Question about Samsung ES30 Digital Camera
Samsung ES30 lcd not working anymore
My lcd on my Samsung ES30 digital camera dont working anymore, i can take picture but i can't see anything when i take picture or when i try to navigate in menu
    Genius:
  • Samsung Master
  • 1,019 Answers
There is no user cure for this, needs to go to repair shop.
Posted on Jan 26, 2013
MJS_1
  • 150 Answers
SOURCE: samsung digital s73 camera
Hi, there are many reasons why a camera may produce less then sharp pictures.
1) Dirty, oily or damaged lens: Check for dust and fingerprints.
Clean lenses with extreme caution, using dry lens paper.
Use only minimal pressure and gently wipe from the center
outwards, NEVER in circles.
If the lens is really dirty, ask a professional photo dealer to
clean it for you as a free courtesy.
2) Check to see if the auto-focus is working correctly, this could
be an electronic or mechanical problem requiring servicing.
Focus the camera on sharp image at various distances,
to see if it responds by moving the lens.
3) Can you focus the camera manually?
4) Can you focus by moving the camera back and forth
in regards to the object of interest?
5) Is the auto-focus feature somehow disabled in the menus ?
6) Are the batteries up to snuff, they may be strong enough to
turn on the camera, but too weak to move the focus motor.
7) Is the subject you are trying to focus on out of the
focus range of the lens: i.e. too close ?
8) Is the subject you are focusing on too bland, with insufficient
detail to activate and lock the auto-focus.
9) Do you have enough light for the auto-focus to operate.
10) Does the flash unit project an red pattern to help with
focusing.
11) Are you mistaking sharpness (focus) for depth of field.
In low light conditions, the lens iris opens wide, just
like your eye, to let more light in.
This results in a loss of focussed depth of field. This
means that focusing becomes much more sensitive
and critical, such that (when) the main subject is in focus,
everything behind and in front of the subject is not.
This is a theoretical limitation of all optical lenses:
The greater the focal length and the greater the aperture,
the shorter the depth of field.
This can actually be very beneficial when shooting a
portrait: Focus on the eyebrows, blur the background,
or it can be very detrimental: When trying to magnify
a butterfly on a tulip in low light conditions, getting
everything in focus is impossible.
12) Are you mistaking motion blur with lack of focus,
due to slow shutter speeds.
13) Are you shooting in very low light conditions,
causing the picture to become more noisy,
due to the way the digital camera sensor works.
14) I you come up empty on all these suggestions,
you probably have a defective camera and it is
warranty time:
a) Defective electronics
b) Defective auto-focus mechanism
c) Defective lens, loose internal elements
d) Detached sensor chip
.... etc
Try to isolate the problem. Try to manually and
automatically focus on a wide range of subjects,
at various distances, in bright daylight conditions.
If you are still unable to focus the camera,
it is probably defective and requires replacement
or servicing
BTW
Quick review of the internet, indicates that
this particular model is notorious for high battery drain
and battery connection problems. This may be the cause
of poor auto focus as indicated above.
Also this camera has insufficient internal memory, and
and an add-on memory card is required. It is possible
that without the memory card, the camera is defaulting
to a very low pixel resolution, in order to save memory
space, thus creating the appearance of poor focus.
The nominal resolution of the camera = 7.2 Mega Pixels
is respectable for such a low cost camera, but the
reliability reviews are not good.
Martin
Posted on Apr 24, 2008
plaintiger
  • 9 Answers
SOURCE: The flash will not work on my Samsung S860 Digital
the S860 has three flash modes in which the flash only fires under certain conditions.
- in Auto Flash mode and Auto & Red Eye Reduction mode, the flash will only fire if the subject or background is dark; otherwise it won't flash.
- in Slow Synchro mode, the flash only fires when the camera's using a slow shutter speed.
if you have your flash mode set to any of these, the flash will only fire when the camera determines that flash is needed; otherwise it won't fire. to have the flash fire all the time and automatically vary its intensity according to how much light is needed, set the flash mode to Fill flash; to turn the flash off altogether (so that it won't fire no matter what), set the flash mode to Flash Off.
for all the details on the S860's flash modes, you can download the user manual here and refer to pages 28 and 29.
hope this helps...
Posted on Mar 08, 2009
tbreeze47
  • 3083 Answers
SOURCE: My samsung L830 digital camera does not focus
Sounds like the infrared circuit is bad. In that case, it will need repair. Only other alternative is to try manual focus in the meanwhile.
Posted on Feb 19, 2010
  • 102366 Answers
SOURCE: i have the usb cable
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Posted on May 09, 2011
hmerchant110
  • 7191 Answers
SOURCE: Samsung ES30 digital cacmera can I
You can transfer files directly from the camera to the computer without installing any programs.
When you connect the camera to a Macintosh computer, the computer recognizes the camera automatically.
To transfer the photos, please refer to the steps as shown in the attached image:
For more details, download the complete instruction manual by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Thanks for using FixYa.
Posted on Jul 01, 2011
Samsung es30 driver
You don't need a driver.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Nov 17, 2012 | Samsung ES30 Digital Camera
Cd drivers for samsung es30
Consider NOT using a driver.
Oct 25, 2012 | Samsung ES30 Digital Camera
Cd drivers for samsung es300 camera
Hi! I've miss placed my data cable for my Samsung
Take your camera to a computer shop or digital camera shop and thay will supply you with the correct cable.
Oct 23, 2012 | Cameras
The picture taken in samsung es30 when transfered to PC doesnot show dat & time. How to rectify it?
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Aug 03, 2012 | Samsung ES30 Digital Camera
My Samsung 5x ES30 Zoom Did Not Operate Normaly
Ensure you're using new batteries and try again.
Apr 02, 2012 | Samsung ES30 Digital Camera
How do i delete pictures from a samsung ES30 digital camera
To delete pictures, follow these steps:
To delete single file, 1. In playback mode (while viewing you pictures or videos), select a file and press the {Fn} key 2. Select YES to delete the file
To delete Multiple files, 1. In playback mode, press {Fn} 2. Select Multiple Delete. 3. Select the files you want to delete and press {OK} Press {OK} again to cancel your selection 4. Press {Fn} 5. Select YES
To delete all files, 1. In playback mode, press {MENU} 2. Select File Options > Delete> All > Yes
Sep 14, 2011 | Samsung ES30 Digital Camera
I have the usb cable for my samsung es30 but when i plug it in it doesn@t work, how can i copy my pictures
May 09, 2011 | Samsung ES30 Digital Camera
I dont know how to turn on the optical zoom for the samsung ES30
If I may recommend an alternative solution, it's better to leave off digital zoom. You can do the same thing on your computer by loading the image and then increasing the size. Digital Zoom spreads the image over more pixels, but doesn't give you a better image.
This video will help explain more.
Mar 06, 2011 | Samsung ES30 Digital Camera
Samsung ES30 Digital Camera Logo
89 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
