Question about Synergy Samsung SMX-F30 Camcorder Battery Charger
My samsung f30 camcorder turn on with black screen?
It does turn on but the screen stays back?
I have set the date on my samsung f30 camcorder but does not appear on any recorded film....Why ? please.
You need to use the user manual to check this out. I do not know the answer off hand. Follow the link to the user manual. http://www.videocamera-manual.com/manuals/samsung/Samsung_SMX-F30.pdf
Nov 10, 2016 | Samsung Video Cameras
How do I get my camcorder to stay on?
the monitor cable is cut. this is the reason for this. open cam and monitor sect, replace the flat ribbon type cable.
Nov 17, 2015 | JVC Everio Gz-ms120 Camcorder - Onyx...
Can't take picture or record video?
Try turning the screen all the way around and close the screen so the screen its left outside where you can see if that doesn't work you will need to replace the ribon that connects the screen to camcorder.
Jan 30, 2014 | DXG Technology DXG-506V DV Digital...
Where can I get a manual freee on line for a Camcorder F30 samsung
http://www.scribd.com/doc/15077694/Samsung-Camcorder-SCF30F33F34LN-User-Manual
Sep 24, 2010 | Cameras
I have a samsung smx f30 camcorder and when i watch the videos on the computer the video has lines on it so what is the problem
This sounds like the camera needs a cleaning and you can buy camera cleaning items from any good camera store.
May 20, 2010 | Video Cameras
Fujifilm Finepix F30 compact digital, LCD is very dim.
its not a good idere to get them wet you know,
it could be repaired if you can strip it out and you may be lucky it could only need drying out to work again take care when striping it down dry it out in free air only dont apply ant heat to it
Oct 31, 2009 | Sharp Viewcam VL-AH130U Camcorder
Screen is black than white and then turns normal. HELP!
It might be flex internal wire connecting LCD with camcorder. I had problems like this changed it and it's like new.
got it from the repair shop.
Good luck
Meggita
Jul 31, 2009 | Video Cameras
LCD Screen
Replace the Ribbon Wire between the Mini DV unit and the lcd screen. Samsung wanted $136 to repair same issue for me. Screen started with colored lines eventually going to white lines and finally screen went completely black and stayed black. I replaced the Ribbon Wire after purchasing a copy of the systems schematics and repair manuel online. With total cost of everything i bought to make this repair I saved a little over $115 from what Samsung wanted for the same repair.
Jul 21, 2008 | Samsung SC-D353 Mini DV Digital Camcorder
Blue screen appears on my samsung camcorder
SOUNDS LIKE A BAD CCD.. SAMSUNG IS KNOWN FOR THIS PROBLEM WITH THIS MODEL.. WILL YOUR UNIT RECORD SOUND BUT NO PICTURE? IF IT DOES IT IS THE CCD ..CHARGED COUPLER DEVICE
Jan 07, 2008 | Samsung SC-D107 Mini DV Digital Camcorder
Samsung SC-MM10S Blue Screen
CCD sensor seems faulty . Samsung should repair free of charge.
Aug 28, 2007 | Samsung SC-MM10S Camcorder
Synergy Samsung SMX-F30 Camcorder Battery Charger Logo
Top Synergy Cameras Experts
Are you a Synergy Camera Expert? Answer questions, earn points and help others
