Question about DeLonghi Dehumidifiers
I cannot get my DEM8.5/10 to drain continuously even though I have removed the rubber bung , have no kinks in hose and exit end of hose lower than outlet from machine. Any ideas?
The machine is 3 years old and during the past two winters I have been able to continuously drain. Dehumidifying would stop for a time if temp. was too low but then restart along with continuous drainage as temp. rose. This winter however after a cold spell dehumidifying restarted as before but condensate this time would only pass into internal tank which requires daily emptying.
  • 883 Answers
SOURCE: Hose Drainage
yes, that is what the knockout port was designed for. Make sure the hose you get does actually thread onto the hose connection port before you punch out knock out. The hose should be a standard garden hose connector.
Posted on Aug 17, 2007
22yooper
  • 828 Answers
SOURCE: 2008 Frigidaire 50 pint Dehumidifier from Lowes
You can test it out by disconnecting the power cord, wait five minutes and plug it back in. If it retains the original settings you are good to go. If you are wondering before purchasing a new unit ask before you buy.
Posted on Jun 29, 2008
  • 30 Answers
SOURCE: haier 30 pint dehumidifier continuous drain problem.
Many just attach the hose at the reservoir; from your description, Haier apparently has a separate location. Check that the point that the hose attaches has an opening (many don't, they expect you to drill it). It should then drain through gravity. Check to make sure that no part of the drain hose is higher than the bottom of the reservoir, otherwise it can't drain. It won't siphon because each time the the tank empties, the suction is broken and the siphoning can't continue.
Posted on Aug 31, 2008
  • 3 Answers
SOURCE: whirlpool dehumidifier drains into the bucket, not the garden hos
I had a sililiar problem. I think I tightened tthe hose after putting a new rubber gasket on hose fitting, Also checked angle of hose.
Posted on Sep 30, 2009
heatman101
  • 43501 Answers
SOURCE: woods dehumidifier wont dehumidify
Here is a tip that I wrote that will help you...
http://www.fixya.com/support/r3877515-dehumidifier_problems_dehumidifier
heatman101
Posted on Apr 16, 2010
P1 constantly goes on throughout the day. I do not know if I have the setting right or if the drain hose is connected properly.
First, the drain hose should not be longer than 5 feet and should be draining downward, with no kings or bends in the hose, The dehumidifier does not have a pump. It relies on gravity to drain the water.
As far as it running all day is concerned, some dehumidifiers have a "Constant" or "Continual" setting. Which means it runs constantly. Either while dehumidifying or defrosting. In addition, most Danby dehumidifier models are designed to have the fan run even when the compressor is not running. This is in order to circulate the air in the room and make the unit work more efficiently. This is a standard feature and cannot be programmed to stop.
Hope this answered you questions.
Apr 24, 2011 | Danby DDR4009EE Dehumidifier
Can I set my dehumidifier to turn cycle on and off while I am traveling
Normally a dehumidifier will run based on the humidity found in the air in the room it is located in, although many can be set to run all the time.
I don't believe your model can be set to run next Tuesday, Wednesday and Thursday because you will be home and th NOT run next Friday and Saturday because you will be traveling, for example.
Your machine should run on automatic until the bucket fills with water at which time it should stop running until you empty the bucket. Many buckets offer the feature of adding a drain hose you can run to a drain somewhere. Some people have a floor drain they use for such purposes. Others I have known sit the device on the counter and drain into a sink or in the bath tub and drain that way.
For best dehumidifying results, you should run your machine all the time.
I hope I have answered your quesiton. Thanks for considering FixYa.com
Jan 06, 2010 | Frigidaire FDL50R1 Dehumidifier
Our dehumidifier is full of ice, is this normal or an indication of more serious problem. It is 3 1/2 years old and has been in constant use since purchased.
If the room tempature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defost over night.
Only specially made dehumidifers work below a room temo of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensot from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Jan 02, 2010 | Kenmore 54501 Dehumidifier
My Soleus Dehumidifer is not dehumidifying
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 30, 2009 | Soleus CFM-40 Dehumidifier
The dehumidifier runs all day but there is only a little water being produced. We have humidity set at 35%, and the actual readings are much higher. This is only a year or so old. The last machine worked...
coolant may be low - warranty should be 5 years
Dec 10, 2009 | Fedders A7DH45B2A Dehumidifier
My dehumidifier is frozen solid
Unplug it ... let it defrost.
Set it to a higher % humidity and make sure the fan is on its fastest speed. If you can set it not run continually (a selection option), do that. Also, set a small fan close by to move more air around the machine. If you have the option, put a hose on the collection device to drain to a sewer.
As your space starts to dry out, set the humidity setting to a lower number. This may take a week or more.
I believe perfect humidity is slightly above 50% - no need to try to get to 40% except in unusual circumstances. If that is the case, get a second device. Or, if your space is large, you may want to add a second device.
I hope this info helps you and your problem is solved.
thanks for using Fixya.com
a
Oct 25, 2009 | Danby DDR556RH Dehumidifier
Dehumidifier
After reading comments and complaints from other frustrated Maytag owners, I just went out and bought a new LG EnergyStar dehumidifier. I'm taping the receipt inside a plastic bag, along with the user manual, to the side of the machine. Hope this one works for a LONG time! Ronnisue
Jun 15, 2008 | Maytag Dehumidifiers
Does not dehumidify at all
was it wintered in a warm or a freezing area-which? freezing storage is bad news for these. it somehow makes all of the freon leak out
May 28, 2007 | Haier HD451E Dehumidifier
Dehumidifiers Logo
43 people viewed this question
Top DeLonghi Dehumidifiers Experts
dennis lewis
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
