Question about Lowrance Boating
SPEED/TEMPERATURE SENSOR WORK SPORADICALLY(lowrance X-85)
Hi, I have a lowrance X-85. when I turn it on, the speed and temperature sensor (model ST-TBK) indicate the speed and temperature on screen and all is right. But after fifteen minutes, the sensor does not work well because it indicates the same temperature even if the temperature has changed and the speed indicates 0 mile per hour. Then I turn it off and turn it on afterwards and it still works well for only fifteen minutes and the same problem occurs.
Can you help me please to fix this problem?
CMV9
  • 594 Answers
SOURCE: When turning on the Lowrance
here is the link to your the lowrance web site. the trouble shooting guide says that if you tried to it on another boat than you might need to take it in for service. but there is a section that explains how to do a soft reset on the unit. you might try that.
http://www.lowrance.com/en/Support/Troubleshooting-Guide/Depth-Reading/
please rate and comment on your experiance with fixya.
Posted on Aug 15, 2008
hydetech
  • 113 Answers
SOURCE: Globalmap 2000 sonar not responding
Not enough info to diagnose your problem. It sounds like a networking problem. I couldn't find a manual for the sam-st module so I'm not sure how you have it hooked up. Typically with these devices only one would be hooked up to the SONAR module, and it would then share the data with the other display via an ethernet or NMEA2000 network. The erratic behavior of your bluewater could be due to some sort conflict with the current coming from the GlobalMap2000. Do you get the same problem when the 2000 is turned off? Have you tried running the GlobalMap2000 with the bluewater turned off?
Posted on Aug 19, 2008
SOURCE: 98 dodge caravan problems
I had the same issue with my dodge caravan and after several attempts by the dealer to fix it, it turned out to be a broken wire. They replaced the relay and it would work for a while and then go blank again. Have the wires checked thoroughly.
Posted on Sep 27, 2008
MrScary66613
  • 1990 Answers
SOURCE: instrument cluster panel
Not a Fuse. There are Small Bulbs on the Back of the Guage Cluster that Burn out Occassionally. You will need to Disassemle the Dash and Remove the Guage Cluster to get to these Mini-Bulbs for Replacement. Please Rate my Solution, I need all the Help that I can Get! Thanks!
Posted on Jan 29, 2009
  • 30 Answers
SOURCE: ABS light & brake light on, problems with speedo working properly
The rear wheel speed sensor is the most common problem on those trucks and will do what you are talking about. It is located at the top of the rear axle in the center. It picks up it's signal from a tone ring on the diff inside! If a tranny input or output sensor is bad then the tranny won't shift properly!
Posted on Aug 14, 2009
Does the x510c have a speed and temp transducer or just the paddle seperately
Hi Rick
There is only one transducer. for speed/temperature. From page 2 of the owner's manual (see link below)
"A single-frequency with built-in temperature
sensor is packed with the X-510c"
Hope this helps and happy boating!
-Steve
http://www.lowrance.com/Root/Lowrance-Documents/X515cDF_X510c_0151-451_120406.pdf
Mar 10, 2015 | Lowrance X510c 5" Screen Color 200 Khz...
Hi, whenever I power off my lowrance 125 it defaults the settings and I constantly have to change them every time I turn it back on, also the speed read out on the top left remains at 0 kts, however I do...
These units have internal batteries that power a small bubble memory that remarks your settings. I would conclude that this battery is dead. The result being your unit forgets your settings every time you turn it off.
Possibly a faulty speed wheel on your unit as to why the system no longer registers speed.
Try recalibration the speed. http://www.lowrance.com/Root/Lowrance.../x136df_0151-171_112003.pdf
Above is a link to a PDF for your owners manual.
Feb 19, 2015 | Lowrance X125
What is error code F-85
There isn't one listed.
71 Timer stop idling
75 Oil temperature sensor circuit hydraulic steering system
The pressure sensor 81 at the inlet trap foreign particles
82 Pressure Sensor
84 speed sensor
91 Accelerator pedal position sensor
94 Pressure Sensor fuel pumping
95 The differential pressure sensor on the fuel filter
Jun 19, 2014 | Caterpillar Cat Forklift Ignition Switch...
What are the data cable 5 wire used for and where do they get hooked up
The additional wires are for NMEA data transfer to and from other devices and sensors like distance, speed, depth, temperature and NMEA 0183 sentences the unit will use when connected to a VHF radio or other NMEA 0183 device.
The manual link below.
http://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-5_HDI_OM_EN_988-10518-001_w.pdf
Jun 11, 2014 | Lowrance Boating
1997 buick skylark temperature sensor location
the radiator fan gets the power from a relay that is energized by a signal from the ECM that in turn gets a report from the coolant temperature sensor
AT this point I would be thinking that there is considerable resistance in the relay
you say the fan works a bit so the temp sensor is reporting toe the ECM which is turning the relay on but power is low from there
replace the fan relay and see if the situation improves
you can test that theory by putting a meter across the wires to the fan when it should be working and reading the voltage available to the fan
if it is not 12 volts or better( 13.2-14 volts) it is the relay
Mar 13, 2017 | Cars & Trucks
1997 Buick Skylark radiator fan weak, works sporadically
Hi, I believe it could be a bad temp sensor. Which turns the fan on or off. Have it checked. Replace it with new one. Hope that helps you.
May 25, 2017 | Cars & Trucks
I HAVE A 2003 TIBURON WITH A NEW RADIATOR. THE CAR HAS A TENDENCY TO INCREASE IN TEMP IF ON A CONSTANT SPEED OF 140KM. IF THE SPEED IS DROPPED TO 100KM THEN THE TEMP DROPS TO THE NORMAL OPERATING TEMP...
My guess is trapped air in the cooling system. If the cooling system was just filled with antifreeze without bleeding the air, it could cause sporadic overheating. It could also be the cooling fan not coming on at high speeds. Next time the temperature rises, turn on the defroster for th front windshield. That should cause the air conditioner to come on, which in turn will turn on the cooling fan. If the temperature drops, I would suspect the cooling fan sensor is faulty.
Jan 14, 2011 | 2003 Hyundai Tiburon
X107CDF speed / temperature sensor replacement?
Certainly you can.
We did that last year with our Raymarine Tridata.
Easy peasy.
Jun 25, 2017 | Lowrance GPS
Ck eng lt, intermittant, card chugs, then i must turn off and restart, code 58 and 85 on scanner
 Electronic control module (ECM) computer circuit problems - faulty programmable read-only memory (PROM). OR (Transmission) Input or output speed sensor - circuit problems. (Speed sensor signals do not agree with with selected gear range.) OR Torque converter clutch (TCC) - TCC is mechanically stuck on.
 Vehicle anti-theft system (VATS) problem. OR Transmission Temperature Sensor (TTS) - short circuit problem in sensor or wiring. OR Transmission fluid temperature high.
Apr 23, 2009 | Ford Escort Cars & Trucks
Boating Logo
149 people viewed this question
Top Lowrance Boating Experts
Phil Walker
Phil Walker
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
