Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Cant update firmware belkin g plus
Doing a firmware update for my Belkin G Plus (F5D9230-4) results in a connection reset interference in both google chrome and firefox. I go to upload the new firmware, a blue bar appears indicating that my process is being started, then it almost immediately jumps to an error saying my connection was reset. What can I do? Is there a way to view my routers OS though an ethernet cable so I can manually change the html code for the update process?
  • 7,627 Answers
  • Matthew Javelet Jan 06, 2013
    It did not. I should elaborate that I've tried all official sources from Belkin and they do not help, nor do any relevant issues online help me either. This is why I'm asking for assistance, not a support webpage. Thanks anyways.
3 Suggested Answers
  • 699 Answers
SOURCE: hey i have a Belkin wireless g plus mimo router.
The problem you are describing is typical of Firewall issues: you can try to resolve the issue by trying the following in order: 1) Disable any firewall/anti-spyware software on your PC/Laptop (or try using a different 'working' PC or Laptop 2) Disable all firewall on your wireless router 3) Disable all firewall on your adsl/cable modem
Once you determine where the problem is, re-enable the firewalls/filters as required and add Exceptions for the appropriate IP addresses and/or Ports to enabled Web browsing (in general do not block port 80 or 8080).
Hope it helps.
Posted on Jul 18, 2010
KasperHalvas
  • 69 Answers
SOURCE: I have a Belkin Wireless
Make sure the IP of the Router and the IP of the MAC is in the same scope.
E.G. Router: 192.168.1.1 Subnet 255.255.255.0
Mac: 192.168.1.5 subnet 255.255.255.0
Typically the router acts as DHCP-server and distributing ip-adresses automatically, when a computer is connected. But the the IP can also be set manually.
Posted on Mar 13, 2011
Belkin 30e puts out only .38mbps
Check ALL cables, reseat, replace. Contact your ISP for good signal, have a ISP tech analize the signal. If it's a Wireless connection many things will cause a weak signal, interference, distance, firmware update needed, outside interference, bad connections, the device is bad itself. Is the Belkin Secured? Change Channels, update firmware, reset the device. Try here for Belkin Support and User Manual: http://www.belkin.com/support/dl/P74559-B_F5D7230-4v7_man.pdf AND here: http://www.belkin.com/us/support-article?rnId=3588
Apr 19, 2013 | Belkin Computers & Internet
Looking for driver for a belkin wireless G Plus MIMO Router. Model # F5D9230-4 ver.3100 Thank you
This looks like the correct one:
http://en-us-support.belkin.com/app/answers/detail/a_id/523/~/f5d9230-4-wireless-g-plus-mimo-router---firmware-update
(select download Version 3xxx Firmware )
Feb 16, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I currently use the Belkin G Plus MIMO as a router but now my iPhone which is always connected while in inside the house is suddenly disconnecting and I'm having trouble connecting back, what should I do?
This is most likely a result of your recent iOS4 update on your iPhone.
Check the Belkin Support web site to see if there is a firmware update available for your router.
If that's not the case, try power-cycling the router and deleting the entry for your router in your iPhone and recreate it.
Dec 21, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin router only giving me 4mb but when hard
This can be solve by doing a firmware upgrade you can go to Belkin site and download the latest firmware for this unit to improve the speed of connection........
Nov 08, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do i update the firmware on my belkin router?
On my router I have to log into the router while it is connected to the internet and select update Firmware. From there it does everything on it's own. If it ask for user ID and Password you can try User ID: admin Password:administrator if you don't have that information. If that doesn't work the only other method would be to activate the reset to reset the router to factory and then update and reprogram your settings.
Sep 11, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Line-drop problems on Belkin G PLUS MIMO Router F5D2304
firemware update can fix this issue if it is an issue with rtr .... try connecting a comp to modem and observe connection first if it is fine then update firmware it should work
Jun 19, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have the belkin wireless G+ Mimo 5D9230-4, Moves TOO Slow
Update the firmware of your router. After doing the update, you need to reset the router by pressing the reset button at the back for 20 seconds then power cycle it.
Jan 07, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Keep losing internet signal
Have you tried updating the firmware of your router? Updating the firmware of the router will fix that issue. Make sure after updating the router's firmware, hard reset the router. To hard reset it, Press the reset button on the back of the router for about 20 seconds, then unplug the power for 30 seconds then plug it back. Reconfigure the wireless settings of the router. Make sure to change the wireless channel of the router to channel 11 or 1 and not 6 to avoid interference.
Sep 16, 2008 | Belkin (F5D9230-4) Wireless Router...
Slow Internet using Belkin Wireles G Plus MIMO
Try setting the MTU size to 1400 and also check if there's any firmware update for it if there is update the firmware.
Hope it help
Apr 22, 2008 | Belkin (F5D8231-4) Wireless Router...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
54 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
