Question about Philips MCM275 Shelf System
I have a Philips mcm275 micro sistem and when i plug it in,turns on end off by himself an make a noise each time,like a clic,and do not work at all.
I see people have same problem but it dont show what the problem was
I have a 2008 dodge nitro my ac not working there is not leak and the sistem is just charge the compressor don't engage I need some help thanks
Check the switch in the line, Check the clutch on the front of compressor is turning by hand it could be seized.
Jul 13, 2017 | Dodge Cars & Trucks
I have tikking noise from both spekers,
hi how can i get amanual for a micro component system UX-P5R
Nov 22, 2013 | Philips WACS700 Shelf System
My hyundai accent won't start anymore. The battery is good because every electrical components works well but when I turn the key to fire the engine nothing happens. The starter doesn't make any noise or...
I just experienced the issue: clic-clac-nothing. Jumps start: same clic-clac-nothing. I set the 4th gear and moved the car. Just started like day one!
It's good, so far but I don't know why...
Jul 08, 2010 | 1997 Hyundai Accent
Cd player
Clean the laser lens
Dec 31, 2009 | Philips MCM275 Shelf System
Cant eject cd, no sound
HI, you have a damaged IC chip on the main board that is not allowing proper sound distribution at this time and, the load motor on the CD assembly is also damaged. this is the reason for the trapped CD that wont eject.
Unfortunately, Micro dose all of its repairs in house and you will have to send this unit to the Micro techs for this repair.
May 19, 2009 | Philips Audio Players & Recorders
No tengo el cd y quiero intalar una camara logitech 961306
hola raul....
tienes que ir al web de logitech a esta página para elegir tu país.
una vez que has entrado en el web... haz un clic en el enlace para 'Asistencia' (arriba del todo en letra muy pequeñita). en la parte 'Buscar por nombre' elija cameras web... y debajo el modelo, y haz un clic en la flecha.
en la página siguiente, haz un clic en descargas y después en tu sistema operativa y después en el archivo....
Muy Importante:
para elegir el archivo necesitas saber si tu sistem operativa es de 32 o 64 bits... lo puedes averiguar haciendo un clic derecho en el icono de 'Mi Pc' (en XP) o 'Equipo' (en Vista) y seleccionando propiedades del menú emergente.
espero que esto te sirve de ayuda, y avisame si tienes alguna pregunta mas!
bru*
Feb 17, 2009 | Logitech QuickCam Messenger Web Camera
Lost my remote control from my MCM275R/37 audio system so I was wandering if is possible to buy another one
Magnavox no longer has them. Try this eBay listing (check with seller to make sure h has remote):
http://cgi.ebay.com/Philips-MCM275-Micro-Hi-Fi-System-w-MP3-Playback-USB_W0QQitemZ230261324271QQihZ013QQcategoryZ4787QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Jun 14, 2008 | Audio Players & Recorders
CD player not working
Dont worry rdf133, just get a CD cleaner and run it on the player this should solve it, or u can also give the player for general service to a nearest electronics repair shop. I am sure u will get it working. Please rate me...!!!
Thankyou
Feb 10, 2008 | Philips MCM275 Shelf System
Philips MCM275 Shelf System Logo
67 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
