Question about Abbaka White Knight 44AW Electric Dryer
White knight tumble dryer timer sticking at 80minutes and not moving to cool clothes
Timer sticking at 80 minutes and not moving to cool clothes
    New Friend:
Have had the same problem with the timer sticking on the model and the same time interval, now don't trust it's safe to use at any setting over 60minutes
Posted on Feb 19, 2017
  • 497 Answers
SOURCE: White Knight 44AW electrics problem
You may have a short in the system, make sure your breaker is rated high enough to support the dryer
Posted on Oct 06, 2009
SOURCE: My White Knight 44AW, 6kg, tumble dryer makes a
my white knight dryer is noisy but still drys, can i do something or do i need a new one?
Posted on Jan 15, 2010
  • 213 Answers
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at TEL 08455218000
Posted on May 10, 2010
  • 1527 Answers
SOURCE: white knight tumble dryer wont switch on
hello check inside the door to see if the long pin hasn't snaped off this connects to the interlock that activates the motor if this is ok check the capacitor next to the motor this gives the motor a boost at switch on hope it helps
Posted on Mar 12, 2011
  • 63 Answers
SOURCE: i can get the back of my white knight 38AW tumble dryer
try lifting the top of the dryer it usually pops up in the front then you will see the drum and the belt
Posted on Sep 27, 2012
Rainbird RC-Bi timer issue
Copy following link to identify sprinkler & irrigation timers on market, and buy another one.
Install heavy-duty mechanical timer.
Replace sprinkler head
Check that voltage is at least 80% amount that shows on rating plate of timer. ie: 80% x 125V = 100Volts
Jun 29, 2013 | Rain Bird Hardware & Accessories
We have a Kenmore 80 series top load washer model 110.28803890. When the timer moves to spin it makes a load clicking noise and does nothing.
Timers are not supposed to make loud clicks. If it is, it's going bad. The same problem happened with my parent's Estate washer. It its on it's third timer!
May 24, 2012 | Kenmore Washing Machines
It takes hours to dry the clothes. The dial moves
sounds like a bad timer. if it sticks every time replace they are expensive
Mar 25, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Runs and stop after about 3 minutes
Sounds like a timer. Your timer is sticking
Nov 16, 2009 | Kenmore Elite 21086
Dryer won't heat and the timer doesn't move. It runs forever with no heat.2 different problems?
if you have timer on time dry and it doesn't move timer is probably bad, if you have it on auto dry or some say more or less the timer will not move if there is no heat
Nov 10, 2009 | Kenmore 63942 Dryer
Dryer does not stop - timer knob does not turn so dryer continues
do you have it on more or less?,if so the timer will not move unless there is heat, do you have heat?are the clothes drying ?if you have it on time dry the timer is bad try moving it past the spot were it's sticking and see if it counts down
Nov 03, 2009 | Whirlpool GGQ8831L Gas Dryer
Dryer will not turn off
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 20, 2009 | Dryers
Dryer takes too long to dry the clothes
If there's heat inside the drum the heater coils are ok. Check the exhaust vent, make sure it's not kinked or squished behind the machine and that the outside vent is not clogged with lint. You should feel air blowing freely to the outside.
If there is no heat, first check for 240V at the outlet. If you have 240V, it could be the element, the hi-limit thermostat, the thermal cut-off, the timer, the motor or a wiring issue (loose or shorted).
Good luck!.
Mar 02, 2009 | Estate Dryers
DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
On sensor dry, dryer remains at 1 minute for hours...will not shut off automatically
I'm sorry to hear of your problem with your LG dryer. I have one as well and it works very well. I found my owners manual. It has a web site They also have a toll free number 1-877-714-7486. Perhaps either of these will help you find an answer. Good Luck
Dec 03, 2006 | LG DLE5932W Electric Dryer
Abbaka White Knight 44AW Electric Dryer Logo
596 people viewed this question
Top Abbaka Dryers Experts
shaun taylor
Bill Eager
Are you an Abbaka Dryer Expert? Answer questions, earn points and help others
