Question about RCA RT2250 System
On and off
When i turn on the receiver i get a clicking noise then it clicks again and turns off
  • jake_jones63 Feb 06, 2009
    i am having the exact same issue, i thought my reciever was garbage, and then i decided to tackle a rescue operation, because i really do like this thing.
    Hey nuwan, it seems like you know what to do, can you help me?
    New Friend:
  • 111 Answers
Speaker protection turnd on i think .it can be happend because of faulty output section of the power amplifire.
can you open the cover and shall we start the repair or what.
nuwan
Posted on Jan 20, 2009
  • nuwan chinthaka
    nuwan chinthaka Jan 12, 2010
    ok jake,,,,,
    can you find the circuit diagram of that it will help you to find the problem easily
    anyway i can help you.
Mine does the same thing. I ave found out that if I turn the unit off then turn it back on then go through all the options on the remote, am/fm, dvd, etc. then back to sat. turn it off then back on it resets something and will stay on? Hope that helps.
kevin
Posted on Feb 15, 2010
Problem turning unit on
it may have an internal shout somewhere causing the speaker protection relays to kick out..
Jan 18, 2014 | Sony STR-DE935
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Will not turn on, makes a clicking noise
The clicking generally means that the relay is trying to close but for some reason cannot.Usually, (but not always) this indicates a problem in the power supply such as a blown voltage regulator or a zener diode. This is not an easy fix and not for the faint of heart. If you feel up to it, at least try to locate a circuit diagram or even better a repair manual. I like Onkyo receivers. They are generally quite reliable and fixable.
Jun 12, 2010 | Onkyo TX-SR606 Receiver
Sound clicks off Sony STR-DE835 5.1 Channel
THIS UNIT HAS BAD SOLDER CONNECTIONS ON REGULATOR TRANSISTORS,REMOVE BOTTOM AND YOU WILL SEE THE BAD CONNECTIONS.ALSO BE SURE TO RE-TIGHTEN ALL CHASSIC GRD SCREWS AS THIS WILL ALSO CAUSE THE SAME PROBLEM.
Apr 14, 2010 | Sony STR-DE835 Receiver
The receiver turns on riefly and then makes a
The clicking noise is the protection circuit., sounds like you have a grounded speaker wire, but you say the speakers are not connected so the amp may be toast. Is there any smell of burnt wires? This is ussuallt noticable near the circuit board if something failed!
Jul 07, 2009 | KLH Audio Players & Recorders
I have a Marantz SR5500 and the unit will not stay powered on.
I have this problem. it is caused by an o/c mains transformer primary winding. the clicking and flashing light is the stanbyy circuit trying to switch the power on to the main (large) transformer when it gets no voltage out it switches back off
May 19, 2009 | Marantz SR5500 Receiver
NAD 7140
The clicking is the sound of a bad relay. A relay is an electrical switch that opens and closes under the control of another electrical circuit. There is no user solution for this. You'll have to take it to an electronics repair shop (~$150) or dump the whole unit.
Nov 22, 2008 | NAD 712
Receiver making alot of clicking noises.
I Have a son STR DE 845 and the speakers make a popping sound when it is in DTS mode what is the problem.
Thanks,
Larry
Jan 20, 2008 | Sony STR-DE845 Receiver
Toshiba Plasma clicking noise
Check the fan, it may be dust or a bad bearing.
Oct 10, 2007 | Toshiba 42DPC85 42 in. EDTV-Ready Plasma...
RCA RT2250 System Logo
264 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
