Question about Matrix T7xe Treadmill- Trade-show Demo Unit
Software problem. Will not start, and touchscreen do not work.
Hey, I got a Matrix T7xe Treadmill, but it does not work at the time, but I hope you can help my. The problem is: When I turn on, the touchscreen do not work. When I try to start it by cliking on one of the "normal" buttons nothing happens, and it says "Pause" on the touchscreenit All in all - I can't use for anything right now What I think could be the soloution: Reseting it. But how do I do that? Updating the software. But how do I do that? I don't know anything about the subjekt, but I hope that you can help my and you might have some other and better soloutions that the one I posted. Asger Ravn
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: My Matrix T3X treadmill display doesn't work
tight the ribbon cable keypad, clean it +tight the wires connector from display board vs lower board and clean it.
2) adjust the reed switch, clean it and tight the wires connector.
see the diagram.
God bless you
Posted on Jul 20, 2012
Matrix MX-3 error code 1
see the diagram attached for the speed sensor. test for open or faulty. clean it, and tight for plug or connector.
2) Test the input voltage motor, if there are the motor need repair
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Dec 16, 2012 | Matrix T3Xi Treadmill
Life of running belt in matrix treadmill
all depende how frequently you LUBE the deck belt, may you have a worn Deck. see the instr. manual and see the video.
God bless you
Aug 05, 2012 | Matrix MXT5 Treadmill
see the diagram.
God bless you
Jul 19, 2012 | Matrix T3Xi Treadmill
My matrix MX-T5x start running and stop in seconds. With the error code E7. What is the problem ?
By E7 it means Speed sensor feedback missing. You have to check the speed sensor mounted near the motor pully. Remove the speed sensor and clean it well Then refix it then check the tread mill by powering ON. If then also the problem remains the same , You have to replace the speed sensor.
ok
Aug 02, 2011 | Matrix MXT5 Treadmill
Hi, i have an Error signal " 2 - 9 F " the treadmill stops and cant run anymore. thanks a lot!
I have a Matrix Treadmill t4. An error of "E1 and E3" occurs when it is started? Can you tell me the solution?
Mar 15, 2011 | Matrix T3Xi Treadmill
Treadmill only works for 15 secs
1) If the the belt is moving during that time then stop I would suspect that speed sensor maybe defective. Replace the sensor
2) Now if their is no belt movement then either Motor Control board or Drive Motor is defective. Do Motor Test
I would check the drive motor first to eliminate an expensive component, unplug unit then remove motor shroud then unplug the connectors leading to the motor itself. If you have wire leads and a 18v drill battery2_bing.gif connect the leads into motor then attach the other end to you battery and if the motor will rotate ( approx. 1mph) if that is accomplished then the only other component to be replaced would be the Motor Control Board. Call Matrix for parts @ 1-866-693-4863 option 3
May 14, 2010 | Matrix T3Xi Treadmill
Matrix T7xe Treadmill- Trade-show Demo Unit Logo
49 people viewed this question
Top Matrix Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
greg kinsley
Are you a Matrix Exercise and Fitnes Expert? Answer questions, earn points and help others
