Question about Candy CPCA250K Bottom Freezer Refrigerator
Candy fridge feezer CFBC3150 A UK
How to defost fridge and freezer
  • 1122 Answers
SOURCE: fridge freezer icing up
YOUR DEFROST TIMER COULD BE STUCK,FIND IT ON BACK OR FRONT OR INSIDE TURN SLOW CLOCKWISE TILL CLICK,IF FRIG. IS RUNNING IT SHOULD TURN OFF AND GO TO DEFROST,ALSO THE DEFROST HEATER IN FREEZER COULD BE BAD,OR THE TERMINATOR IN FREEZER COULD BE BAD OR THE FREEZER FAN MIGHT HAVE STOPPED,LET ME KNOW WHAT YOU KIND,THANKS-MIKE
Posted on May 30, 2008
huuum
  • 750 Answers
SOURCE: Candy CPCA250 GB Freezer feezing but fridge not cold
Hello jonnyclewlow
Welcome,
You said, you recently had a problem with my Candy fridge freezer (it defrosted overnight and wasnt cooling at all) and a repair shop diagnosed a thermostat problem. I have replaced the thermostat, Now the freezer freezes without any problems but the fridge does not go cold at all.
Also the compressor is running constantly
This is my first thought
Fresh Food temperature is
too warm. Freezer
temperature is satisfactory.
1. Fresh Food control is set too
warm.
2. Set fresh food control to a colder setting. Allow 24
hours for temperature to stabilize.
3.Then see if you do not have your freezer articles packed full up to the top, or covering the cold air vents usually found in the rear of the freezer compartment.
The fridge and the freezer share the cold air so the air must not be restricted from travel form the freezer to the fridge and back!
This would also cause the compressor to run none stop trying to cool the fridge!
So check your air vents in the freezer.
I'll bet you did not know they were there !
Most of us never notice!
Hope this works for you.
Please let me know that one of these solutions worked for you!
or if you have any questions.
Thank You, huuum
Please remember to leave a rating!
Posted on Oct 14, 2008
  • 5 Answers
SOURCE: freezing frosting fridge
i had the same problem recently with all my fridge food freezing up, this all seemed to start when i discovered the interior bulb blown i replaced it still nothing also noticed warning lights on front out,i could hear the motor going so i knew it was on i removed back cover and found the heater covered in ice it turned out it was the failure of the control board causing these problems had it replaced and working fine now hope this is of help dmb23
Posted on Jan 11, 2009
SOURCE: Candy CPCA270FFK Thermostat replacement
if your refrigerator is in warranty than contact your service authority......or if you had purchased it by your own than ...... my friend! the thermostart does'nt have any warranty
Posted on May 14, 2009
  • 85 Answers
SOURCE: Candy Frostfree Fridge freezer, model CPCA240FFK
1st of all conferm that the compressor is automatically (through Thermostate) going to ON/OFF or not, if it automatically goes OFF, i sugges its OK. and if not its no problum. (Minimum 4 hours rest is Must of a compressor, u can maunally OFF it for daily 4 hours Sleep)
Take Care
Shafky
Posted on Jun 17, 2009
How do I get the dimensions for a fridge freezer?
Looks like they are the same outer dimensions.
Old:
New:
  • Width of cavity: 560 mm
  • Height of cavity: 1772-1776 mm
  • Depth of cavity: 550 mm
http://www.appliancesdirect.co.uk/p/ckbc3150euk/candy-ckbc3150euk-integrated-fridge-freezer#maindesc
Oct 06, 2014 | Refrigerators
Candy fridge freezer not cooling in fridge compartment but freezer working ok
Check to see that fan in back of freezer is running. That's what pushes cold air into fridge.
Aug 04, 2013 | Candy Refrigerators
My fridge keeps freezing and my freezer keeps defosting
Time to get the system charged with coolant. You need someone in the HVAC business to do this, or just buy a new one!
Dec 31, 2012 | Prestige Appliances PRT295FFCS (9.3 cu....
I need a manual for candy fridge freezer
Hello there,
Please enter the model number of you refrigerator in the space below, it will give you the user manual of your refrigerator.
http://www.espares.co.uk/usermanuals.aspx?ma=775&nl=CPCA240FFK
or in
http://www.candy.it/libretti/libretto.cfm?id_line=15&ricerca=1
Hope this helped. All the best Elect_Comp
Sep 26, 2011 | Candy CPCA240FFK Bottom Freezer...
I have a micro fridge and the fridge is not cooling bt the freezer is cooling but not as it should i have the temp to the coolest and the fridge is still not cool what could it be?
it may be frosted up in the freezer behind the back wall, if there is frost build up on the back wall then you need to test the defost circut, termination therm, element and defrost timer
Jul 16, 2011 | Kenmore Side by Side Refrigerator
KitchenAid fridge model #EE4412201, freezer is NOT defrosting. Air tower iced up a little, freezer floor all ice. water in back of fridge. Freezer is cold, fridge isn't. I cleaned the freezer, took the...
try a new defrost timer. or new kit defros timer defrost terminator and heater. tfound the timer rotate, open the freezer. if you hear a noise like ICE BREAKING. your onli problem is the timer. really important after repair your fridge. allow at least 24 hr for defost the whole evap. REALLY IMPORTANT
Mar 31, 2010 | Refrigerators
Fridge Not Working
Your problem could be one of the following:
* compressor
* attachments to compressor (e.g.: relay, capacitor (if applicable) or overload protector)
* refrigerant (e.g.: restriction or leak)
* temperature control assembly
Contact an appliance service company.
Feb 19, 2010 | LG LRTBC1825T Top Freezer Refrigerator
The freezer half is not working
sounds like the defrost timer is stuck to me
call the fridge man or bur a new fridge
parts should be arround 50 plus 50 to install
but call and check first
Jul 25, 2009 | Refrigerators
Candy CPCA250K Bottom Freezer Refrigerator Logo
93 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Billy Detlefsen
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
