Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Water filter light won't reset itself
I've replaced the filter.  The water is flowing freely, so I'm pretty sure I've replaced correctly.  But the light stays red (indicating the filter needs replacing)  what must I do to make it go back to green?
  • sas7120 Feb 14, 2009
    I just replaced the water filter in my Kenmore side by side I know it is working , but I cant reset the light. I did what it said in the book, but nothing happens. Can you help solve this problem
    President:
  • Whirlpool Master
  • 2,651 Answers
Look closely at the panel it will state which buttond to hold for 3 secs to "reset " filter light
Posted on Jan 20, 2009
Dometic freshjet 2200 air conditioning unit working intermittently and displaying a temperature sensor error red flashing light - any tips please Thanks Mark
Make sure your water condensate drain line is flowing freely and not plugged up. Also make sure you have a fairly clean air filter installed.. before you look for more difficult answers.
Aug 07, 2016 | Dometic Heating & Cooling
I have a red light indicator on top of the water icon
Pretty simple - that typically means replace the water filter.
Jan 11, 2015 | Refrigerators
Why won't the hot water empty into the coffee pot?
Make sure your caraffe has its lid on , and check the bottom of the filter. it usually has a valve preventing coffee from leaking when you remove the caraffe. the lid pushes the valve back open when you place the caraffe back into the machine.
Jul 10, 2012 | Cuisinart DCC-2200 14-Cup Coffee Maker
Kenmore washer model #110.28882790 is very slow to fill with water. We've checked and cleaned the hose filters. Is there some kind of water sensor? Or hidden filters?
Remove the water line from the INLET valve and start the machine , if there is no proper flow of water then the inlet vavle is not working to open , the filter on the vavle is clogged or the inlet filter is blocked. Also check the voltage on the inlet valve to make sure that the controller unit is outputting correct voltage.
If not replace filter , valve to ensure that the drum get best flow for filling.
Aug 22, 2011 | Kenmore Washing Machines
I changed my filter, PUR 4396841 and now it is vibrating when I stop dispensing water. Any suggestions? Do I have it installed correctly?
The vibration is a tiny bit of "water hammer." Previous to your filter change, the water flow was restricted, and therefore incapable of causing water hammer. Now that you've changed the filter, the flow is large enough to cause a little water hammer when you shut off the flow.
How to fix: shut off the flow SLOWLY. Water hammer is caused when the flow of water is shut down quickly. This is just as true with large flows (as in fire engine pump panels), as it is in itsy bitsy
filtered water lines & filter housings.
May 13, 2011 | Whirlpool 4396841 Whirlpool Refrigerator...
The water dispenser on the door stopped flowing in mid stream. A day later, still no water. Took out the filter and water streamed just fine. Got new filter put in, and again no water. Took it out and...
Sounds like a "solonoid" is not functioning, either a wire is loose, the switch behind the the "push" device is bad, the "push" device is jammed, or the solenoid valve is bad.
First Try moving the "push" in different directions, including pressing pretty hard.
If you hear a "click" it's probably the solenoid valve. The are simple to fix, buy you will probably need a set of instructions to replace it. Look on line under your Refrigerators manufacturer for the part and instructions......Maake SURE the unit is unplugged before touching wires!
Hope this helps.....
John
May 12, 2011 | Samsung RS2534 Side by Side Refrigerator
My neff is not giving any water, I have changed new filter still light shows fix filter?
If the indicator is a light or series of lights, the light will change from green to yellow. This tells you this it is almost time to change your filter. It is recommended that you replace the filter when the status light changes to red, or when water flow to your water dispenser or ice maker noticeably decreases.
Hence, it's advised to check your water flow (pressure) is perfect. If your water flow is normal the indicator display will automatically be gone and also you will get water also. Please also check any tints orkinks in water hose, if it's correct it. Thanks, Helpful?
Feb 12, 2011 | Neff K3965XO Side by Side Refrigerator
Why would the fuel filter light be staying on
I am pretty sure that there is no fuel filter light, there is a fuel low level indicator that turns on when the fuel is low, if the fuel is not low then the sender unit is broke.
This indicator is red or dark orange and look like a gasoline pump.
Jan 19, 2011 | Toyota Pickup Cars & Trucks
Want to know when and how to replace water filter on a ge side by side refrig
The water filter status light or indicator, present on some models, will help you know when to change your water filter. The light, or indicator, is located either on the temperature control panel in the refrigerator compartment or on the dispenser control panel on the freezer door.
The indicator will be one of two styles.
If the indicator is a light or series of lights, the light will change from green to yellow. This tells you that it is almost time to change the filter. It is recommended that you replace the filter when the status light changes to red or when water flow to your water dispenser or ice maker noticeably decreases.
If the indicator resembles a stack of bars, the bar height will decrease and the status display will change from "Good" to "Order." This tells you that it is almost time to change the filter. Replace the water filter cartridge when the water filter status display changes to "Replace" or when water flow to your water dispenser or ice maker noticeably decreases.
If a filter status light/indicator is not present, the filter should be changed at least once every 6 months. Your filter may need to be replaced more frequently depending on your usage and water quality.
If the water flow to the water dispenser or ice maker noticeably decreases before 6 months have passed, you may need to replace the water filter cartridge more often. Decreased water flow is a sign that the filter is clogged and needs to be replaced.
If the filter is clogged and you are not able to immediately replace it, remove the filter so the water system is in bypass mode. With the filter removed, the water system will continue to operate, bypassing the filter, and the clogged filter will not cause slow water dispensing or low ice production. However, in order to have filtered water, you will need to install a new filter.
The filter status display will help you know when to change your
water filter. When the display reads 10%, order a new filter. It is
recommended that you replace the filter when the display reads 10% OR when water flow to your water dispenser or ice maker decreases.
The filter should be replaced at least every 6 months depending on your water quality and usage.
Step 2
Press the eject button to release the filter from the base grille.
Step 3
Pull the filter straight out.
Step 4
Turn the cap counterclockwise to remove it from the filter. IMPORTANT: Do not discard the cap. It is part of your refrigerator. Keep the cap to use with the replacement filter.
Step 5
Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
Step 6
Remove the protective covers from the O-rings. Be sure the O-rings are still in place after the covers are removed.
Step 7
Push the filter into the base grille. The eject button will pop back out when the filter is fully engaged.
Step 8
Flush the water system. Use a sturdy cup or glass. Depress and hold the
water dispenser lever for 5 seconds, then release it for 5 seconds. Repeat this process until water begins to flow. Once water begins to flow, continue depressing and releasing the dispenser lever. Hold down for 5 seconds and then release for 5 seconds. Do this on/off process for about 2 minutes. This will flush air from the filter and water dispensing
Hope this helpout in changing the water filter......
Aug 10, 2010 | GE Refrigerators
My navigator is suctioning however when it hits a wall it simply stays there and won't turn around any more.
With these automatic pool cleaners, it is often a problem with the water flow not being correct. Test your cleaner to make sure that the water flow is coming out properly. Adjust the water flow gauge if necessary. Make sure that the shoes and wings are in good shape and not functioning properly. Make sure that the rear screen if clear or debris. Make sure that the cone gear rotates freely in both directions. If none of these work, you might have to replace your gear box.
Jun 19, 2010 | Hayward Navigator Pool Cleaner
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
388 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
