Question about Coby PMP-4330 Digital Media Player
I want tp upgrade my firmware
I want to upgrade the system firmware because it has not been done since 2007
What means apc button error
I believe this could be a firmware bug. These units were shipped with a notice to upgrade the firmware on the UPS before putting it into production - have you done that yet? Either way, your local technical support team can help you identify the current firmware version and assist with upgrade instructions to hopefully remedy the problem. They would also guide you to a resolution if a firmware upgrade has already been performed
Aug 26, 2014 | APC Computers & Internet
TP-LINK TL-WR541G Router how to change the language Chinese to english
  1. Make sure you know your hardware version!
  2. Download firmware update in English from TP Link website and unzip.
  3. Connect computer to router with Ethernet cable as per manual and in your web browser window enter http://tplinklogin.net then enter user name and password (admin,admin) to access the router Configuration Utility.
  4. From the English manual note the location in the configuration utility menus of the firmware upgrade utility. I.E. Go "system tools" (last entry in menu) then "firmware upgrade" (3rd item down). I know it's written in Chinese but you can count right?
  5. Select your unzipped file location in the window and press the button beneath.
May 10, 2014 | TP-LINK TL-WR541G Router
How to update whole firmeware of tplink for w8901g
Sameer, First thing to do is establishing some facts of this router. Please look at the labels at the bottom of the unit and let me know the firmware version. Something like v1, v2 or v4. Pls look here for the example http://www.tp-link.com/lk/Article/?id=46.
You now have to connect the router to a pc with a network cable, that pc is NOT connected to the internet. For instance with a separate laptop, disable the wifi. The network cable connects the router (one of the LAN connections) to the pc.
Invoke a browser and write in the address line 193.168.1.1 with ID admin and password admin. This should open the service program from the router. Go to Firmware upgrade. And follow the rules. Generally you have to check the latest firmware in the TP-Link site and download that file to your pc. IF you have any questions we are always here to help.
Success, Fred
May 03, 2014 | TP-LINK TD-W8901G Router
TL-W8901G recovery after failure upgrade to latest firmware
Did you use an official firmware or something like WRT?
Apr 26, 2014 | TP-LINK TL-WR642G Router
Error while upgrading firmware
You can try to find the old version of firmware and see if you can load it. If that fails the router is garbage.
Mar 30, 2014 | TP-LINK TL-WR541G Wireless Router
Firmware upgrade
try reset your router first , then upgrading
Jan 26, 2014 | TP-LINK TD-W8901G Router
Downloading failure
Follow the instructions at http://www.tp-link.com/ca/support/download/?model=TD-W8101G to help in identifying the version of the router and attempt to re-install (correct) software. If unsuccessful the router may have been damaged by the failed firmware upgrade attempt.
Sep 17, 2013 | TP-LINK Computers & Internet
TP-Link TL-WR642G recovery after failure upgrade to latest firmware
may find this page helpful. http://www.dd-wrt.com/wiki/index.php...om_a_Bad_Fl ash Its not for the TP-Link router but the same principle could be applied to you with the correct firmware. Its worked for me on more than a few occasions. Providing you can ping the router via a lan cable then the chances of recovering it are very high.
Apr 19, 2012 | TP-LINK TL-WR642G Router
When i install the drivers for TP-Link WN353GD adapter, I already get a warning that it may not be compatible with my system. Currently i am running Win XP SP 2. Is there sometime i can do to overcome...
Update your Wireless Adapter firmware @ http://www.tp-link.com/support/download.asp?a=1&m=TL%2DWR340GD
There are 3 versions for your product(TP-LINK TL-WN353GD, Important***select the correct firmware version to update. Then download the latest drivers(Setup Utility) & and install the drivers for your adapter from the TP Link site.
Link - How to look over the hardware version on a TP-Link device?
Hope it helps.
Apr 05, 2011 | TP-LINK TL-WN353GD 802.11g/b Wireless...
When i connect tp-link tl-wr541 tp pc one connect nd discounnect so i cant upgrade firmware to it and cant access because of disconnect
1. dowloan latest firmware for router
2.only connect router and computer with cable
3.open router page
4 go to upgrade router option,click on brouse select file then click on upload
5.after uploading router firmware ,reset router then
reconfigure router
regards
prakash
Feb 10, 2010 | NetGear WGR614 Wireless Router
Coby PMP-4330 Digital Media Player Logo
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
