Question about Home
Ecoflush Model B8104 toilet leaks from handle when flushing.
Model B8104
  • Stavros Michailidis
    Stavros Michailidis Sep 13, 2015
    I'm having the same problem. What did you finally do to fix it?
  • 15,704 Answers
The manual and troubleshooting information is here. This is a plumbing feature I have never come across before.
https://wdiecoflush.files.wordpress.com/2013/05/b8104-service-manual.pdf
Amazon will sell you a replacement module;
http://www.amazon.com/EcoFlush-B8104-Pressure-Assisted-Control/dp/B00FHB8CAM
Posted on Sep 13, 2015
  • 35 Answers
SOURCE: American Standard Elongated toilet bowl water level slowly drops
The tank holding the proper amount of water is a good sign. The inside of the stool is like the GOOSE NECK under you sink. It always holds water. This may sound like a bit of a hassle to do but if all 3 toilets are identical, here is what you can try if you are a bit handy. Go to the hardware store and purchase 4 toilet wax rings with a plastic flange and a few sets of toilet floor flange bolts(they are cheap and you can always return if not used, as It is better to have xtra parts on hand). Turn off the water supply to the "Mystery Toilet". Leave the tank and everything connected to the stool. Flush the toilet and remove all excess water from the tank and bowl. This can be done with a shop vac, sponge or towel. Disconnect the water supply to the tank. Remove the bolts holding the stool to the floor and carefully remove toilet. Scrap off all the old wax from the floor flange and bottom of stool. Now go and repeat this proceedure to one of the toilets that is working properly. In other words Switch the "Mystery Toilet" with a "Working Toilet" and see how they react. If the working toilet does it in the same bathroom and the "Mystery Toilet" does not do it in the other bathroom then you probably have a VENTING PROBLEM. If the "Mysery Toilet" Does it in the other bathroom then you most likely have a Defective Toilet. This Job is best done by 2 people, as it can sometimes be challenging to center the new wax ring on the toilet flange. Reconnect to the floor and reconnect water supply to the tanks. DO NOT OVERTIGHTEN BOLTS to the floor flange as you may crack the toilet. All drain lines must be vented properly for water to flow. If you are curious check out drain venting on the internet. Also, sometimes a vent can become obstructed with debris, ice, bird nest, etc.. I would 1st check the vent on the roof visually and then have someone flush and listen. If you believe the vent is clear....Then do the toilet switch and go from there.....Hope this helps and Happy Holidays....Joe
Posted on Dec 21, 2008
  • 659 Answers
SOURCE: Toilet won't shut off
Does it leak from the overflow? If so then the washer at the top of the Fluidmaster needs to be replaced. If it is not going over the overflow then you will need to replace the flapper on the flush valve.
Posted on Apr 11, 2009
gypsycat00
  • 224 Answers
SOURCE: toto toilet, flapper doesn't stay up long enough to flush
One of two things is the problem. First, make sure that you have a tight chain with little slack. If there's too much slack, the flapper won't catch in the passing air to stay up. Second, the flapper is not correct for that style of toilet. You might want to look into purchasing a new Kolby filter that has a removeable cone in the center. Move that cone to 12 o'clock to allow the maximum amount of water to run through the flush valve. If the flapper you have now is flat, it needs to have a cone in the center on the underside.
Posted on Jul 10, 2009
  • 150 Answers
SOURCE: Toilet flushing problem!
The siphon mechanism works on a vacuum principle. If there is the slightest damage to the siphon membrane you will experience the problem you describe. A new siphon is required.
Posted on Jan 20, 2010
bloues
  • 56 Answers
SOURCE: One of our EcoQuantum toilets really doesn't
Hello
Im Rossouw. qwalifide plumber
Ur problem most likely is ur arm conected to your flush handel.
If the arm is iron, try bending it down so that when u use the handel it has more leverage tolift up ur sistern flush rubber and create a flow facume as we call it.
if its plastick.... u must ajust the hight of ur flush meganisem by turning the head were the arm is conected left and pushing it down and turning it right to fasen it again. this will also work for iron arm bt is un nessesery for iron arm.
ajust hight until problem is solved.
Please rate my advice thanx :]
Posted on Jul 10, 2010
Bemis duel flush toilet leaking, how do I fix it?
If the leak is inside the toilet, then you have a defective flush valve or flapper Which ever one is in your model toilet.
Jul 25, 2014 | Bemis Home
How do I repair a toilet in a 1991 Pace Arrow
Is the water constantly running inside the toilet or leaking from behind. If it is running inside the toilet it is often cause by the valve not being allowed to return to the off position. This could be a result of a bad flush linkage from the foot pedal or handle or it could be that the ball or blade gasket is messed up inside the toilet. If it is leaking behind the toilet that means your water flush module has cracked and must be replaced. Turn the water to the coach off. Disconnect the water line to the rear of the toilet. Remove the nut on each side of the base of the toilet. Take the toilet outside and inspect every component and replace what has failed. It is very basic and simple to repair.
Jun 25, 2014 | RVs
Have a Duo Flush System from FluidMaster. It continuest to ghost flush. Have adjusted the float valve several times but is still ghost flushes. How can I stop this?
follow this steps and fix it. God bless you
f the toilet bowl overflows, use a plunger or auger to eliminate clogs. If the toilet does not flush, tighten or replace the defective handle , adjust or replace the lift chain , or replace the flush mechanism. Jiggling the handle forces the lift chain or rod to re-seat the flush mechanism, telling you that something is awry.
If the bowl drains sluggishly, remove the clog with a plunger or auger, or raise the water level in the tank .
If water runs continuously through the toilet, lower the water level in the tank , adjust or replace a lift chain or wire , repair or replace a worn flush valve , clean or replace the valve seat assembly .
If water appears under the tank, tighten the tank hold-down bolts , lower the water level in the tank, replace the float valve , replace a malfunctioning ball , or tighten nuts on the water supply line, replace leaking supply line . As a last resort, re-seat the toilet .
If the seat is cracked or unsightly, replace it .
If the bowl or tank is cracked or otherwise unacceptable, replace the entire toilet .
Nov 25, 2013 | Delta Home
The rubber stopper does not line up properly causing leaking to bowel i hove to take cover off and move it a touch over after we flush my model is 703 one piece the handle does not come up after...
contact Kohlet online or there 1 800 number. They have all the parts but they also charge a lot.
Me I would turn on cut-off valve then go to Home Depot or Lowes and explain problem and tell model 703 and they can look it up and order your parts. They may even be cheaper then from Kohler.
Oct 05, 2010 | Kohler Toilet - One Piece with Ingenium...
Flush valve closes before toilet flushes completely?
lift off cover and adjust =shorten length= between flapper and handle lever
Apr 26, 2010 | American Standard Colony 2388.012.222...
Tilet want flush no pressure when depressing
Take off the top lid and look at the flush handle mechanism. You'll see a not that holds it onto the tank. Tighten the nut so it is snug. Don't overtighten it or you could crack the tank. Next inspect the chain that goes between the end of the flush handle rod and the flapper valve. It should lift the flapper all the the way up when you operate the handle.
Apr 11, 2010 | Crane Plumbing 3755 Toilet-To-Go Metro...
Shortly after toilet flushes, you hear a tinkling sound for several seconds, as if water dripping inside. Sometimes also hear another sound like flushing even though toilet is done running,
Check the water level inside the tank to be sure the tank isn't overfilling and spilling into the overflow tube.
Also check the flapper valve (the rubber valve at the bottom of the tank that sits over the flush hole and is connected to the flush handle) to be sure it is holding and not leaking.
Make sure the handle chain that goes to the flapper valve isn't tangled up and holding the flapper valve partially open.
Dec 12, 2009 | Office Equipment & Supplies
Water level in bowl too hogh
Try bendig the float rod down so th resivor dont fill so much
Oct 19, 2009 | Elements Of Design EVWC320 EcoFlush Close...
Home Logo
1,002 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
