Question about Bosch 24 in. SHU53 Built-in Dishwasher
I have a Bosch SHU5315UC/U06 Whenever the cycle is over and it says CL, there is tiny grit on most of the dishes that has been dried on. Also, the dispenser is not open again and sometimes the soap block has not dissolved.
  • 1314 Answers
SOURCE: Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Posted on Feb 16, 2008
SOURCE: Bosch #SHU9955 Integra dishwasher for
The problem was evident during short cycle (primary cycle used) and changing to regular cycle used and back to short cycle seems to have corrected problem.
Posted on Oct 12, 2008
SOURCE: Bosch diswasher detergent dispenser doesn't open during wash cycl
I've been told we can replace the dispenser. See AppliancePartsPro.com. Part AP2834000
Posted on Mar 31, 2009
DrakeTech
  • 61 Answers
SOURCE: I have a bosch dishwasher shu6805uc/u06 to long to wash.
Well not going into the dry cycle could be a timing issue or a EOC (control panel) issue and will need to be addressed. But most dishwashers these days have a active run time during normal cycle of 110 to 120 mins, and thats not including the heated dry feature. I would let the unit run and see if it will finish on its own, and if I say it pushes two and half hours then something is wrong. A tech would most likely have to look at it, also a power reset could help but thats like a 30% chance.
DrakeTech
Posted on Dec 30, 2009
  • 457 Answers
SOURCE: Bosch dishwasher soap dispenser
all you have to do is take a flathead screwdriver and look at the dispenser it has a locking metal around thecase where the dispenser goes. it a press in and listen to it click thats when you know that section is in.the plastic around the dispenser is the section where it snaps in. also unplug the dispenser. its only one plug in. very easy but atrick that i use is make sure the rubber gasket is lubricated with something like dish soap.when installing it you have to push hard and listen for the snaps .nyc appliance repair can handle at 1-888-692-1055 based in nyc
Posted on Feb 26, 2010
Bosch Dishwasher Model SHU5315UC/U06 Looking for Cycle Buttons That are no longer avail #176079
There are several places on-line where you can find this parts. Depending on where you are. For example you can look up www.dlpartsco.com
May 08, 2016 | Bosch Dishwashers
Runs through cycle, but dishes and glasses do not dry, they are soaking wet.
10 Tips to Help the Dishwasher Run Better - Cleaning Tips ...
www.thekitchn.com/10-tips-to-make-yo...
Apartment Therapy's The KitchnFeb 24, 2014 - Well, we're here to help, with 10 tips for making your dishwasher run its best. ... loading up to help reduce particles stuck on dishes once the cycle is over. ...water to flash dry and not roll off your dishes, taking the ends of the dirty bits with it..... but can lead to damage, particularly of any glasses you put in the ...
[PDF]Dishwashers - Frequently Asked Questions ... - Bosch
www.bosch-home.com/Files/Bosch/In/in/Document/Bosch.pdf
this cycle the dishwasher dries the dishes. 3. ... dishes. During this time, you do notneed to be around the dishwasher as it ... Does it also dry the dishes after the wash?... You can put utensils that are made out of steel, ceramic, glass, plastic which is ...No, the dishwasher runs the whole washing programme automatically.
Why is My Dishwasher Not Drying the Dishes? ' Dr ...
Dec 03, 2015 | Dishwashers
Bosch SHU5315UC dishwasher doesn't end cycle
make sure 120 degree water enters the diswasher
Feb 08, 2010 | Bosch SHU5316UC Dishwasher
DrakeTech
Dec 30, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
My Bosch shu 5315uc does not advance to rinse or dry. Machine just keeps running. Dishes are dirty and smelly. Manuel says to check if water line is closed or inlet filter blocked. Have no idea how to do...
The waste pipe may be blocked or partly blocke. Is this connected with another appliance under the sink?( T junction?. It may be blocked or partly blocked.
Oct 11, 2009 | Bosch SHU5315UC Dishwasher
Wash cycle OK, but the drying cycle is faulty. The dishes are wet after 12 hours. Will not dry contents of washer! #SHU680SUC/U06
your heating coil has gone bad it`s that rod looking thing in the bottom of your unit under your spray washing spinner depending on the age of your unit your probley better off buying a new dishwasher
Oct 02, 2009 | Bosch Dishwashers
Bosch dishwasher SHU5315uc control board issue
Check the main smoothing capacitor on the control board. Could be low value.
Jul 24, 2017 | Bosch SHU5315UC Dishwasher
Bosch dishwasher SGS55M2 leaves dishes wet
Are you using drying agent?If not you have to use it in bosch dishwashers.When the cycle is completed is it hot,steam rolls out.if not you have a heater problem or thermostat problem.
If you need more info please ask
Feb 05, 2009 | Audiovox Bosch 718 World Cellular Phone
Not cleaning dishes
Our Bosch does a pretty good job of washing dishes. But we rinse most of the time. Not a hard rinse, but a rinse.
Are both spray bars rotating? You can test by seeing that the bars rotate easily by hand, and also by starting a cycle and opening the door real quick when you hear the spray hit the door.
Make sure the spray bar nozzles are all clear.
Has it ever done a good job of cleaning dishes?
DI you leave a heavy build-up of food on the dishes, and allow it to dry before washing?
Jan 26, 2009 | Bosch SHU5315UC Dishwasher
Bosch 24 in. SHU53 Built-in Dishwasher Logo
82 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
