User & Care Guide, but I could not find it anywhere in there.
Posted on Mar 20, 2009
  • 59 Answers
SOURCE: Drain valve in Porter Cable air compressor
this valve works backwards, you screw it out to stop airflow. If that doesn't work, replace the valve.
David
Posted on May 25, 2009
  • 69 Answers
SOURCE: COMPRESSOR PUMPS UP TO 40-50 psi KEEPS RUNNING.
Most likely the pump is leaking somewhere, if the new hose is not leaking. Hoses don't just burst without showing signs or wear and tear, i.e. cracking and splitting. The pump was probably having problems, and this caused the hose to burst. Look for signs of leakage, and if you can't find them, the pump is shot.
Posted on May 27, 2009
  • 256 Answers
SOURCE: Drain valve on air compressor won't open or close
I would use an ajustable wrenck to try and open the valve. Being at the bottom and in the water, this is a common occurrence. to replace the valve, there is a Hex nut outer fitting (part of the valve) that you have to remove right by the valve "T" handle. Put a wrench on this and remove the complete valve. It too will be very hard to remove. When you install the new valve, use some anti-seize compound to make future removal easier.
Posted on May 31, 2009
Should Ebrs watertech pressure pump come on and shut up with use of tap
No. It sounds like you have lost your air bubble or air bladder in your captive air tank. Without the elastic effect of an air bladder or air bubble in your captive air tank, the pump will come on right away, trying to keep up with demand for water. You will have to either add air to the bladder in your captive air tank (it looks like a car tire valve stem) so the pressure is likely in the 35-50 lbs range. You may have to flush a toilet or have other water usage going on when you will the tank with air or you will be fighting your water pump. Or, turn the pump off, flush a toilet, and then will it with air to the approximate pressure, then turn the pump on for normal operation. If the problem comes back, you will need to possibly replace the captive air tank and or bladder, which if ruptured is letting air dissolve into the water, leaving you again with not elastic bubble to act as an accumulator.
Jan 23, 2018 | Plumbing
How much air should be in the bladder bag in a 36 gallon captive air tank
The air pressure in the tank should be two psi below your pump cut-on pressure (i.e. 18 psi with 20-40 psi pump cut-on/cut-off or 28 psi with 30-50 psi pump cut-on/cut-off).
Oct 03, 2017 | Plumbing
Repair help
If it has an automatic pressure regulator ( cuts out at set pressure) adjust the pressure higher. They are only meant to pump up tyres to a max set pressure probably at the 40 psi as most tyres only need 35 psi max.
May 31, 2013 | Air Tools & Compressors
DeVilbiss air compressor will not build pressure
Does it have an intake air filter? Has the compressor been properly maintained? Oil less? It may have worn out rings and or valves
Aug 24, 2017 | Air Tools & Compressors
Campbell hausfeild air pump 26 gallon runs for an hour and only produces 40 pounds of pressure what could be the problem
Head valves. Some units use simple metal strips (reed valves) while others are just a bit more complicated. Could be either a broken valve or a stuck valve. The other possibility would be a stuck one way check valve that goes into the tank and keeps the pressure from going back into the pump.
Jul 15, 2011 | Campbell Hausfeld Air Tools & Compressors
I have a flotec shallow well pump i can not get it to pump the water it stays at 20 pounds did i hook it up wromg
check your pressure tank. It sounds like it is water logged. This means there is no air pressure in it. If you're cut in pressure is set at 30 pounds you must have 30 psi of air pressure in the pressure tank.
Oct 01, 2010 | Flotec 3.4 Hp Floodmate Submersible Sump...
PSCZ Residential Irrigation Controller issue - reset it and it reverts back to time on the display that does not exist like 9001 etc... also wondering.. the pressure that comes out of the sprinklers...
I would replace the controller. As for your pressure, you can adjust your pressure switch to a higher pressure. A 40-60 psi setting gives an average pressure of 50 psi.Keep in mind that your expansion tank should have an air pressure setting 2 psi lower than your cut in pressure. There is a schraeder valve at top of tank where you can pump in air. Change the tank pressure before you adjust the press switch, which has simple instructions on the inside of the cover of the switch.
Nov 16, 2017 | Plumbing
No more then 30 pounds of presure and wont shut off. Flotec water
If the pressure does not get pass 30 psi, then check for leaks along the pipelines and on the tank itself. An air leak on the top portion of the tank can cause the pressure not to trigger the pressure switch. Use soap bubbles to detect any air leak. Although a stuck pressure is not more likely the problem, check it also.
Aug 31, 2009 | Flotec 1/2 Hp Stainless Steel Waterfall...
Air Tools & Compressors Logo
44 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
