Question about Kenmore 24032\24036 Top Load Washer
How to disassembly the canister
Please show me how to open the top so I can remove canister of this model 110 27841600
  • 101 Answers
This is an easy thing to do. To start what you will want to do is remove the screws on the back control panel. Then on the sides there are two covers. Just pop them off and you will see two screws, one on each side. Take those out. Next and last, take a sturdy flat head screw driver, insert it into the crack on the front of the machine just under the lip there about an inch from the lid. Pry it up, there are two clips holding it in place. That's it. Let me know if you have any other questions and let me know if this was helpful to you. Good luck.
Posted on Jan 22, 2009
How much to replace a hoover motor?
Upright or canister? On the canister type, the unit has to be taken completely apart by separating the top and bottom and removing several screws to get inside to find the motor. A search using your model number will normally reveal a youtube video showing you how.
Dec 01, 2014 | Vacuums
Beckett burner starts and ignites but flame goes out slowly then get a lot of smoke why is this happening
It sounds like your filter is clogged. In the line from the oil tank to the burner there should be an in line filter. It is usually canister shaped and has a felt filter element inside. Shut valve off at the tank and loosen bolt on the top of the canister to remove bottom section of canister and access filter replace filter ( most hardware stores carry them) and reassemble canister. There is a small screw on top of the canister. Remove this to let air out when you open valve to let oil fill canister. When oil comes out shut off valve and reinstall screw. Reopen valve again and you should be ready for burner test. Setting a pan under the filter canister is a good idea to catch any oil from disassembling filter. Hope this Helps.
Oct 19, 2014 | Beckett B2502 Burner, Oil
Electrolux Z5935 Bagged Canister Vacuum disassemble
Anybody knows how to disassemble this unit ? I removed 4 screws but all seems to be still locked together. I tried to separate top from bottom and I can't.
Mar 30, 2013 | Electrolux Z5935 Bagged Canister Vacuum
My power cord will not retract back into the housing< i would like to open the back of the unit but there no screws or bults to due so. How do you open the back of model c151d
Try standing vacuum on end, then gently tugging and releasing cord. This generally will retract it.
There are many problems that can result in disassembly and reassembly by an untrained person, including shock and fire. For those and other reasons, I don't recommend trying this yourself. Take it to the nearest Aerus Electrolux store for repair.
The back of the vacuum can only be removed by separating the top and bottom portions of the canister. The cord winder will need to be removed and the wires all disconnected. The cordwinder is then taken apart and the cord rewound and set for proper tension for rewinding. If the cord is simply stuck due to having been pulled out too far, this is generally not necessary.
Jan 07, 2011 | Electrolux UltraLux 2000 Bagged Canister...
My Miele S548 does not turn on. I am suspecting power cord contact inside. I am pretty good at disassembling electrical equipments including TVs and laptops. Not being able to open the vacumm canister...
your exactly right. there is probably 2 or 3 screws your missing there.
now getting to these screws is easy. If you haven't already, remove the top filter and the bag door lid.
Assuming you have taken the screw out holding the black control panel out already... you want to remove the black panel with your on/off switch and the cord rewind. Once you have the panel off there are a couple of screws there that are holding you back. once removed, you should have full access to the underneath with the motor and cord rewinder there.
Good luck,
Nov 11, 2010 | Miele S548 Bagged Canister Vacuum
How do u open up the compartment to empty the trash
I couldn't figure that out either...since I misplaced the owner's manual...Anyway, there is a little gray colored knob at the top of the "collection" canister...and simply press that button and it disassembles that canister from the rest of the upright and then you are able to empty that trash contained therein.
Sep 29, 2010 | Euro-Pro NV22 Shark Navigator Bagless...
How to disassemble a GE DBXR453EV0WW dryer?
Unplug the dryer.
Remove the screws from the control panel top rear.
Lift the control panel aside.
Pull the top lid forward to remove it.
Reach inside the right and left front corners to remove the screws holding the front panel to the cabinet.
Remove the door switch wires and set the front panel aside.
Your model may or may not have 2 screws holding the top lid down located inside the door opening. Open the door,get down on your knees and look up at the door opening for 2 screws.
Jan 03, 2010 | GE Dryers
How to replace the auto rewind button on Hoover canister vacuum.
116-...... usually indicates a Sears/ Kenmore model vac Please clarify
Sep 17, 2009 | Hoover Vacuums
String caught in end of rug brush
This pdf file should help you - there are instructions in it for removal of the roller.
Rate if this helps :)
Feb 15, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Cant open the oven model nnst656w
What usually breaks is the door open lever. Sometimes it may be a worn door open button (the back side) or the face of the lever.
On a counter top model, the outer cover will need to be removed to diagnose and repair this.
On an over-the-range model, only the control panel needs to be removed. At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can order Panasonic parts from Tritronics (or call 866-779-5835) but if you don't find what you're looking for there, try here.
Nov 02, 2008 | Panasonic NN-T888S Convection/Microwave...
Kenmore 24032\24036 Top Load Washer Logo
65 people viewed this question
Sal De
 Brian Main
Brian Main
