Amber light blinking
Shuts down
won't restart for hours
  • richardsd854 Feb 16, 2009
    I have a Dell Dimension 8400that has been working fine until last evening the power switch was found with a blinking amber light, which prevented a computer start. The PC was unplugged, and replugged about half hour later, the PC was normal and allowed a start. After about 5 minutes of work, the PC shutdown and the power button was blinking amber. Any recommendations?
  • maccaz21 Apr 18, 2009
    My computer now has the same problem.. Amber light flashing but will not boot at all. I have unplugged the hard drive and tried to boot but still nothing.
    It could be the power source, when you say try a new power source what do you mean exactly?
  • 79 Answers
Power supply may be faulty - this is also common for overheating motherboard. Try a new power supply.
Posted on Jan 25, 2009
Dell c521 won't start blinks amber
A possible power supply failure has occurred. The system has not received a Power Good signal from the power supply. In other words you either have a defective power supply or a device in the computer (i.e. sound or video card) is shorting out the power supply.
Mar 15, 2013 | Dell Dimension C521 PC Desktop
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
This is my second dockstar, and both have just gone to rapid blinking amber lites. seagate doesn't really tell you any thing.
moz-screenshot.pngmoz-screenshot-1.png1-If you never shut off the device try to turn off for 4 hours and try to use it again.
2-The bottom light must flash when is on,if not you have a power supply or net cable problem.
3-If the top light is amber is indicate you have a disk problem
4-Do a power cycle
5-if the problem continues run the disk diagnosis utility from the web interface
6-If fails the drive needs replacement, check for warranty
7-Try to do a system reset.Press and hold the switch( a small hole at the bottom of the Ethernet) until the top front light flash and allow the unit to restart.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 01, 2010 | Seagate FreeAgent DockStar Network Adapter...
I turned on my Dell Dimension 4700 computer,but the amber light started to blink . I held the start up button for 5 seconds and the light went out. I tried to start it up again and got the same thing,...
Vaughn it sounds like the power supply is going bad, try another known good working power supply. If that doesn't work then the motherboard would need to be replaced. If the power supply isn't giving the correct voltages that could cause the computer not to turn on. If the motheboard isn't able to convert the voltages properly then the motherboard could be faulty.
Dec 23, 2009 | Dell Dimension 4700 PC Desktop
A power outage caused server to shut down. It
The power outage is suspected to corrupt the RAM. Get in touch with the vendow and get it replaced.
Nov 09, 2009 | HP Server Tc2120 (335874-001)
Toshiba 1410-S173 battery charging light blinks amber
did you buy the battery brand new or used?
brand new, deffectibe motherboard, bad charger or bad dc socket.
used, change it.
Mar 03, 2009 | Toshiba Satellite 1415-S173 Notebook
Computers & Internet Logo
1,393 people viewed this question
David Payne
David Payne
