Focus 42'' TV PW4201H
Can anyone tell us where the av audio out is on this set please.
2 Suggested Answers
bluegreenash
  • 661 Answers
SOURCE: RCA - 4228ASPDP - 42 inch Plasma - Audio Problems
Usually you would connect the SKY box to the DVD recorder and the DVD recorder to your TV, check you installation guides for setup instructions, which should show you a preferred layout diagram,
Posted on Sep 27, 2007
I have a lg 42"lcd tv turn the volume up and it just goes all the way up to full volume byitself same when you lower the volume.tried adjusting volume from side of tv manualy same thing.
What might be happening is that you have connected the TV to a home theater AV unit. I have a similar set up and as long as I am running the signal from my computer to the AV system, audio control is via the windows application and the AV system. The TV has no audio control. This can be especially true if you are connecting the TV directly to a computer.
Apr 12, 2015 | LG Televison & Video
No audio on hdmi input
Are you using this HDMI input through an AV receiver, satellite or cable box, or directly into the TV? HDMI connectors are a well known issue for going bad mechanically(the jack itself) I have advised 100's of technicians throughout the USA, during my last employment at Pioneer. These connectors are very difficult to replace, as the pins on the connector are very small and close together.
For more information or repair, please visit my website at audioserviceclinic.com. You may contact me through my website.
Thank you.
Apr 23, 2014 | LG 42PX4RV 42 in. EDTV-Ready LCD TV
Ok my 42la45h tv has been losing sound, and now it does not want to come on at all...the manufacturing date is oct.16,2007
Hi Mike,
I worry the AV PCB was damage on your TV. But prior to get repaired / replaced , first please check your audio line like wiring terminals/ connection.
If nothing problem there, you need to repair /replace the AV board.
Regards
Sep 28, 2011 | Proscan 42LA45H 42 in. LCD TV
I have a 42" Hannspree TV. What channel do I put
h;
your DVD player has an output of Audio and Video, and at the back of your TV has and input A/V
you have to connect a RCA cable to this inputs, your RCA must have 3 connectors yellow for video,red for left channel audio white for right channel audio,
then set your TV to AV1 if connect it to AV input 1,there are two AV input at the back,and also SVideo input,
you have to set it by pressing INPUT or TV on remote or button of your TV.
Sep 03, 2011 | Televison & Video
I have an lg 32ld350. I plugged in headphones into it as to not annoy anyone with the tv and when i was done i unplugged them and now i have no sound unless i use headphones. Even with them unplugged it...
Turn off ur tv.Tries take the head phone steal jack plug it in and unplug it out do this like three or four times.Tries the tv menu audio resetting again.The audio should return.Don't used ur tv head phone again the input jack socket it have problems,just lower ur tv volume for not to annoy anyone.Or used the tv head phone jack socket again will damage it for good, and will never get sound out throught ur tv speaker again.
Apr 16, 2011 | LG 42PX5D 42 in. Plasma HDTV
The sound from the amp does not match up with the video on the TV. We have 2- 25' RCA jacks, 1 to the "Video" and 1 to the "Audio-R" in the "AV IN 1" section. Are our cables...
If those are rca jacks on tv being used to go to amp ?
Are you sure they are not input TO tv rather than outputs ?
YOu must use the AV out connectors on TV to go to amp.
25 inces is fine.
Please dont forget to vote if you liked my answer
thanks
Feb 13, 2011 | LG 42LH50 42 in. HDTV LCD
We moved our tv from a room with surround sound, and we now have no volume at all on our tv. How do we reprogram the tv?
You have to get in the Audio Menu and tell the TV "What You Want". Things are now set-up to operate with an external sound system. You have to set things back to Normal or Default.
Sep 13, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
We have just recently repositioned our Philips Model No. 42PFL7422D/37 Flat Screen TV and thought we had written down the proper wiring set up for connecting to Charter Communications etc. Is there any...
CHARTER BOX
3 CABLES
YELLOW - VIDEO
RED - R. AUDIO CHANNEL
WHITE - LEFT AUDIO CHANNEL
Hook them up to tv's INPUT of the same colors
Then turn tv to input or av channel.
Mar 31, 2010 | Philips 32PF7421D 32 in. LCD HDTV
Can I set the default input?
some tv model has a setting that every time you switch on the tv the set will back on the last customer setting, other tv does not support this setting. But if your tv works as i mentioned earlier during the first time you buy it. Meaning the IC memory is malfuntion.
Jun 14, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
LG 42'' TV has no sound but great picture. How do I get the sound?
You shouldn't need anything plugged into the accessory jacks to get local sound from your set. Go through the main setup menu and check audio settings; they may be set to turn off the internal speakers to send the sound to a home theatre that you apparently don't have. Most sets have that as a selection and supply L-R audio for an external system and mute the internal speakers.
FYI: The three connectors you mention are coded as follows:
Red - right channel audio White - left channel audio Yellow - composite video (contains synchronization signals and video)
These may be input connectors (for external VCR/DVD decks) so check your owner's guide to verify.
Nov 23, 2008 | LG DU-42LZ30 42 in. LCD HDTV
Televison & Video Logo
141 people viewed this question
Top Televison & Video Experts
